Home » Archived » Visual Editor (VE) » Can't get VE to work at all
Can't get VE to work at all [message #94285] Thu, 16 June 2005 22:12 Go to next message
Originally posted by: VigilanteP.comcast.net
I installed VE and Eclipse properly, my extracting the GEF, EMF, and VE
plugin archives to the eclipse folder, they show up correctly in the feature
browser.
Whenever i try to create a new visual class of any type i am shown an error
message :
"Creation of element failed. See error log for more details".
It does this for every single type of visual class.
What could be causing this?
Re: Can't get VE to work at all [message #94296 is a reply to message #94285] Fri, 17 June 2005 05:41 Go to previous messageGo to next message
Hi Peter,
> message :
Not sure, but the log file will help diagnose what is going wrong. It
is where exceptions and problems that occur inside the running Eclipse
IDE get written. It is located in the .metadata directory of your
workspace and called .log. You can also see it in Eclipse itself by
doing Window>Show View>Error Log.
Could you please get the .log file and post it to the newsgroup so we
can take a look at what is going on ?
Joe Winchester
Re: Can't get VE to work at all [message #94334 is a reply to message #94296] Fri, 17 June 2005 22:31 Go to previous messageGo to next message
Ah ok, i was wondering where the log was or if there was a log... this makes
more sense. Heres what it says.
Internal Error org.eclipse.jdt.ui
This error occurs any time i try to make a swing, awt, or swt component with
the "new visual component" dialog.
The stacktrace of the error :
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
at
org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElementWizard.java:133)
at
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.performFinish(NewVisualClassCreationWizard.jav a:411)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:844)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3058)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2691)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at
org.eclipse.ui.internal.actions.NewWizardShortcutAction.run( NewWizardShortcutAction.java:110)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1716)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1680)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:365)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
at
org.eclipse.core.internal.runtime.InternalPlatform.asLocalUR L(InternalPlatform.java:200)
at org.eclipse.core.runtime.Platform.asLocalURL(Platform.java:4 99)
at
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.getGeneratorInstance(NewVisualClassCreationWiz ard.java:96)
at
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.applyContributor(NewVisualClassCreationWizard. java:277)
at
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.finishPage(NewVisualClassCreationWizard.java:3 11)
at
org.eclipse.jdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.java:117)
at
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:39)
at
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:718)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3760)
at
org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRunnableAdapter.java:87)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
at
at
at
at
at
at
at
at
at
Hopefully this makes sense to you
"Joe Winchester" <winchest@uk.ibm.com> wrote in message
news:d8u5rm$9aa$1@news.eclipse.org...
> Hi Peter,
>> error message :
>> "Creation of element failed. See error log for more details". It does
> Not sure, but the log file will help diagnose what is going wrong. It is
> where exceptions and problems that occur inside the running Eclipse IDE
> get written. It is located in the .metadata directory of your workspace
> and called .log. You can also see it in Eclipse itself by doing
> Could you please get the .log file and post it to the newsgroup so we can
> Best regards,
> Joe Winchester
Re: Can't get VE to work at all [message #94369 is a reply to message #94334] Sun, 19 June 2005 14:49 Go to previous messageGo to next message
This means something is not installed correctly. Please list the
versions and driver ids of the Eclipse SDk, VE, EMF, and GEF that you
installed.
Rich Kulp
Re: Can't get VE to work at all [message #94395 is a reply to message #94369] Sun, 19 June 2005 22:08 Go to previous messageGo to next message
I'm not sure what the driver ID is or how to find it but the version numbers
are :
Eclipse 3.1
EMF 2.0.1
VE 1.0.2.1
GEF 3.0.1
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:d94en4$8hb$2@news.eclipse.org...
> This means something is not installed correctly. Please list the versions
> and driver ids of the Eclipse SDk, VE, EMF, and GEF that you installed.
> Rich Kulp
Re: Can't get VE to work at all [message #94469 is a reply to message #94395] Mon, 20 June 2005 09:36 Go to previous messageGo to next message
You need to step up to the VE 1.1M2 plus the new prerequisites of EMF
and GEF. 3.1 is not supported by these older versions of code.
> are :
> Eclipse 3.1
> EMF 2.0.1
> VE 1.0.2.1
> GEF 3.0.1
>>Thanks,
>>Rich Kulp
Rich Kulp
Re: Can't get VE to work at all [message #94513 is a reply to message #94469] Tue, 21 June 2005 01:30 Go to previous messageGo to next message
Ok, after reinstalling everything and making sure i have all of the correct
versions It now lets me create the visual class but when it is initializing
the visual editor it gives me this error :
An internal error occurred during: "Create Remote VM for Visual Editor for
Java".
tried to access method
org.eclipse.pde.internal.core.WorkspaceModelManager.getWorks pacePluginModel(Lorg/eclipse/core/resources/IProject;)Lord/e clipse/pde/core/plugin/IPluginModelBase;
from class org.eclipse.jem.internal.proxy.core.ProxyPlugin
There are two other simultaneous errors but they all reference this main
problem.
Thanks for any help.
news:d96gp2$a60$2@news.eclipse.org...
> You need to step up to the VE 1.1M2 plus the new prerequisites of EMF and
>> numbers are :
>> Eclipse 3.1
>> EMF 2.0.1
>> VE 1.0.2.1
>> GEF 3.0.1
>>>Thanks,
>>>Rich Kulp
> Rich Kulp
Re: Can't get VE to work at all [message #94525 is a reply to message #94513] Tue, 21 June 2005 09:23 Go to previous messageGo to next message
Did you step up to Eclipse 3.1RC2 and VE 1.1M2 and GEF 3.1RC1 and EMF
2.1 I20050609? This says you still have a mismatch of drivers.
> Java".
Rich Kulp
Re: Can't get VE to work at all [message #94563 is a reply to message #94525] Tue, 21 June 2005 12:22 Go to previous messageGo to next message
I am using Eclipse 3.1 RC3 and i used the update utility in eclipse to
install everything, should i do it all manually instead? I figured that the
automatic installation would work best.
news:d994c8$5uo$1@news.eclipse.org...
> Did you step up to Eclipse 3.1RC2 and VE 1.1M2 and GEF 3.1RC1 and EMF 2.1
>> correct versions It now lets me create the visual class but when it is
>> initializing the visual editor it gives me this error :
>> for Java".
> Rich Kulp
Re: Can't get VE to work at all [message #94576 is a reply to message #94563] Tue, 21 June 2005 16:09 Go to previous messageGo to next message
The update utility only gets released versions. Since 3.1 and VE 1.1 and
GEF, etc. are still in development and not released, the update manager
doesn't find them. You must use the downloads for development drivers.
And VE 1.0.x does not work with Eclipse 3.1. So you must use the downloads.
Rich Kulp
Re: Can't get VE to work at all [message #94622 is a reply to message #94576] Tue, 21 June 2005 21:58 Go to previous messageGo to next message
Hmm ok then could you please tell me which versions of GEF , EMF, and VE i
should use for Eclipse 3.1 RC3 so that it will all work properly. I will
just do a fresh install with these 3 plugins.
The installation instructions do not tell me this. Thanks for your help.
news:d99s64$77h$1@news.eclipse.org...
> doesn't find them. You must use the downloads for development drivers. And
> Rich Kulp
Re: Can't get VE to work at all [message #94637 is a reply to message #94622] Tue, 21 June 2005 23:14 Go to previous messageGo to next message
>>Thanks,
>>Rich Kulp
Re: Can't get VE to work at all [message #94652 is a reply to message #94622] Tue, 21 June 2005 23:16 Go to previous messageGo to next message
Peter,
The required versions of Eclipse, GEF and EMF are listed in the
Requirements section of every download page of a VE build. See the
1.1M2 download page for example:
http://download.eclipse.org/tools/ve/downloads/drops/S-1.1M2 -200506101701/index.html
It should work ok with later builds of Eclipse, GEF and EMF, but for the
most part you should try to match the required versions.
- Jeff
>>Thanks,
>>Rich Kulp
Re: Can't get VE to work at all [message #94696 is a reply to message #94652] Wed, 22 June 2005 11:23 Go to previous message
Ah thank you very much, i guess i was trying to use the wrong versions all
along, it all works now.
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:d9al2p$ugu$2@news.eclipse.org...
> Peter,
> Requirements section of every download page of a VE build. See the 1.1M2
> - Jeff
>> i should use for Eclipse 3.1 RC3 so that it will all work properly. I
>> will just do a fresh install with these 3 plugins.
>>>downloads.
>>>Thanks,
>>>Rich Kulp
Re: Can't get VE to work at all [message #607969 is a reply to message #94285] Fri, 17 June 2005 05:41 Go to previous message
Hi Peter,
> message :
Joe Winchester
Re: Can't get VE to work at all [message #607974 is a reply to message #94296] Fri, 17 June 2005 22:31 Go to previous message
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Root exception:
at
at
at
at
at
at
at
at
at
> Hi Peter,
>> error message :
> Best regards,
> Joe Winchester
Re: Can't get VE to work at all [message #607981 is a reply to message #94334] Sun, 19 June 2005 14:49 Go to previous message
installed.
Rich Kulp
Re: Can't get VE to work at all [message #607989 is a reply to message #94369] Sun, 19 June 2005 22:08 Go to previous message
are :
Eclipse 3.1
EMF 2.0.1
VE 1.0.2.1
GEF 3.0.1
> Rich Kulp
Re: Can't get VE to work at all [message #608006 is a reply to message #94395] Mon, 20 June 2005 09:36 Go to previous message
> are :
> Eclipse 3.1
> EMF 2.0.1
> VE 1.0.2.1
> GEF 3.0.1
>>Thanks,
>>Rich Kulp
Rich Kulp
Re: Can't get VE to work at all [message #608020 is a reply to message #94469] Tue, 21 June 2005 01:30 Go to previous message
Java".
problem.
>> numbers are :
>> Eclipse 3.1
>> EMF 2.0.1
>> VE 1.0.2.1
>> GEF 3.0.1
>>>Thanks,
>>>Rich Kulp
> Rich Kulp
Re: Can't get VE to work at all [message #608023 is a reply to message #94513] Tue, 21 June 2005 09:23 Go to previous message
> Java".
Rich Kulp
Re: Can't get VE to work at all [message #608027 is a reply to message #94525] Tue, 21 June 2005 12:22 Go to previous message
>> for Java".
> Rich Kulp
Re: Can't get VE to work at all [message #608028 is a reply to message #94563] Tue, 21 June 2005 16:09 Go to previous message
Rich Kulp
Re: Can't get VE to work at all [message #608034 is a reply to message #94576] Tue, 21 June 2005 21:58 Go to previous message
> Rich Kulp
Re: Can't get VE to work at all [message #608036 is a reply to message #94622] Tue, 21 June 2005 23:14 Go to previous message
>>Thanks,
>>Rich Kulp
Re: Can't get VE to work at all [message #608039 is a reply to message #94622] Tue, 21 June 2005 23:16 Go to previous message
Peter,
- Jeff
>>Thanks,
>>Rich Kulp
Re: Can't get VE to work at all [message #608046 is a reply to message #94652] Wed, 22 June 2005 11:23 Go to previous message
> Peter,
> - Jeff
>>>downloads.
>>>Thanks,
>>>Rich Kulp
Previous Topic:Eclipse Forms UI - is it supported?
Next Topic:VE on Mac OS X
Current Time: Sun Jul 20 15:04:18 EDT 2025
Powered by FUDForum. Page generated in 0.12044 seconds
