Home » Archived » Visual Editor (VE) » N20050616: Unable to open a Swing visual class
N20050616: Unable to open a Swing visual class [message #94291] Fri, 17 June 2005 03:56 Go to next message
I'm testing the new nightly build N20050616 (W2K, Swing) and I'm unable to
open a Swing visual class. An error message appears: An internal error
occurred during: "Setup Java Visual Editor".
Voila the exception stack trace:
java.lang.NoSuchMethodError:
org.eclipse.ve.internal.cde.core.CDEPlugin.hasInitialization Data(Ljava/lang/String;)Z
at
org.eclipse.ve.internal.jcm.impl.BeanDecoratorImpl.createBea nProxy(BeanDecoratorImpl.java:628)
at
org.eclipse.ve.internal.java.core.BeanProxyAdapterFactory.cr eateAdapter(BeanProxyAdapterFactory.java:106)
at
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.create Adapter(AdapterFactoryImpl.java:138)
at
org.eclipse.emf.common.notify.impl.AdapterFactoryImpl.adaptN ew(AdapterFactoryImpl.java:112)
at
org.eclipse.emf.ecore.util.EcoreUtil.getRegisteredAdapter(Ec oreUtil.java:100)
at
org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean ProxyHost(BeanProxyUtilities.java:449)
at
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:365)
at
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:278)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1868)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Francesc Rosés
Re: N20050616: Unable to open a Swing visual class [message #94301 is a reply to message #94291] Fri, 17 June 2005 09:15 Go to previous messageGo to next message
Did you do a -clean first when you started Eclipse?
Also after doing -clean try doing a Project->Clean...->Clean all projects.
Rich Kulp
Re: N20050616: Unable to open a Swing visual class [message #94342 is a reply to message #94301] Sat, 18 June 2005 05:23 Go to previous messageGo to next message
I tried it with the same results.
Francesc Rosés
Re: N20050616: Unable to open a Swing visual class [message #94382 is a reply to message #94342] Sun, 19 June 2005 14:51 Go to previous messageGo to next message
this means something is not installed correctly. That method does exist.
Please list the Eclipse, EMF, and GEF builds that you have installed.
How did you install it? Try a fresh clean installation of
Eclipse,EMf,GEF, and VE instead of unzipping onto an existin one.
Francesc Rosés wrote:
> Hello,
> Francesc Rosés
Rich Kulp
Re: N20050616: Unable to open a Swing visual class [message #94410 is a reply to message #94382] Mon, 20 June 2005 01:21 Go to previous messageGo to next message
I'll try with a clean installation later this morning.
Francesc
Re: N20050616: Unable to open a Swing visual class [message #94424 is a reply to message #94382] Mon, 20 June 2005 04:44 Go to previous message
Clean install Eclipse 3.1 RC3 and VE N20050616. Works!
I can assure the previous tests had the correct EMF and GEF versions.
Francesc Rosés
Re: N20050616: Unable to open a Swing visual class [message #607970 is a reply to message #94291] Fri, 17 June 2005 09:15 Go to previous message
Rich Kulp
Re: N20050616: Unable to open a Swing visual class [message #607975 is a reply to message #94301] Sat, 18 June 2005 05:23 Go to previous message
Francesc Rosés
Re: N20050616: Unable to open a Swing visual class [message #607987 is a reply to message #94342] Sun, 19 June 2005 14:51 Go to previous message
> Hello,
> Francesc Rosés
Rich Kulp
Re: N20050616: Unable to open a Swing visual class [message #607991 is a reply to message #94382] Mon, 20 June 2005 01:21 Go to previous message
Francesc
Re: N20050616: Unable to open a Swing visual class [message #607993 is a reply to message #94382] Mon, 20 June 2005 04:44 Go to previous message
Francesc Rosés
Previous Topic:VE preview goes way out of the viewable screen and other strange behaviours
Next Topic:Box.createRigidArea() Problem
Current Time: Sun Jul 20 03:05:27 EDT 2025
Powered by FUDForum. Page generated in 0.05956 seconds
