Home » Archived » Visual Editor (VE) » Class cast exception on customizer OK click
Class cast exception on customizer OK click [message #607764] Sat, 14 May 2005 20:33
Suddenly getting the error below any time I click VE's OK button on my
customizer. My code seems to complete entirely. The property sheet
gets updated with the correct values. No code is generated, though.
Any idea the cause? Suggestions on how to debug/determine what class is
causing the problem? What is the minimum necessary VE part of CVS that
I should check out to support debugging this?
!ENTRY org.eclipse.ve.java.core 2 0 2005-05-14 17:24:14.231
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassCastException:
org.eclipse.ve.internal.java.core.TypeReferenceCellEditor
at
org.eclipse.ve.internal.java.core.CustomizeJavaBeanAction.cu stomizerOK
(CustomizeJavaBeanAction.java:234)
at org.eclipse.ve.internal.java.core.CustomizeJavaBeanAction.ru n
(CustomizeJavaBeanAction.java:137)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2
(ActionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t
(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents
(Display.java:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2527)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run
(IDEApplication.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run
(PlatformActivator.java:228)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:344)
(EclipseStarter.java:156)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Previous Topic:Adding JRadioButton to ButtonGroup generates improper code
Next Topic:How to add compontents to the Visual Editor design - palette
Current Time: Sat Jul 19 17:18:35 EDT 2025
Powered by FUDForum. Page generated in 0.04869 seconds
