Home » Modeling » Papyrus » Dragging existing SysML blocks into block definition diagrams doesn't work
Dragging existing SysML blocks into block definition diagrams doesn't work [message #607445] Tue, 14 September 2010 09:23 Go to next message
Hey guys,
I'm not sure if this is a bug or if I'm missing something.
I have some existing SysML blocks which I use in an internal block diagram. Now I want to use the same blocks in a block definition diagram. I tried dragging them from the Model Explorer into the diagram, but the dropping is not allowed.
What works is creating new blocks directly into the diagram by selecting "Block" from the Palette. But when I remove them I can never put them back into the diagram again.
Dragging existing blocks from the Model Explorer into block definition diagrams is not working. It's no problem with internal block diagrams, though.
Any ideas?
Markus
Re: Dragging existing SysML blocks into block definition diagrams doesn't work [message #607450 is a reply to message #607445] Wed, 15 September 2010 04:55 Go to previous messageGo to next message
Hi Markus,
Looks like a bug as you should definitively be able to drag and drop
blocks from model explorer in a BDD.
Can you please open a bug in the bugzilla?
thanks
raphaël
Le 14/09/2010 15:23, Markus Lorenz a écrit :
> Hey guys,
> though.
> Any ideas?
> Regards,
> Markus
Re: Dragging existing SysML blocks into block definition diagrams doesn't work [message #607452 is a reply to message #607445] Wed, 15 September 2010 06:57 Go to previous message
I'll open a bug in bugzilla. Thanks for your answer.
Previous Topic:Dragging existing SysML blocks into block definition diagrams doesn't work
Next Topic:Opening a papyrus UML diagram editor programatically
Current Time: Sat Jul 19 23:14:50 EDT 2025
Powered by FUDForum. Page generated in 0.04551 seconds
