Home » Archived » Visual Editor (VE) » PTArrayCreation
PTArrayCreation [message #87442] Mon, 18 April 2005 11:02 Go to next message
could you please say me how to create an array statement for an
initializing.
I tried it with this statement:
<arguments
xsi:type="org.eclipse.jem.internal.instantiation:PTArrayCreation "
type ="java.lang.String" dimensions="1">
<initializer
xsi:type="org.eclipse.jem.internal.instantiation:PTArrayInitializer "
expressions = "arg1, arg2"/>
</arguments>
But it did not work :-(
Thank you in advance
Elena
Re: PTArrayCreation [message #87473 is a reply to message #87442] Mon, 18 April 2005 11:26 Go to previous messageGo to next message
Hi Elena,
> Hello,
> initializing.
The best way for this is to enable the VE to show the viewer with the
XML for its EMF model. In the development environment (the one you are
writing your plugin in) open the launch configuration and go to the
Tracing tab and enable tracing for org.eclipse.ve.java.core and select
debug/xmltext. Then in the workbench you lauch visit the preferences
for Java/Visual Editor and there will be a checkbox called "Show XML
viewer". Check this.
Now when you open the VE you will see a text viewer showing the parsed
XML definition of the EMF model. Sometimes it doesn't show up with
contents first time so change something like a button label or move
something on the free form to get it refreshed.
This model will let you see the allocation for everything. Go into the
code and manually write the constructor with the array you want and then
let the VE parse it and build you the parseTreeAllocation. Once you see
what the VE builds then you just have to make this the allocation you
generate.
Joe Winchester
Re: PTArrayCreation [message #87517 is a reply to message #87473] Mon, 18 April 2005 12:47 Go to previous messageGo to next message
sorry , but I don not see any check box "Show xml viewer". If I visit
"Preferences | Java | Visual Editor" I see three widgets:
appearance, code generation and pattern styles. And there is no check box
that you mean.
Could you please specify where I can find and activate the check box.
Thank you
Elena
Re: PTArrayCreation [message #87559 is a reply to message #87442] Mon, 18 April 2005 13:23 Go to previous messageGo to next message
Elena wrote:
> Hello,
> initializing.
> <arguments
> <initializer
> </arguments>
> Elena
<allocation xsi:type="org.eclipse.jem.internal.instantiation:ParseTreeAllocation ">
<expression xsi:type=" org.eclipse.jem.internal.instantiation:PTClassInstanceCreati on " type="Foo">
<arguments xsi:type="org.eclipse.jem.internal.instantiation:PTArrayCreation " type="java.lang.String[]">
<initializer>
<expressions xsi:type="org.eclipse.jem.internal.instantiation:PTStringLiteral " escapedValue="&quot;foo&quot;"/>
<expressions xsi:type="org.eclipse.jem.internal.instantiation:PTStringLiteral " escapedValue="&quot;bar&quot;"/>
</initializer>
</arguments>
</expression>
</allocation>
Re: PTArrayCreation [message #87620 is a reply to message #87517] Mon, 18 April 2005 17:58 Go to previous messageGo to next message
Hi Elena,
> box that you mean.
Gili gave you the parse tree so his answer was better than mine which
was sort of a "I don't know but I know how to find out" kind of reply.
You have to start eclipse in debug mode to get the check box showing.
Look at the help for the section on starting the VE in debug mode which
talks about the tracing tab. Once you've got this trace the plugin
org.eclipse.ve.java.core and select the option debug/xmltext. Only once
this is done will you see the check box.
Sometimes when you do tracing it is hard because you have to check the
plugin and the debug option and I am always forgetting to do the former
and wondering why it isn't enabled.
Joe Winchester
Re: PTArrayCreation [message #87634 is a reply to message #87559] Tue, 19 April 2005 08:38 Go to previous messageGo to next message
thank you for an answer. The creation of array does work :-). My component
can be initialized and the string array can be read correctly !!!
But in the .log I get an exception:
"Error Apr 19, 2005 14:25:15.866 Invalid name specified:
java.lang.String[]"
Here is a section from my .xmi:
<arguments
<initializer>
<expressions
escapedValue="&quot;ButtonLabels&quot;"/>
<expressions
</initializer>
</arguments>
Do you know what the cause for this exception is ?
Elena
Re: PTArrayCreation [message #87649 is a reply to message #87634] Tue, 19 April 2005 09:45 Go to previous messageGo to next message
Could we please add the rest of the exception stack trace so that we can
see where the error was produced. The message by itself is not sufficient.
> java.lang.String[]"
Rich Kulp
Re: PTArrayCreation [message #87662 is a reply to message #87649] Tue, 19 April 2005 10:06 Go to previous messageGo to next message
unfortunately there is only a message "An exception stack trace could not
be found."
And in the "error log" - view I can see that the exception comes from
the plug-in "org.eclipse.jdt.core". Not more.
Elena
Re: PTArrayCreation [message #87675 is a reply to message #87662] Tue, 19 April 2005 10:37 Go to previous messageGo to next message
Look in the actual .log file itself. In your workspace's .metadata
directory. That is usually a more complete view for us. IF nothing else
is there either, then what can you do? :-)
Are there any other messages in the .log file?
Rich Kulp
Re: PTArrayCreation [message #87689 is a reply to message #87675] Tue, 19 April 2005 11:11 Go to previous messageGo to next message
I swear that there are only two lines in the .log-File:
!ENTRY org.eclipse.jdt.core 4 983 Apr 19, 2005 17:05:13.306
!MESSAGE Invalid name specified: java.lang.String[]
Elena
Re: PTArrayCreation [message #87703 is a reply to message #87689] Tue, 19 April 2005 12:07 Go to previous messageGo to next message
Well, are things working? I don't know who is producing it. JDT isn't
being nice. It isn't saying what method is doing this. If things are
working, I guess we can just leave it go for now. It's not the VE code
so I can't isolate it.
> Thanks :-)
> Elena
Rich Kulp
Re: PTArrayCreation [message #87732 is a reply to message #87703] Wed, 20 April 2005 03:59 Go to previous messageGo to next message
OK.
Re: PTArrayCreation [message #87859 is a reply to message #87732] Wed, 20 April 2005 10:11 Go to previous message
I actually just tried it with 3.1M6 of Eclipse and I don't get the msg.
Maybe something has changed.
Elena wrote:
> OK.
Rich Kulp
Re: PTArrayCreation [message #607165 is a reply to message #87442] Mon, 18 April 2005 11:26 Go to previous message
Hi Elena,
> Hello,
> initializing.
generate.
Joe Winchester
Re: PTArrayCreation [message #607168 is a reply to message #87473] Mon, 18 April 2005 12:47 Go to previous message
that you mean.
Thank you
Elena
Re: PTArrayCreation [message #607171 is a reply to message #87442] Mon, 18 April 2005 13:23 Go to previous message
Elena wrote:
> Hello,
> initializing.
> <arguments
> <initializer
> </arguments>
> Elena
<initializer>
</initializer>
</arguments>
</expression>
</allocation>
Re: PTArrayCreation [message #607175 is a reply to message #87517] Mon, 18 April 2005 17:58 Go to previous message
Hi Elena,
> box that you mean.
Joe Winchester
Re: PTArrayCreation [message #607176 is a reply to message #87559] Tue, 19 April 2005 08:38 Go to previous message
java.lang.String[]"
<arguments
<initializer>
<expressions
<expressions
</initializer>
</arguments>
Elena
Re: PTArrayCreation [message #607177 is a reply to message #87634] Tue, 19 April 2005 09:45 Go to previous message
> java.lang.String[]"
Rich Kulp
Re: PTArrayCreation [message #607178 is a reply to message #87649] Tue, 19 April 2005 10:06 Go to previous message
be found."
Elena
Re: PTArrayCreation [message #607179 is a reply to message #87662] Tue, 19 April 2005 10:37 Go to previous message
Rich Kulp
Re: PTArrayCreation [message #607180 is a reply to message #87675] Tue, 19 April 2005 11:11 Go to previous message
Elena
Re: PTArrayCreation [message #607181 is a reply to message #87689] Tue, 19 April 2005 12:07 Go to previous message
> Thanks :-)
> Elena
Rich Kulp
Re: PTArrayCreation [message #607183 is a reply to message #87703] Wed, 20 April 2005 03:59 Go to previous message
OK.
Re: PTArrayCreation [message #607193 is a reply to message #87732] Wed, 20 April 2005 10:11 Go to previous message
Elena wrote:
> OK.
Rich Kulp
Previous Topic:New VE user would appreciate advice as I am having trouble with working with JPanels in JPanels in a
Next Topic:Icons on the custom widgets in VE are not visible
Current Time: Sat Jul 19 14:26:41 EDT 2025
Powered by FUDForum. Page generated in 0.07909 seconds
