Home » Archived » Visual Editor (VE) » Estimation
Estimation [message #87392] Mon, 18 April 2005 04:13 Go to next message
as you know I would like to implement a relationship between components
that is a little bit like a relationship between a Shell and SWT Button.
In my case there is a variable:
Hashmap hm;
in the code. And if I drop a swing button on the frame a button with a
parameter hm has to be instantiated.
myButton = new MyButton(hm);
Hashmap for my button has to be like parentComposite (Shell) for SWT
button.
(1)
Do I have to develop an editpart and an editpoliy beside decoderhelper to
reach my aim ? Or do I have to implement other classes? I have already
seen how to define an editpart and an editpoliy in override files.
I know I asked you a lot about instantiating a component with a parameter.
I really appreciate that you always gave me a detailed answer.
(2)
Could you give me an estimation how complex it is to implement my case or
how long it would take? It must also be considered that I am new in this
theme.
Thank you in advance
Elena
Re: Estimation [message #87408 is a reply to message #87392] Mon, 18 April 2005 06:33 Go to previous messageGo to next message
I think it is important to say that Hashmap is not a graphical class.
Elena
Re: Estimation [message #87457 is a reply to message #87392] Mon, 18 April 2005 11:21 Go to previous messageGo to next message
Hi Elena,
> or how long it would take? It must also be considered that I am new in
> this theme.
What is the hierarchy of your classes. You said none of them were
visual but then you talked about Swing. Is your example something like
A extends Object{
public B getB();
public void setB(B);
B extends Object{
public void addA(A);
public void removeA(A);
What is the example of a full class .java code that contains a
relationship between parent and child you want the VE to be able to open
with ?
Joe
Re: Estimation [message #87488 is a reply to message #87457] Mon, 18 April 2005 12:37 Go to previous messageGo to next message
Hello :o),
in my case the relationship is like this:
Public class B extends JButton {
Public B (A a) {
a.setB(this);
Public class A extends Hashtable {
putB(B b) {…}
As you see the class B is a visual class and the class A is a not visual
class. The Class A has a list of Objects of the class B. I hope it is
possible to implement my example.
Thank you very much :-)
Elena
Re: Estimation [message #88452 is a reply to message #87392] Mon, 25 April 2005 08:38 Go to previous message
could you give me a hint what classes and interfaces I must implement and
where it is better to start?
Thank you
Elena
Re: Estimation [message #607161 is a reply to message #87392] Mon, 18 April 2005 06:33 Go to previous message
Elena
Re: Estimation [message #607164 is a reply to message #87392] Mon, 18 April 2005 11:21 Go to previous message
Hi Elena,
> this theme.
A extends Object{
public B getB();
B extends Object{
with ?
Joe
Re: Estimation [message #607166 is a reply to message #87457] Mon, 18 April 2005 12:37 Go to previous message
Hello :o),
Public B (A a) {
a.setB(this);
putB(B b) {…}
Elena
Re: Estimation [message #607233 is a reply to message #87392] Mon, 25 April 2005 08:38 Go to previous message
Thank you
Elena
Previous Topic:VE Installation
Next Topic:Instantiating derrived component
Current Time: Sat Jul 19 06:04:10 EDT 2025
Powered by FUDForum. Page generated in 0.25828 seconds
