Home » Archived » Visual Editor (VE) » how to actually run VE code...?
how to actually run VE code...? [message #87102] Thu, 14 April 2005 01:20 Go to next message
Originally posted by: simon.ou.edu
Hi...
How do I actually run the code generated from VE? When I try to run the
code, I get the following (see below at the end of the message). The
tutorial at
http://www-106.ibm.com/developerworks/opensource/library/os- ecvisual/
says to put something like what follows in the arguments:
-Djava.library.path=C:\eclipse\plugins\org.eclipse.swt.win32 _3.0.0\os\win32\x86
but I do not see a 'org.eclipse.swt.win32...' plugin any where. I wonder
what I could do to run the code? Thanks.
Regards...
Miguel.
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-win32-3128 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:125)
at SWTExample.main(SWTExample.java:30)
Re: how to actually run VE code...? [message #87129 is a reply to message #87102] Thu, 14 April 2005 05:32 Go to previous messageGo to next message
Hi Miguel,
> tutorial at
SWT requires a bit of native code every operating system it runs on, and
the name and location of this varies. If you're using Eclipse 3.1 as
your development platform then this has a new friendly launcher called
"SWT Application". Select this instead of "Java Application" and it
does a pretty good job of finding the location of the native library and
adding it to the VM arguments for you. If this works you can also go to
the debug perspective, bring up the properties on the entry in the Debug
viewer you will actually see the whole arguments to the javaw.exe
command and you could copy and paste the -Djava.library ... bit if
you're trying to create a batch file for example.
How did you find the tutorial overall ? If you've got any feedback
please add it to the bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88801. It's having its
final review right now by the Eclipsecorner editors for formatting and
stuff, but if you found any errors or anything more that needs
explaining please let us know, as in the new few days it'll move from
our CVS repository where we can make instant change to the Eclipsecorner
one where we don't have commit rights and updates will become harder.
Joe Winchester
Re: how to actually run VE code...? [message #87174 is a reply to message #87129] Thu, 14 April 2005 10:34 Go to previous messageGo to next message
Joe, The SWT launcher from Eclipse is broken right now. They also got
caught by the everything in jar problem that we got bit with!
Rich Kulp
Re: how to actually run VE code...? [message #87187 is a reply to message #87174] Thu, 14 April 2005 11:42 Go to previous messageGo to next message
Hi Rich...
Thanks for this update. I was not sure of what I was doing wrong because
I could not get any thing to work.
Using E.3.1, with the latest VE nightly build, how could I run the VE
SWT example? I do not find the org.eclipse.swt.win32_3... plugin. Is
this broken somehow, or... I am not too sure of what to do. The following:
-Djava.library.path=" installation_directory\plugins\org.eclipse.swt.win32_3.0.0\o s\win32\x86
seems not to be an option? Thanks for your suggestions.
Regards...
Miguel.
Re: how to actually run VE code...? [message #87199 is a reply to message #87129] Thu, 14 April 2005 11:52 Go to previous messageGo to next message
Hi Joe...
Thanks for your help.
The SWT launcher did not work, but we know this now.
With regard to the article, I have not been able to put time into this
yet, but it does look very promising. I think that the format is
adequate, and the message does get across. It seems that the article is
adequate at least for folks at my proficiency level ( <= medium).
Thanks for the efforts that have gone in the article.
I am interested in a 2D plot widget that scrolls as inputs come by. I
will use your article to see if I can do something along this line.
Thanks again.
Regards...
Miguel.
> Best regards,
> Joe Winchester
Re: how to actually run VE code...? [message #87213 is a reply to message #87187] Thu, 14 April 2005 12:22 Go to previous messageGo to next message
Hi Miguel,
Run your class with the main(String[]) method using the Java Application
launcher and look at the error message. You had one like:
Find the file swt-win32-3128.dll in the file system. You could just
Windows explorer and just search for it starting at the root location of
your Eclipse install. Once you have file right mouse click and bring up
its properties and in Windows you can select beside the Location label
and use Ctrl+C to copy this into the clipboard. Let's assume the label
is something like:
C:\Eclipse_3_1_M6\eclipse\workspaces\dev_04_11\org.eclipse.s wt.win32\os\win32\x86\swt-win32-3128.dll.
Then go back to your Java Application launcher configuration, select the
second tab called Arguments and in the text box called VM Arguments:
write the line;
-Djava.library.path=""
and between the quotation marks copy the clipboard contents and remove
the last segment (the actual dll name) so it'd become something like
-Djava.library.path=" C:\Eclipse_3_1_M6\eclipse\workspaces\dev_04_11\org.eclipse.s wt.win32\os\win32\x86 "
I think from Rich's post that there might be some issue with the actual
location of the dll being in a jar file in which case you'd need to
extract it. However it worked for me using an M6 3.1 driver although I
had imported the plugin project org.eclipse.swt into my workspace.
Joe
Re: how to actually run VE code...? [message #87228 is a reply to message #87213] Thu, 14 April 2005 12:38 Go to previous message
Hi Joe...
Yes, this works. Simple and easy. Thanks again.
Regards...
Miguel.
> Hi Miguel,
> is something like:
> write the line;
> Best regards,
> Joe
Re: how to actually run VE code...? [message #607141 is a reply to message #87102] Thu, 14 April 2005 05:32 Go to previous message
Hi Miguel,
> tutorial at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88801 It's having its
Joe Winchester
Re: how to actually run VE code...? [message #607144 is a reply to message #87129] Thu, 14 April 2005 10:34 Go to previous message
Rich Kulp
Re: how to actually run VE code...? [message #607145 is a reply to message #87174] Thu, 14 April 2005 11:42 Go to previous message
Hi Rich...
Regards...
Miguel.
Re: how to actually run VE code...? [message #607146 is a reply to message #87129] Thu, 14 April 2005 11:52 Go to previous message
Hi Joe...
Thanks again.
Regards...
Miguel.
> Best regards,
> Joe Winchester
Re: how to actually run VE code...? [message #607147 is a reply to message #87187] Thu, 14 April 2005 12:22 Go to previous message
Hi Miguel,
is something like:
write the line;
Joe
Re: how to actually run VE code...? [message #607148 is a reply to message #87213] Thu, 14 April 2005 12:38 Go to previous message
Hi Joe...
Regards...
Miguel.
> Hi Miguel,
> is something like:
> write the line;
> Best regards,
> Joe
Previous Topic:My bean extends JPanel and is not visible when I choo it as a new Visual component
Next Topic:how to visually edit an old program made in Visual Age for Java?
Current Time: Sat Jul 19 14:17:23 EDT 2025
Powered by FUDForum. Page generated in 0.05404 seconds
