Home » Archived » Visual Editor (VE) » Moving from JBuilder to Eclipse
Moving from JBuilder to Eclipse [message #86119] Fri, 08 April 2005 11:00 Go to next message
Originally posted by: francisc.brs.ca
Must be a popular question, but i just can't find the info...
Our current product was developed using JBuilder and we're checking how
to jump to Eclipse. The only problem is all the bunch of GUI generated
by JBuiler wich is really ugly when we open the files Swing files in VE.
Does anyone has a link or something where i could find the info?
Re: Moving from JBuilder to Eclipse [message #86562 is a reply to message #86119] Mon, 11 April 2005 09:58 Go to previous messageGo to next message
> Thanks
You may be having some of the issues noted in the following:
http://dev.eclipse.org/newslists/news.eclipse.tools.ve/msg02 743.html
https://bugs.eclipse.org/bugs/show_bug.cgi?id=82734
If you have other issues, it will be great if you can include a snippet of code that causes these problems.
Re: Moving from JBuilder to Eclipse [message #86610 is a reply to message #86562] Mon, 11 April 2005 10:37 Go to previous messageGo to next message
Problem is we only use standard Swing components and layouts.
When opening a file in VE, that was done with JBuilder, we see the
components scattered around. All the frames are extending JFrame.
That, for some reason, VE don't like.
I tried creating classes directly with VE, extending JFrame, not
encapsulating, and i get the same result. You see the frame's head at
the top of the editor, and the components scattered but looks like list...
So, i'm not sure if the jbInit() the problem. The way i see it, VE just
doesn't like us to extend for JFrame (or others). The only it seems to
work properly is to encapsulate.
Maybe i'm wrong about that to.
>> how to jump to Eclipse. The only problem is all the bunch of GUI
>> generated by JBuiler wich is really ugly when we open the files Swing
>> files in VE.
>> Thanks
Re: Moving from JBuilder to Eclipse [message #86624 is a reply to message #86610] Mon, 11 April 2005 10:46 Go to previous messageGo to next message
Please append an example of .java file in error. That will tell us if it
is the coding pattern or if it is some other error.
Rich Kulp
Re: Moving from JBuilder to Eclipse [message #86666 is a reply to message #86624] Mon, 11 April 2005 11:34 Go to previous messageGo to next message
--------------090002070307020203000402
First, i'm trying to convince my co workers to switch to Eclipse. This
file is from a Swing application in wich i have no implications. But i
need to find a way for that programmer to be able to continue his Swing
development for me to convince him... My boss is pressuring me to do so.
Obviously i don't send the whole project for legal reasons.
But, like i wrote in my previous email, i have seen the problem even
creating a class straight from VE. It seems to dislike extending
JFrames. Encapsulation works fine. But there are too many Swing related
files created with JBuiler, and they won't be happy if they have to
re-write the whole thing...
name="MainMenu.java"
Content-Disposition: inline;
filename="MainMenu.java"
package ca.caddy.caddyweb;
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
import javax.swing.border.*;
import ca.caddy.caddyweb.util.*;
import java.util.ArrayList;
import java.util.Collection;
import ca.caddy.caddyweb.fw.DataBean;
import ca.caddy.caddyweb.fw.DataBeanFactory;
import ca.caddy.caddyweb.general.client.DataBeanFactory1;
import ca.caddy.caddyweb.general.client.PermissionBean;
/*import ca.caddy.caddyweb.handicap.edit.teemarker.TeeMarkerEditIntFr ame;
import ca.caddy.caddyweb.handicap.edit.handicapclass.HandicapClassE dit;
import ca.caddy.caddyweb.handicap.edit.handicapclubcourse.*;
import ca.caddy.caddyweb.handicap.edit.membergames.MemberGameHystor yEdit;*/
import ca.caddy.caddyweb.reports.CaddyReportsIntFrame;
import ca.caddy.caddyweb.reports.CaddyReportsMaintenance;
import ca.caddy.caddyweb.edit.tournament.TournamentEditIntFrame;
import java.util.ResourceBundle;
import java.lang.reflect.*;
import ca.caddy.caddyweb.reservation.client.TeeSheetBean;
import ca.caddy.caddyweb.tools.*;
import ca.caddy.caddyweb.search.CaddySearchMainIntFrame;
import ca.caddy.caddyweb.edit.search.CaddySearchMemberPanel;
import ca.caddy.caddyweb.reservation.client.MemberClubBean;
import ca.caddy.caddyweb.status.ClientStatusDialog;
import ca.caddy.caddyweb.widgets.*;
import ca.caddy.caddyweb.edit.cart.*;
import ca.caddy.caddyweb.edit.category.*;
import ca.caddy.caddyweb.edit.club.*;
import ca.caddy.caddyweb.edit.course.*;
import ca.caddy.caddyweb.edit.crossover.*;
import ca.caddy.caddyweb.edit.draw.*;
import ca.caddy.caddyweb.edit.holiday.*;
import ca.caddy.caddyweb.edit.locker.*;
import ca.caddy.caddyweb.edit.member.*;
import ca.caddy.caddyweb.edit.member.memberimport.*;
import ca.caddy.caddyweb.edit.membertype.*;
import ca.caddy.caddyweb.edit.ninehole.*;
import ca.caddy.caddyweb.edit.refsheet.*;
import ca.caddy.caddyweb.edit.role.*;
import ca.caddy.caddyweb.edit.teesheettemplate.*;
import ca.caddy.caddyweb.edit.typetable.*;
import ca.caddy.caddyweb.edit.user.*;
import ca.caddy.caddyweb.edit.properties.club.*;
import ca.caddy.caddyweb.exception.*;
import ca.caddy.caddyweb.gridgenerator.*;
import ca.caddy.caddyweb.rnr.*;
import ca.caddy.caddyweb.pos.client.GreenFeeTableBean;
* <p>Title: Main Caddy window</p>
* <p>Description: The CaddyWeb Main Menu</p>
* <p>Copyright: Copyright (c) 2002</p>
* <p>Company: Caddy Systems</p>
* @author Marc-Andr
Re: Moving from JBuilder to Eclipse [message #86884 is a reply to message #86666] Tue, 12 April 2005 10:52 Go to previous messageGo to next message
There are two issues with the pattern in the file above. It is something we should fix.
1. is https://bugs.eclipse.org/bugs/show_bug.cgi?id=48552
VE currently will not parse some thing like
this.getContentPane().setLayout(borderLayout1);
As a workaround, you can select the "this.getContentPane()", ContextMenu->Refactor->Extract Local Variable
It will create the following expression
Container contentPane = this.getContentPane();
Replace it with
Container contentPane = new JPanel();
this.setContentPane(contentPane);
2. is https://bugs.eclipse.org/bugs/show_bug.cgi?id=91138
VE will not model a border interface by default. You can force it to model it by either:
changing decleration like these:
private Border border1;
to
private Border ivjborder1;
or
private Border border1; // @jve:decl-index=0
Adding ivj in front of the decleration, or the @jve: comment will force the modeling of a border interface.
You can add yourself to these bugs if you want to. The more interest there is for a particular bug, the higher it gets
prioritized.
Re: Moving from JBuilder to Eclipse [message #86912 is a reply to message #86884] Tue, 12 April 2005 11:53 Go to previous message
Thanks. I'll had to the bugs soon.
I'll try that solution for one file and see what happens.
> Replace it with
> model it by either:
> to
> or
> there is for a particular bug, the higher it gets prioritized.
Re: Moving from JBuilder to Eclipse [message #607104 is a reply to message #86119] Mon, 11 April 2005 09:58 Go to previous message
> Thanks
Re: Moving from JBuilder to Eclipse [message #607107 is a reply to message #86562] Mon, 11 April 2005 10:37 Go to previous message
>> files in VE.
>> Thanks
Re: Moving from JBuilder to Eclipse [message #607108 is a reply to message #86610] Mon, 11 April 2005 10:46 Go to previous message
Rich Kulp
Re: Moving from JBuilder to Eclipse [message #607111 is a reply to message #86624] Mon, 11 April 2005 11:34 Go to previous message
import java.awt.*;
* @author Marc-Andr
Re: Moving from JBuilder to Eclipse [message #607124 is a reply to message #86666] Tue, 12 April 2005 10:52 Go to previous message
Replace it with
to
or
prioritized.
Re: Moving from JBuilder to Eclipse [message #607126 is a reply to message #86884] Tue, 12 April 2005 11:53 Go to previous message
> Replace it with
> model it by either:
> to
> or
Previous Topic:Support of JFace and swt library
Next Topic:adding popup menu to generate code
Current Time: Sat Jul 19 10:56:51 EDT 2025
Powered by FUDForum. Page generated in 0.06564 seconds
