Support of JFace and swt library [message #607096] |
Sun, 10 April 2005 23:36 |
It was said here that the ve version for the M6 eclipse version would
support JFace. Does the last release ( N20050407 ) has already support for
JFace?
The code generated for a swt composite has the following:
// TODO Auto-generated method stub
/* Before this is run, be sure to set up the following in the launch
configuration
* (Arguments->VM Arguments) for the correct SWT library path.
* The following is a windows example:
* -Djava.library.path="installation_directory\plugins\org.eclipse.swt.win32_
3.0.0\os\win32\x86"
It looks that the swt plugin are deployed as a jar, and the comments says
about the directory plugin, so I think one would have to change those
comments.
I had to extract the dll's by hand and point the VM arg to there.
Emerson
FUDForum. Page generated in 1.02621 seconds
