Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Issue with JPA Annotations
Issue with JPA Annotations [message #86214] Wed, 13 June 2007 11:29 Go to next message
I am trying to capture JPA annotations in EMF editor (Soyatec) , generate
a code and then use Teneo to generate HBM file. It seems annotations are
not reflected in HBM file.
ecore annotation looks like :
<eClassifiers xsi:type="ecore:EClass" name="EQUser"
eSuperTypes="#//EQGlobalDomainObject">
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@Entity(name=t_eq_user)"/>
<details key="value" value="@Table(name=t_eq_user)"/>
</eAnnotations>
generated code has following comments :
@model annotation="teneo.jpa appinfo='@Entity(name=t_eq_user)'
value='@Table(name=t_eq_user)'"
@generated
But hibernate file doesnt have new table name :
<joined-subclass name="com.company.eqfc.model.orgdata.impl.EQUserImpl"
entity-name="EQUser" abstract="false" lazy="false"
extends="EQGlobalDomainObject" table="`equser`">
Can you pls help ?
Also how can we add multiple annotations through EMF editor ? it doesnt
allow multiple properties with 'appinfo' name ?
Re: Issue with JPA Annotations [message #86259 is a reply to message #86214] Wed, 13 June 2007 14:28 Go to previous messageGo to next message
Can you check if the annotations are present in the generated EPackageImpl java class?
If they are then maybe it is best that I try your ecore. If not then the problem is in the java
packageimpl generation.
When I edit the ecore model in the emf ecore editor then the Property view shows a value field when
I click on the button on the right then a multi-line text editor opens in which I can enter multiple
lines with annotations.
gr. Martin
> generate a code and then use Teneo to generate HBM file. It seems
> annotations are not reflected in HBM file.
> </eAnnotations>
> @generated
> Can you pls help ?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Issue with JPA Annotations [message #86304 is a reply to message #86259] Wed, 13 June 2007 14:58 Go to previous messageGo to next message
I do see annotations in the Epackageimpl. Here is the method in the
package impl :
protected void createTeneoAnnotations() {
String source = "teneo.jpa";
addAnnotation
(jpaTableEClass,
source,
new String[] {
"appinfo", "@Entity(name=t_jpatable)"
Here is the Ecore file :
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="jpatest"
nsURI="http://com.jpmorgan.jpatest" nsPrefix="com.jpmorgan.jpatest">
<eClassifiers xsi:type="ecore:EClass" name="JPATable">
<details key="appinfo" value="@Entity(name=t_jpatable)"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
Here is the HBM file generated from above ecore file :
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD
3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<!-- Generated by Teneo on Wed Jun 13 12:32:01 EDT 2007 -->
<hibernate-mapping>
<class name="org.eclipse.emf.ecore.impl.DynamicEObjectImpl"
entity-name="JPATable" abstract="false" lazy="false" table="`jpatable`">
based on the annotation, table name in this case should be t_jpatable.
Appreciate your help.
Re: Issue with JPA Annotations [message #86347 is a reply to message #86304] Wed, 13 June 2007 16:23 Go to previous messageGo to next message
Here is the ecore which creates a table with the name test_jpatable. The name of the entity is not
picked up, this is a bug. The table annotation works.
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
<details key="appinfo" value="@Entity(name=&quot;t_jpatable&quot;)
&#xA;@Table(name=&quot;test_jpatable&quot;)"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType
</eClassifiers>
</ecore:EPackage>
gr. Martin
> package impl :
> addAnnotation
> (jpaTableEClass, source, new String[] {
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> <hibernate-mapping>
The Netherlands
Re: Issue with JPA Annotations [message #86359 is a reply to message #86347] Wed, 13 June 2007 16:59 Go to previous messageGo to next message
Martin
Thx for quick response.
Unfortunately its still not working for me. Not sure if there is something
wrong with my setup. This is what I did during retest :
1:- Edited ecore file and made changes as suggested by you.
i.e. <details key="appinfo"
value=" @Entity(name=&quot;t_jpatable&quot;)&#xA;@Table( name=&quot;test_jpatable&quot;) "/>
2. Reloaded this ecore in genmodel and generated code. Above change is
reflected in JpatestPackageImpl
addAnnotation
(jpaTableEClass,
source,
new String[] {
"appinfo",
"@Entity(name=\"t_jpatable\")\n@Table(name=\"test_jpatable\")"
3. Right clicked on jpatest.ecore file and then ran Teneo -> Generate EMF
- Hibernate O/R Mapping
4. Hibernate mapping file is generated which doesnt have above table name.
<class name="com.jpmorgan.jpatest.impl.JPATableImpl"
I am using Teneo 0.8.0.
Any clue ??
Re: Issue with JPA Annotations [message #86372 is a reply to message #86359] Wed, 13 June 2007 17:08 Go to previous messageGo to next message
Okay, if you right click on the ecore file to create the hbm file then you don't need to re-generate
the java code, only if you use the hbdatastore without a hbm file then this is required.
Can you post the exact ecore you use or send me it by email?
gr. Martin
> Martin
> something wrong with my setup. This is what I did during retest :
> addAnnotation
> "appinfo",
> EMF - Hibernate O/R Mapping
> Any clue ??
The Netherlands
Re: Issue with JPA Annotations [message #86387 is a reply to message #86372] Wed, 13 June 2007 17:35 Go to previous messageGo to next message
Here is the complete ecore file :
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: Issue with JPA Annotations [message #86401 is a reply to message #86387] Wed, 13 June 2007 19:02 Go to previous messageGo to next message
This works for me but for testing I do not use the right click but use the HbDataStore (and then
call getMappingXML). Although the underlying code for the right-click menu option is the same as the
one used in the HbDataStore.
Can you try programmatically (initialize a hbdatastore)?
Here is the hbm I get:
<!-- Generated by Teneo on Thu Jun 14 01:01:21 CEST 2007 -->
<hibernate-mapping>
<class name="org.eclipse.emf.ecore.impl.DynamicEObjectImpl" entity-name="JPATable" abstract="false"
lazy="false" discriminator-value="t_jpatable" table="`test_jpatable`">
<meta attribute="eclassName">JPATable</meta>
<meta attribute="epackage">http://com.jpmorgan.jpatest</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="name" lazy="false" insert="true" update="true" not-null="false" unique="false"
type="java.lang.String">
<column not-null="false" unique="false" name="`name`"/>
</property>
</class>
</hibernate-mapping>
gr. Martin
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
The Netherlands
Re: Issue with JPA Annotations [message #86417 is a reply to message #86401] Wed, 13 June 2007 21:41 Go to previous message
Martin
This works. That means there is some difference between the way hbm file
is generated from Epackage or Ecore. Epackage works as annotations are
added to Eclass. In case of Ecore I think it fails to interpret
eAnnotations from XML file.
One question. Can HbDataStore be initialized based on ecore ? If yes then
we can try to see if that works.
Many thanks for your quick help. Also let me know when next version of
Teneo will be available.
Re: Issue with JPA Annotations [message #606950 is a reply to message #86214] Wed, 13 June 2007 14:28 Go to previous message
gr. Martin
> </eAnnotations>
> @generated
> Can you pls help ?
The Netherlands
Re: Issue with JPA Annotations [message #606956 is a reply to message #86259] Wed, 13 June 2007 14:58 Go to previous message
package impl :
addAnnotation
(jpaTableEClass,
source,
new String[] {
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
<hibernate-mapping>
Re: Issue with JPA Annotations [message #606966 is a reply to message #86304] Wed, 13 June 2007 16:23 Go to previous message
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
gr. Martin
> package impl :
> addAnnotation
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> <hibernate-mapping>
The Netherlands
Re: Issue with JPA Annotations [message #606969 is a reply to message #86347] Wed, 13 June 2007 16:59 Go to previous message
Martin
addAnnotation
(jpaTableEClass,
source,
new String[] {
"appinfo",
Any clue ??
Re: Issue with JPA Annotations [message #606971 is a reply to message #86359] Wed, 13 June 2007 17:08 Go to previous message
gr. Martin
> Martin
> addAnnotation
> "appinfo",
> Any clue ??
The Netherlands
Re: Issue with JPA Annotations [message #606973 is a reply to message #86372] Wed, 13 June 2007 17:35 Go to previous message
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: Issue with JPA Annotations [message #606975 is a reply to message #86387] Wed, 13 June 2007 19:02 Go to previous message
<hibernate-mapping>
</id>
</version>
</property>
</class>
gr. Martin
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
The Netherlands
Re: Issue with JPA Annotations [message #606977 is a reply to message #86401] Wed, 13 June 2007 21:41 Go to previous message
Martin
Previous Topic:[teneo] primary key in java code
Next Topic:[Teneo / JPOX] Generate EMF JDO/JPOX OR Mapping
Current Time: Sun Jul 20 08:31:05 EDT 2025
Powered by FUDForum. Page generated in 1.07080 seconds
