Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build with p2.gathering and root files fails.
PDE Build with p2.gathering and root files fails. [message #549120] Sat, 24 July 2010 16:18 Go to next message
I'm having a problem here shipping the JRE with our product package
using the root-properties.
I have a working PDE build for our product, including the generation
of p2 metadata using the p2.gathering=true switch. Now as soon as I add
the
root.linux.gtk.x86.folder.jre=absolute:/path/to/jre
line to the build.properties of the main feature project for this product
the build fails during the p2 director execution. And I can't quite
understand what the problem is or how to solve it:
[echo] !ENTRY org.eclipse.equinox.p2.director 4 1 2010-07-24
17:48:47.314
[echo] !MESSAGE Cannot complete the install because of a conflicting
dependency.
[echo] !SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2010-07-24
17:48:47.315
[echo] !MESSAGE Software being installed: MyIDE 4.1.0-SNAPSHOT 4.1.0.27
(ide.product 4.1.0.27)
[echo] !SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-07-24
17:48:47.316
[echo] !MESSAGE Only one of the following can be installed at once:
[echo] !SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-07-24
17:48:47.317
[echo] !MESSAGE ide.product_root.gtk.linux.x86 1.1.0.27
17:48:47.318
[echo] !MESSAGE ide.product_root.gtk.linux.x86 4.1.0.27
17:48:47.318
[echo] !MESSAGE Cannot satisfy dependency:
17:48:47.319
[echo] !MESSAGE From: MyIDE 4.1.0-SNAPSHOT 4.1.0.27 (ide.product
4.1.0.27)
17:48:47.320
[echo] !MESSAGE To: ide.product.feature.group [1.1.0.27]
17:48:47.321
17:48:47.322
4.1.0.27)
17:48:47.324
[echo] !MESSAGE To: ide.product_root.gtk.linux.x86 [4.1.0.27]
17:48:47.324
17:48:47.325
[echo] !MESSAGE From: MyIDE Product 1.1.0.27 (ide.product.feature.group
1.1.0.27)
17:48:47.325
[echo] !MESSAGE To: ide.product_root.gtk.linux.x86 [1.1.0.27]
Re: PDE Build with p2.gathering and root files fails. [message #551039 is a reply to message #549120] Wed, 04 August 2010 18:47 Go to previous messageGo to next message
Andreas Pakulat wrote:
> the
It turns out the root-files just triggered an error elsewhere in my rcp
build. I had the .product file and a feature use the same id, which is
apparently not a very wise idea. So after using a different id in the
product file the build with rootfiles works fine now.
Andreas
Re: PDE Build with p2.gathering and root files fails. [message #606428 is a reply to message #549120] Wed, 04 August 2010 18:47 Go to previous messageGo to next message
> the
Andreas
Re: PDE Build with p2.gathering and root files fails. [message #658297 is a reply to message #551039] Mon, 07 March 2011 12:45 Go to previous message
The following error message is very strange, and pretty hard to get to the
root cause. :(
Error message (excerpt):
Cannot complete the install because of a conflicting dependency.
I've spend a couple of hours to see what was wrong.
As Andreas already highlighted, one should double check if *.product id !=
plugin's symbolic name - in which the *.product resides.
IMO, one should better leave the *.product ID empty.
Note: I didn't used root files while I've been facing this issue.
Jtonic.
>> Hi,
>> the
> Andreas
Respect
jtonic
Previous Topic:Is it possible to mirror a deltapack and refer to it (as update site) in a *.target definition?
Next Topic:Including Root Files in a Product Build
Current Time: Sat Jul 19 15:30:53 EDT 2025
Powered by FUDForum. Page generated in 0.03858 seconds
