Home » Eclipse Projects » Plugin Development Environment (PDE) » Developing plugins with library dependency
Developing plugins with library dependency [message #606335] Tue, 27 July 2010 07:57 Go to next message
Hi *,
I have following scenario:
We are developing a JEE application with an RCP client application. The RCP plugin uses a business delegate library to communicate with the server, to cache some data and to do some other fancy things. This business delegate library is not an Eclipse plugin but the Eclipse plugin depend on this business delegate.
In the development environment the Eclipse Workbench consists of a Plugin project 'rcp.client' for the RCP plugin and a plain Java Project 'business_delegate' for the business delegate. Unfortunately I have not found any way to tell Eclipse that it should bundle the business delegate as a library in the plugin. Currently I am exporting the business delegate as a jar to a lib directory in the 'rcp.client' using the Eclipse Export functionality.
This is sad since whenever I want to start my RCP application from within Eclipse I have to export the business delegate.
Is there any way to tell Eclipse that the 'rcp.client' project depends on the 'business_delegate' project and that it should include it?
Thomas
Re: Developing plugins with library dependency [message #606343 is a reply to message #606335] Tue, 27 July 2010 16:57 Go to previous message
Convert the business_delegate project a plugin project that has the jar file
on its runtime classpath.
In the business_delegate project, export the packages that need to be used
by the rcp.client project.
In the rcp.client project import the required packages.
I assume you are using a feature to build the application, so the
business_delegate plugin needs to be added to the feature so it is included
in the exported application.
Namaste, Bruce
Previous Topic:product export with qualifier replacement
Next Topic:Plugin with multiple files
Current Time: Sat Jul 19 15:41:36 EDT 2025
Powered by FUDForum. Page generated in 0.08559 seconds
