Home » Eclipse Projects » Plugin Development Environment (PDE) » headless pde build : InvocationTargetException in generated build.xml
headless pde build : InvocationTargetException in generated build.xml [message #606279] Mon, 19 July 2010 10:06
I am trying to set up a headless build of my product and it works for
the first few plugins (everything gets compiled, I have the classfiles
in the @dot directory), but then at some point I get
path/to/generated/buildxml/of/pluginxy/build.xml:251:
I marked line 251 in the generated script below with a leading 251:
<pathelement
path=" ../../../target/plugins/org.eclipse.xtext.ui_1.0.0.v20100616 1118.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.ecore.edit_2.6.0.v20 100614-1136.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.edit_2.6.0.v20100614 -1136.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.ecore.change_2.5.0.v 20100521-1846.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.edit.ui_2.6.0.v20100 614-1136.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.emf.common.ui_2.6.0.v201 00614-1136.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.xtext.ui.shared_1.0.0.v2 01006161118.jar "/>
<pathelement
path=" ../../../target/plugins/org.eclipse.xtext.builder_1.0.0.v201 006161118.jar "/>
</path>
<!-- compile the source code -->
251: <javac destdir="${build.result.folder}/@dot"
failonerror="${javacFailOnError}" verbose="${javacVerbose}"
debug="${javacDebugInfo}" includeAntRuntime="no"
bootclasspath="${bundleBootClasspath}" source="${bundleJavacSource}"
target="${bundleJavacTarget}" errorProperty="compilation.error.occured"
<compilerarg line="${compilerArg}"
compiler="${build.compiler}"/>
<classpath refid="@dot.classpath" />
<src path="src/" />
<src path="src-gen/" />
<compilerarg
value="@${basedir}/javaCompiler...args"
compiler="org.eclipse.jdt.core.JDTCompilerAdapter" />
<compilerarg line="-log
&apos;${build.result.folder}/@dot${logExtension}&apo s; "
</javac>
<antcall target="checkCompilationResults"/>
<!-- Copy necessary resources -->
<copy todir="${build.result.folder}/@dot"
failonerror="true" overwrite="false">
<fileset dir="src/">
<exclude name="**/*.java"/>
<exclude name="**/package.htm*"/>
</fileset>
<fileset dir="src-gen/">
</fileset>
</copy>
</target>
the target's name is @dot
I have no clue how to debug this. Any help would be highly appreciated!
Tobi
Previous Topic:Cheat sheets and localization
Next Topic:headless pde build : InvocationTargetException in generated build.xml
Current Time: Sat Jul 19 13:46:55 EDT 2025
Powered by FUDForum. Page generated in 0.04336 seconds
