Trouble creating an SWT application visual class with 3.1 M6 [message #606222] |
Sat, 02 April 2005 16:54 |
I just downloaded 3.1M6 and, using the update manager, installed VE. I
guess my first question is should it work? I was able to create a Swing
visual class and that worked fine.
When I tried to craete an SWT application I recived an error saying
"Creation of element failed. See error log for more details." Attached
is the error log entry.
Ian
!ENTRY org.eclipse.jdt.ui 4 10001 2005-04-02 16:47:26.562
!MESSAGE Internal Error
!STACK 0
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
at
org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish(NewElementWizard.java:130)
at
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.performFinish(NewVisualClassCreationWizard.jav a:407)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
at
org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspa th(JavaProject.java:2050)
at
org.eclipse.jdt.internal.core.ClasspathEntry.validateClasspa th(ClasspathEntry.java:1101)
at
org.eclipse.jdt.internal.core.SetClasspathOperation.verify(S etClasspathOperation.java:820)
at
org.eclipse.jdt.internal.core.JavaModelOperation.runOperatio n(JavaModelOperation.java:760)
at
org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(Ja vaProject.java:2739)
at
org.eclipse.jdt.internal.core.JavaProject.setRawClasspath(Ja vaProject.java:2755)
at
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.verifyProjectClassPath(NewVisualClassCreationW izard.java:345)
at
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.finishPage(NewVisualClassCreationWizard.java:3 06)
at
org.eclipse.jdt.internal.ui.wizards.NewElementWizard$2.run(N ewElementWizard.java:114)
at
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:34)
at
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:710)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1714)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:3665)
at
org.eclipse.jdt.internal.ui.actions.WorkbenchRunnableAdapter .run(WorkbenchRunnableAdapter.java:87)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
FUDForum. Page generated in 0.03435 seconds
