Home » Eclipse Projects » Plugin Development Environment (PDE) » How to use multiple p2 repos in a pdebuild?
How to use multiple p2 repos in a pdebuild? [message #538915] Wed, 09 June 2010 01:39 Go to next message
Originally posted by: wbeckwith.gmail.com
My situation is that I have a target composed of the eclipse RCP runtime
+ the delta pack and another directory of 3rd party dependencies. We
can add the dependencies directory to the pluginPath variable and all
will compile down fine. However, when the ant task p2.mirror executes,
it only sees the repo at the target. The dependencies repo is not taken
into context.
I figure there might be ant properties that maybe go into the builder's
build.properties file that may instruct the build file generation to
create another <source> element that points to the 2nd dependencies
repo. If there is, or there is a better of structure this outside of
dumping everything into the same directory, please let me know.
Wb
Re: How to use multiple p2 repos in a pdebuild? [message #539083 is a reply to message #538915] Wed, 09 June 2010 11:17 Go to previous messageGo to next message
You want "p2.context.repos" which should be a comma separated list of URIs.
Somewhat related are:
"repoBaseLocation" - a folder containing other repositories in zips or
subfolders. These repositories will be transformed using repo2runnable.
"transformedRepoLocation" - the location of the repository where the
results of the repoBaseLocation transformation should go.
"transformedRepoLocation" is automatically added to the list of context
repositories with p2.context.repos.
-Andrew
> into context.
> Wb
Re: How to use multiple p2 repos in a pdebuild? [message #539230 is a reply to message #539083] Thu, 10 June 2010 02:06 Go to previous messageGo to next message
That was what I needed. Now p2.mirror can see the dependencies repo.
One final (ATM) question, but the mirror process seems to resolved all
bundles into the product install. There are some bundles I need in my
target platform for compilation which are provided via Import-Package
but we can't ship the actual bundles themselves. How do I keep these
guys from being included?
Wb
> -Andrew
>> into context.
>> create another<source> element that points to the 2nd dependencies
>> Wb
Re: How to use multiple p2 repos in a pdebuild? [message #539677 is a reply to message #539230] Fri, 11 June 2010 16:04 Go to previous message
This seems to be related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=313334
The only thing I can think of there is to make those dependencies optional
and then have a fix for this bug.
-Andrew
Re: How to use multiple p2 repos in a pdebuild? [message #605962 is a reply to message #538915] Wed, 09 June 2010 11:17 Go to previous message
-Andrew
> into context.
> Wb
Re: How to use multiple p2 repos in a pdebuild? [message #605973 is a reply to message #539083] Thu, 10 June 2010 02:06 Go to previous message
Wb
> -Andrew
>> into context.
>> Wb
Re: How to use multiple p2 repos in a pdebuild? [message #605997 is a reply to message #539230] Fri, 11 June 2010 16:04 Go to previous message
-Andrew
Previous Topic:Add onSave action to editor
Next Topic:p2-enabled PDE build fails when p2.category.definition is set (seemingly valid categories.xml file)
Current Time: Sat Jul 19 20:11:02 EDT 2025
Powered by FUDForum. Page generated in 0.05142 seconds
