Home » Eclipse Projects » Plugin Development Environment (PDE) » Help required with IMarker Line numbers
Help required with IMarker Line numbers [message #604876] Wed, 03 March 2010 19:51 Go to next message
Hello friends,
I am creating custom markers in the editor from an eclipse plug-in. I am currently creating the markers using file.createMarker(MARKER_TYPE) and setting other attributes like line number, severity and message.
Once the user does some edits in the editor (For example, pressing enter in the lines before the marker is present), the custom marker line number changes.
Is there a way I can track those changes? I thought I can use MarkerUtilities.getLineNumber(marker) but once the execution is reaching this line, it is jumping out of the method without printing out any error. The same happened with any other methods of MarkerUtilities.
Please suggest on this.
Thanks.
Re: Help required with IMarker Line numbers [message #604907 is a reply to message #604876] Sat, 06 March 2010 05:53 Go to previous message
On 3/4/2010 6:21 AM, bhagvanram@gmail.com wrote:
> Hello friends,
> number changes.
> Thanks.
A better way would be to handle this using IModelChangedListener. If you notice the problem markers,
their line numbers too are updated on Save.
hth,
Ankur..
Eclipse PDE UI Committer | IBM India Software Lab, Bangalore
+91-99456-94011 | @ankur_sharma | http://blog.ankursharma.org
Previous Topic:Help required with IMarker Line numbers
Next Topic:properties view
Current Time: Sat Jul 19 10:56:16 EDT 2025
Powered by FUDForum. Page generated in 1.09742 seconds
