Home » Eclipse Projects » Plugin Development Environment (PDE) » Disable save for launchConfiguration.launch?
Disable save for launchConfiguration.launch? [message #604772] Mon, 22 February 2010 14:58 Go to next message
We have a set of external java processes that we call using the launch configuration framework.
When calling launchConfiguration.launch, it seems to prompt to save all dirty editors in the workspace, which is expected behavior but i would like to disable this for some processes. Is there an easy way to do this?
It looks like there is a JavaLaunchDelegate which extends AbstractJavaLaunchDelegate which exends LaunchConfigurationDelegate.
LaunchConfigurationDelegate has a method named preLaunchCheck which then saves all dirty editors.
I've looked around and there does not seem a simple way to disable then other then to inherit from the ILaunchDelegate and ILaunchConfigurationDelegate to override the one method.
Is there any simple way to do this?
Any help is appreciated.
Re: Disable save for launchConfiguration.launch? [message #604774 is a reply to message #604772] Mon, 22 February 2010 21:13 Go to previous message
Well it seems i answered my own question. I can create an 'org.eclipse...launchDelegate' extension point, specify the run modes (run, debug) and the class which is the LaunchConfigurationDelegate.
I created an object called CLaunchConfigurationDelegate which this extension point references, inherited from JavaLaunchDelegate and overrided the method that performs the save to do nothing when i start my processes using the launch configuration framework.
I hope this helps someone who has a similar question!
Previous Topic:Disable save for launchConfiguration.launch?
Next Topic:Version handling plugin
Current Time: Sun Jul 20 09:29:32 EDT 2025
Powered by FUDForum. Page generated in 0.05340 seconds
