Home » Eclipse Projects » Plugin Development Environment (PDE) » Including source code in site build from UI (PDE configuration parameters)
icon5.gif  Including source code in site build from UI [message #513706] Wed, 10 February 2010 17:00 Go to next message
I have an update site definition that contains a feature, which contains plugins. - Quite unspectacular. I would like to bundle the source code with the plugins and I do not want to use the PDEbuild command line mechanism.
I can do this for the feature by clicking 'export' and then setting the corresponding option to export the source.
When I build the site by clicking build all, I do not have that option.
QUESTION: Where and how can I include data in the feature definition, so that the site build picks up the source code production command. Or is it impossible?
I believe this must be a fairly common case, as any library that is reused in a plugin can potentially break and then leave the re-user/contributor with no idea what is going on...
Re: Including source code in site build from UI [message #513765 is a reply to message #513706] Thu, 11 February 2010 02:59 Go to previous messageGo to next message
Hello Joerr,
Been there, and quite a coincidence that I have just written an article [1]
on it.
You may as well check out my project as a sample. [2]
[1] http://blog.batoo.org/?p=54
[2] http://emf-ebm.svn.sourceforge.net/svnroot/emf-ebm/update/
> mechanism.
> impossible?
Hasan Ceylan
hceylan@batoo.org
+90 (532) 713-5384
+90 (216) 332-5647
"He who controls the present, controls the past. He who controls the past,
controls the future.", George Orwell
icon14.gif  Re: Including source code in site build from UI [message #513805 is a reply to message #513765] Thu, 11 February 2010 06:24 Go to previous message
Cool Fantastic! Kotaus and all the power of Java to you!
P.S.: My project is packaging SableCC
Re: Including source code in site build from UI [message #604641 is a reply to message #513765] Thu, 11 February 2010 06:24 Go to previous message
8) Fantastic! Kotaus and all the power of Java to you!
Previous Topic:Problem exporting a product
Next Topic:NPE non-deterministic build
Current Time: Sat Jul 19 07:55:06 EDT 2025
Powered by FUDForum. Page generated in 0.04655 seconds
