Home » Archived » XML Schema Definition (XSD) » key/keyref does not validate with recursion?
key/keyref does not validate with recursion? [message #604354] Thu, 10 September 2009 11:22
Hi everyone,
Is it true that key/keyref does not validate with recursion? I have this
question because that when I validate the following xml file, the
validation of an element defined with recursion doesn't work. Following is
xml and the corresponding xsd file. Thanks in advance!
Toan.
xsd file :
<?xml version="1.0" encoding="ISO-8859-1"?>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:element name="CompositeType" type="CompositeType" />
<xsd:element name="Model" type="Model">
<!-- CompositeTypeKey/KeyRef -->
<xsd:key name="CompositeTypeKey">
<xsd:selector
xpath=".//CompositeType" />
<xsd:field xpath="./typeName" />
</xsd:key>
<xsd:keyref name="CompositeTypeRef" refer="CompositeTypeKey">
<xsd:selector
xpath=".//Attribute/CompositeTypeReference" />
<xsd:field xpath="." />
</xsd:keyref>
</xsd:element>
<xsd:complexType name="CompositeType">
<xsd:sequence>
<xsd:element minOccurs="0" name="typeName"
type="xsd:string" />
<xsd:element maxOccurs="unbounded" minOccurs="0"
name="Attribute" type="Attribute" />
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Attribute">
<xsd:sequence>
<xsd:element minOccurs="0" name="name" type="xsd:string" />
<xsd:choice minOccurs="1">
<xsd:element minOccurs="1" maxOccurs="1"
name="CompositeTypeReference" type="xsd:string" />
</xsd:choice>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Model">
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
xml file :
<?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>
<Model xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="test.xsd" >
<CompositeType>
<typeName>Bozo</typeName>
</CompositeType>
<CompositeType>
<typeName>MyData</typeName>
<Attribute>
<name>b</name>
<CompositeTypeReference>Bozo</CompositeTypeReference>
</Attribute>
<Attribute>
<name>d</name>
<CompositeType>
<typeName>CustomData</typeName>
</CompositeType>
</Attribute>
<Attribute>
<name>n</name>
<CompositeType>
<typeName>NewData</typeName>
<Attribute>
<name>m</name>
<CompositeTypeReference>My</CompositeTypeReference>
</Attribute>
<Attribute>
<name>c</name>
<CompositeTypeReference>Custom</CompositeTypeReference>
</Attribute>
</CompositeType>
</Attribute>
</CompositeType>
</Model>
Notice that when validate if the validation of recursion works, there will
be two errors at :
because the right references are :
<CompositeTypeReference>MyData</CompositeTypeReference>
<CompositeTypeReference>CustomData</CompositeTypeReference >
Previous Topic:Parse XSD from the WTP plugins.
Next Topic:key/keyref does not validate with recursion?
Current Time: Sat Jul 19 22:01:56 EDT 2025
Powered by FUDForum. Page generated in 0.23763 seconds
