Home » Eclipse Projects » Plugin Development Environment (PDE) » Build Path Incomplete
Build Path Incomplete [message #604148] Thu, 14 January 2010 06:34 Go to next message
this is propably a newbish question/problem:
I'm trying to compile the source of http://relo.csail.mit.edu/developers.html
I managed to reduce the number of errors in the checked out project from 100 to 2 by adding the required referenced librarys from the GEF.
The remaining errors are:
The project was not build since its build path is incomplete. Cannot find the class file for org.eclipse.core.runtime.Plugin. Fix the build path then try building this project.
The type org.eclipse.core.runtime.Plugin cannot be resolved. it is indirectly referenced from requred .class files.
I do not completely understand how I can complete the Build Path, as it already includes the org.eclipse.runtime_3.5.0.20090525.jar which contains the Plugin.class
But I'm a virgin wrt Eclipse and plug-in programming, so maybe I'm missing something basic or obvious here.
Thanks for any thoughts.
Re: Build Path Incomplete [message #604214 is a reply to message #604148] Sat, 16 January 2010 21:29 Go to previous messageGo to next message
The Relo codebase has had a new home for the last 2+ years. See
www.architexa.com - it is in private beta, but we are beginning to let
users in.
Vineet
eclipseuser@mailinator.com wrote:
> Hello,
Re: Build Path Incomplete [message #604219 is a reply to message #604148] Sat, 16 January 2010 21:52 Go to previous messageGo to next message
The Relo codebase has had a ew home for the last 2+ years. See www.architexa.com - it is in prviate beta, but we are beginning to let users in.
Vineet
Re: Build Path Incomplete [message #604235 is a reply to message #604219] Mon, 18 January 2010 07:09 Go to previous message
Well thanks for the pointer, but that does not really help me in building the project. You're now working with a closed source I guess.
I'd like to build upon Relo's functionality for a Diploma Thesis of my own and it would be great not to reimplement all the class/method-extraction stuff.
Chris
Previous Topic:Build Path Incomplete
Next Topic:Error highlighting without Markers
Current Time: Sun Jul 20 08:38:46 EDT 2025
Powered by FUDForum. Page generated in 0.23839 seconds
