Cheat sheets in modal dialogs [message #603628] |
Fri, 27 November 2009 03:56  |
Hi all,
I have found some documentation about showing the help section on the right side of a dialog. My issue is about using cheat sheets. When the user follow a cheat sheet, if the action requires to open a modal dialog or wizard, he cannot go on following the cheat sheet. Is there a way to have it opened in the right side of the dialog?
Thank you
Enrico
Re: Cheat sheets in modal dialogs [message #603633 is a reply to message #603628] |
Fri, 27 November 2009 04:24  |
Enrico Daga wrote:
> Hi all,
> Thank you
> Enrico
You may associate the command to open the dialog with that step. When the user clicks that "green
arrow" action button, the cheat sheet automatically gets attached to the dialog.
For example, take a look at "Creating an Eclipse plug-in" cheat sheet. Sub-Step 2 of the step
"Configure PDE".
hth,
Ankur..
Eclipse PDE UI Committer | IBM India Software Lab, Bangalore
+91-99456-94011 | @ankur_sharma | http://blog.ankursharma.org
FUDForum. Page generated in 0.43105 seconds
