Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE build/test problem
PDE build/test problem [message #603503] Mon, 23 November 2009 05:27 Go to next message
Hello all,
I am having a strange problem with my PDE build (Eclipse 3.5).
I am building some (extension location, no p2) features containing plugins/test plugins. After the build I am trying to run some tests using the eclipse test framework.
The bad thing is that the test plugins are not found. The following message is appearing all the time:
org.eclipse.test.EclipseTestRunner$TestFailedException: java.lang.Exception: Could not find plugin "..."
When I run the target eclipse manually the test plugins can also not be found (cannot be found at all in view plug-in registry).
But now comes the strange thing: The plugins are there, they are all located in the "plugins" folder.
I tried the following things but none of them helped:
- clean the configuration (cmd line switch -clean)
- remove all the features and just start using the plugins
Does anybody had a similar problem or has some ideas on this?
Thank you
Re: PDE build/test problem [message #603510 is a reply to message #603503] Mon, 23 November 2009 05:58 Go to previous message
Hello Marko,
Are you sure your test plugins dependencies are resolved? Maybe you are missing org.junit or another dependency so that your test plugin cannot be loaded...
HTH
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Previous Topic:Hooking into IWorkbenchPage.closeEditors
Next Topic:PDE build/test problem
Current Time: Sat Jul 19 15:21:33 EDT 2025
Powered by FUDForum. Page generated in 0.55613 seconds
