Home » Archived » Visual Editor (VE) » No SWT
No SWT [message #71589] Fri, 12 November 2004 13:51 Go to next message
Originally posted by: asifna.gmail.com
Just installed VE and on the palette there is no support for SWT. Is there
some configuration parameter I need to set?
Cheers
Asif
Re: No SWT [message #71605 is a reply to message #71589] Fri, 12 November 2004 14:15 Go to previous messageGo to next message
Managed to get the SWT palette to display, but now when I try to add a
component to an SWT composite I get a NoSuchMethod error. On the composite
itself I get a warning saying 'Widget is disposed".
Any ideas?
Cheers
Asif
> Cheers
> Asif
Re: No SWT [message #71623 is a reply to message #71589] Fri, 12 November 2004 14:20 Go to previous messageGo to next message
Managed to view SWT on the palette, but now I'm getting a 'Widget is
disposed' on an SWT composite, and if I try to add a SWT button, a "No
such method error".
Any ideas?
Cheers
Asif
> Cheers
> Asif
Re: No SWT [message #71642 is a reply to message #71623] Fri, 12 November 2004 15:53 Go to previous message
Do you use jdk1.4.1?
VE needs 1.4.2 because of a java-beans problem in 1.4.1.
bye, feri
"Asif" <asifna@gmail.com> schrieb im Newsbeitrag
news:cn32dh$q98$1@eclipse.org...
> such method error".
> Any ideas?
> Cheers
> Asif
>> there some configuration parameter I need to set?
>> Cheers
>> Asif
Re: No SWT [message #603045 is a reply to message #71589] Fri, 12 November 2004 14:15 Go to previous message
Any ideas?
Cheers
Asif
> Cheers
> Asif
Re: No SWT [message #603051 is a reply to message #71589] Fri, 12 November 2004 14:20 Go to previous message
such method error".
Any ideas?
Cheers
Asif
> Cheers
> Asif
Re: No SWT [message #603053 is a reply to message #71623] Fri, 12 November 2004 15:53 Go to previous message
bye, feri
> such method error".
> Any ideas?
> Cheers
> Asif
>> Cheers
>> Asif
Previous Topic:No SWT
Next Topic:New -> Visual Class fails under Mac OS X
Current Time: Sun Jul 20 18:32:05 EDT 2025
Powered by FUDForum. Page generated in 0.04690 seconds
