Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Possible to Override Generation of hibernate.hbm.xml?
[Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #72941] |
Tue, 27 February 2007 11:15  |
Originally posted by: bsu.bergauer.ch
I have some problems getting in control of the id and version columns in my
project. I need to have those attributes both in the ecore and in my model
interface (non synthetic), in the EMF-Editor, however, they are not visible.
I tried to set persistency annotations in the model interfaces with little
success:
FOR THE ID COLUMN:
* @model id="true" required="true"
* @generated
@Id @GeneratedValue(strategy=GenerationType.AUTO)
int getId();
* @generated
void setId(int value);
RESULT: org.hibernate.id.IdentifierGenerationException: ids for this class
must be manually assigned before calling save()
(I notice that the generated PK `id` is auto_increment in
MySql)
FOR THE VERSION COLUMN:
* @model required="true"
* @generated
@Version
int getVersion();
* @generated
void setVersion(int value);
RESULT: org.hibernate.MappingException: Duplicate property mapping of
version found
As I will have quite some tables in my model I'm not so keen in modifying
all generated model interfaces in order to add any annotations. What I
rather would like is to utilize the Teneo utility and so generate EMF -
Hibernate OR mapping direct from the ecore file. In order to do that I have
added persistenceProperties.setProperty(PersistenceOptions.USE_MAP PING_FILE,
"true"); to the persistency property in the EditorPlugin. The generated
hibernate.hbm.xml has anyway to be modified in the following way:
GENERATED:
<id name="id" type="int">
<column not-null="true" unique="false" name="`id`"/>
</id>
MODIFIED:
<id name="id" type="int" column="id" unsaved-value="0">
<generator class="identity"/>
</id>
GENERATED:
<version name="version" column="version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHand
ler">
<meta attribute="syntheticVersion">true</meta>
</version>
MODIFIED:
ler"/>
With the above modifications my EMF-Editor is working and I have no problems
persisting the model objects to the database. Ids are generated and version
is incremented.
My question is if one somehow can override the mappings being generated in
order to achieve above modified id- and version-elements?
Bj
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #72985 is a reply to message #72941] |
Tue, 27 February 2007 12:06   |
Hi Björn,
In Teneo annotations are not specified in the java code but in the model (ecore or xsd) or in a
separate xml.
So the @Id and @GeneratedValue(strategy=GenerationType.AUTO) annotations should be specified there.
If your id attributes all use an EDataType defined by yourselve then you can add the annotations to
the EDataType (so one place instead of at each attribute).
See also here:
http://www.elver.org/hibernate/ejb3_format.html
http://www.elver.org/hibernate/ejb3_examples.html
gr. Martin
Björn Sundin wrote:
> success:
> FOR THE ID COLUMN:
> * @generated
> int getId();
> * @generated
> MySql)
> * @generated
> @Version
> int getVersion();
> * @generated
> version found
> GENERATED:
> </id>
> MODIFIED:
> </id>
> GENERATED:
> ler">
> </version>
> MODIFIED:
> ler"/>
> is incremented.
> Björn
> PS. Versions used and settings:
> - Eclipse IDE 3.2.1
> - EMF 2.2.2
> - Teneo 0.7.5 Maintenance Build
> - Hibernate 3.2
> - MySql and/or Derby embedded
> - Persistence properties set in the EditorPlugin:
> persistenceProperties.setProperty(PersistenceOptions.ID_COLU MN_NAME, "id");
> persistenceProperties.setProperty(PersistenceOptions.VERSION _COLUMN_NAME,
> "version");
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #73013 is a reply to message #72995] |
Wed, 28 February 2007 09:16   |
Hi Björn,
Afaics the <details...> tag in the eAnnotations of the AmsetVersion EDataType is commented out using
xml comment characters (<!-- and -->). Could that be a reason?
Also the id annotation does not seem to be completely correct. The source should teneo.jpa and then
the value should also contain the @Id annotation.
There should be no difference in generating the mapping file manually and then use that or the
automatic mapping in-memory (it also generates an in-memory mapping). I would suggest to use the
automatic in-memory mapping until you want to do extensive manual changes (for example to map to a
current db schema).
gr. Martin
Björn Sundin wrote:
> Hi Martin,
> Thanks for your reply. It definitely brought me on the right path and so I
> decided to define my own id and version datatypes in ecore:
> <eClassifiers xsi:type="ecore:EDataType" name="AmsetId"
> instanceClassName="int">
> <eAnnotations source="teneo.jpa/Id">
> <details key="appinfo"
> value="@GeneratedValue(strategy="AUTO")"/ >
> </eAnnotations>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EDataType" name="AmsetVersion"
> <eAnnotations source="teneo.jpa/Version">
> <!-- <details key="appinfo" value="@Version"/> -->
> </eAnnotations>
> </eClassifiers>
> Those two datatypes are referenced in i.e StatusType:
> <eClassifiers xsi:type="ecore:EClass" name="StatusType">
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
> lowerBound="1"
> eType="ecore:EDataType
> http://www.eclipse.org/emf/2002/Ecore#//EString"/>
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="id"
> lowerBound="1"
> eType="#//bergauer/rcp/amset/model/datatypes/AmsetId"
> iD="true"/>
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="version"
> lowerBound="1"
> eType="#//bergauer/rcp/amset/model/datatypes/AmsetVersion"/ >
> </eClassifiers>
> I now have the following results:
> PersistenceOptions.USE_MAPPING_FILE set true:
> - The hibernate.hbm.xml I now have the id-element with generator,
> non-synthetic. Id is generated as expected
> - The version attribute that I define in ecore isn't recognized with
> annotation yet. In the hibernate.hbm.xml I have one version-element (with
> synthetic set true) and in the database I get two fields e_version and
> version. The PersistenceOptions.ALWAYS_VERSION is set false in the
> EditorPlugin.
> <class entity-name="StatusType" abstract="false" lazy="false"
> discriminator-value="StatusType" table="`statustype`">
> <meta attribute="eclassName">StatusType</meta>
> <meta
> attribute="epackage">ch.bergauer.rcp.amset.model.systemattributes.amset.xmi <
> /meta>
> <generator class="native"/>
> </id>
> <discriminator column="`dtype`" type="string"/>
> <version name="e_version" column="e_version"
> ler">
> </version>
> <property name="name" lazy="false" insert="true" update="true"
> not-null="true" unique="false" type="java.lang.String">
> <column not-null="true" unique="false" name="`name`"/>
> </property>
> </class>
> PersistenceOptions.USE_MAPPING_FILE set false:
> Neither id nor version work is reqognized. In the in-menory mapping I
> have no generator element for the id-element:
> <meta
> /meta>
> </id>
> </property>
> <property name="version" lazy="false" insert="true" update="true"
> not-null="true" unique="false" type="int">
> <column not-null="true" unique="false" name="`version`"/>
> </property>
> </class>
> The solution using the hibernate.hbm.xml seems to be the better way, so I
> think I will go on using PersistenceOptions.USE_MAPPING_FILE=true.
> Apperently I'm doing something wrong with the version though. Am I
> overlooking something obvious?
> cheers,
> Björn
> ref: [Teneo] Setting Id generator from ecore file
> "Martin Taal" <mtaal@elver.org> schrieb im Newsbeitrag
> news:es1oej$v6h$1@utils.eclipse.org...
>> Hi Björn,
>> separate xml.
>> See also here:
>> gr. Martin
>> Björn Sundin wrote:
>>> Hi,
> my
> model
> visible.
> little
>>> success:
>>> FOR THE ID COLUMN:
>>> * @generated
>>> int getId();
>>> * @generated
> class
> in
>>> MySql)
>>> * @generated
>>> @Version
>>> int getVersion();
>>> * @generated
>>> version found
> modifying
> have
>>> added
>>> GENERATED:
>>> </id>
>>> MODIFIED:
>>> </id>
>>> GENERATED:
>>> ler">
>>> </version>
>>> MODIFIED:
>>> ler"/>
> problems
> version
>>> is incremented.
> in
>>> Thanks,
>>> Björn
>>> - Eclipse IDE 3.2.1
>>> - EMF 2.2.2
>>> - Hibernate 3.2
> "id");
>>> "version");
>> The Netherlands
The Netherlands
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #73053 is a reply to message #73035] |
Wed, 28 February 2007 10:56   |
Hi Björn,
What could explain the difference is that after a change in the ecore (like adding an annotation)
you have to regenerate the java model code to get the change in ecore to the runtime layer.
For the automatic mapping the ecore model is not read from the ecore file but from the in-memory
ecore representation. This in-memory representation is created by the generated PackageImpl and can
be out of sync with the ecore file.
So can you try again (if you like) after regenerating the java model code?
gr. Martin
Björn Sundin wrote:
> Hi Martin,
> Well the out-commented element is an artifact from my first try. Oddly
> enough I think it was about how you meant it should look like :
> <eAnnotations source="teneo.jpa">
> <details key="appinfo" value="@Id
> @GeneratedValue(strategy="AUTO")"/>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> It didn't work with the automatic mapping (and I think I missed out testing
> it with the hibernate.hbm.xml) so I abandoned it and found other suggestions
> in the newsgroup extending teneo.jpa to teneo.jpa/Id... :o/
> After having reimplemented the eDataTypes, as above, both Id and Version
> works well using the hibernate.hbm.xml! :) The automatic mapping, though,
> still doesn't recognize the annotations:
> hibernate.hbm.xml:
> <meta
> /meta>
> </id>
> <version name="version" type="int">
> </version>
> </property>
> </class>
> automatic mapping:
> <meta
> /meta>
> </id>
> </property>
> </property>
> </class>
> Could it have to do with the version of Teneo that I use? I'm currently
> using Teneo 0.7.5 Maintenance Build. I did download version 0.8.0 but had to
> deactivate it as I'm using Eclipse 3.2.1.
> Greetings,
> Björn
> news:es42sn$jr2$1@utils.eclipse.org...
>> Hi Björn,
>> current db schema).
>> gr. Martin
>> Björn Sundin wrote:
>>> Hi Martin,
> I
>>> </eAnnotations>
>>> </eClassifiers>
>>> </eAnnotations>
>>> </eClassifiers>
>>> lowerBound="1"
>>> lowerBound="1"
>>> iD="true"/>
>>> lowerBound="1"
>>> </eClassifiers>
> (with
>>> EditorPlugin.
>>> <meta
>>> /meta>
>>> </id>
>>> ler">
>>> </version>
>>> </property>
>>> </class>
> I
>>> <meta
>>> /meta>
>>> </id>
>>> </property>
> update="true"
>>> </property>
>>> </class>
> I
>>> cheers,
>>> Björn
>>>> Hi Björn,
> model
>>>> separate xml.
> annotations
> you
>>>> See also here:
>>>> gr. Martin
>>>> Björn Sundin wrote:
>>>>> Hi,
> in
>>> my
>>> model
>>> visible.
>>> little
>>>>> success:
>>>>> FOR THE ID COLUMN:
>>>>> * @generated
>>>>> int getId();
>>>>> * @generated
>>> class
>>> in
>>>>> MySql)
>>>>> * @generated
>>>>> @Version
>>>>> int getVersion();
>>>>> * @generated
>>>>> version found
>>> modifying
> EMF -
>>> have
>>>>> added
> generated
>>>>> GENERATED:
>>>>> </id>
>>>>> MODIFIED:
>>>>> </id>
>>>>> GENERATED:
>>>>> ler">
>>>>> </version>
>>>>> MODIFIED:
>>>>> ler"/>
>>> problems
>>> version
>>>>> is incremented.
> generated
>>> in
>>>>> Thanks,
>>>>> Björn
>>>>> - Eclipse IDE 3.2.1
>>>>> - EMF 2.2.2
>>>>> - Hibernate 3.2
>>> "id");
>>>>> "version");
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #73116 is a reply to message #73096] |
Wed, 28 February 2007 12:05   |
No problem. Actually, I am not sure why you would need to move the edatatype to the same package.
When you said regenerate, did you regenerate the model code of both epackages?
gr. Martin
Björn Sundin wrote:
> I just moved the eDataTypes to the same package as the model code and the
> autogenerated mapping works! I guess I'm lucky not sitting in your office
> right now...
> Greetings,
> Björn
> "Björn Sundin" <bsu@bergauer.ch> schrieb im Newsbeitrag
> news:es49s3$403$1@utils.eclipse.org...
>> Hi Martin,
>> I use to regenerate all code (model, edit, editor) every time I make a
>> change to the ecore model. Now I even deleted the model code and generated
>> it from scratch. I'm sorry to say that it still is a problem with the
>> autogenerated mapping. It's exactly the same as in my prevoious post.
>> Could it be a problem that the eDataTypes are in another package than the
>> model code?
>> Greetings,
>> Björn
>> news:es48o3$ak$1@utils.eclipse.org...
>>> Hi Björn,
>> the runtime layer.
> file
> code?
>>> gr. Martin
>>> Björn Sundin wrote:
>>>> Hi Martin,
>>>> </eAnnotations>
>>>> </eClassifiers>
>>>> </eAnnotations>
>>>> </eClassifiers>
>> testing
>> suggestions
> Version
>> though,
>>>> hibernate.hbm.xml:
>>>> <meta
>>>> /meta>
>>>> </id>
>>>> </version>
>>>> </property>
>>>> </class>
>>>> automatic mapping:
>>>> <meta
>>>> /meta>
>>>> </id>
>>>> </property>
>> update="true"
>>>> </property>
>>>> </class>
> currently
>> had to
>>>> Greetings,
>>>> Björn
>>>>> Hi Björn,
>> source
>> and
> I
>> changes
>>>>> current db schema).
>>>>> gr. Martin
>>>>> Björn Sundin wrote:
>>>>>> Hi Martin,
> and
>> so
>>>> I
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> lowerBound="1"
>>>>>> lowerBound="1"
>>>>>> iD="true"/>
>> name="version"
>>>>>> lowerBound="1"
>>>>>> </eClassifiers>
> generator,
>> with
>>>> (with
> and
>>>>>> EditorPlugin.
>>>>>> <meta
>>>>>> /meta>
>>>>>> </id>
>>>>>> ler">
>>>>>> </version>
> update="true"
>>>>>> </property>
>>>>>> </class>
>> mapping
>>>> I
>>>>>> <meta
>>>>>> /meta>
>>>>>> </id>
> update="true"
>>>>>> </property>
>>>> update="true"
> name="`version`"/>
>>>>>> </property>
>>>>>> </class>
>> so
>>>> I
>>>>>> cheers,
>>>>>> Björn
>>>>>>> Hi Björn,
>>>> model
>>>>>>> separate xml.
>>>> annotations
> then
>>>> you
>>>>>>> See also here:
>>>>>>> gr. Martin
>>>>>>> Björn Sundin wrote:
>>>>>>>> Hi,
>> columns
>>>> in
>>>>>> my
> my
>>>>>> model
> not
>>>>>> visible.
> with
>>>>>> little
>>>>>>>> success:
>>>>>>>> FOR THE ID COLUMN:
>>>>>>>> * @generated
>>>>>>>> int getId();
>>>>>>>> * @generated
> this
>>>>>> class
>> auto_increment
>>>>>> in
>>>>>>>> MySql)
>>>>>>>> * @generated
>>>>>>>> @Version
>>>>>>>> int getVersion();
>>>>>>>> * @generated
>> of
>>>>>>>> version found
>>>>>> modifying
> What
>> I
>>>> EMF -
> that
>> I
>>>>>> have
>>>>>>>> added
>>>> generated
>>>>>>>> GENERATED:
>>>>>>>> </id>
>>>>>>>> MODIFIED:
>>>>>>>> </id>
>>>>>>>> GENERATED:
>>>>>>>> ler">
>>>>>>>> </version>
>>>>>>>> MODIFIED:
>>>>>>>> ler"/>
> no
>>>>>> problems
> and
>>>>>> version
>>>>>>>> is incremented.
>>>> generated
>>>>>> in
>>>>>>>> Thanks,
>>>>>>>> Björn
>>>>>>>> - Eclipse IDE 3.2.1
>>>>>>>> - EMF 2.2.2
>>>>>>>> - Hibernate 3.2
>>>>>> "id");
>>>>>>>> "version");
>>>>>>> The Netherlands
>>>>> The Netherlands
>>> The Netherlands
The Netherlands
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #73242 is a reply to message #73169] |
Wed, 28 February 2007 14:27   |
Okay, to be honest I do not know exactly if something is out-of-the-ordinary here. Maybe, Ed, do you
know?
gr. Martin
Björn Sundin wrote:
> Yes, I beleve I do... Both packages are in same ecore model and thus I have
> only one genmodel. When I regenerate the model code both packages are
> created. What I noticed is that the Factory and Package classes where the
> model code is located gets the prefix of the package direct above. This is
> not the case for the Factory and Package classes where only the eDataTypes
> are located. Here the generated files are named without prefix
> (Factory.java, Package.java resp. in impl FactoryImpl.java,
> PackageImpl.java ). In FactoryImpl.java I also get a duplicated method
> getPackage() (though static and marked @deprecated) every time I regenerate.
> Greetings,
> Björn
> news:es4cpk$8vf$1@utils.eclipse.org...
> epackages?
>> gr. Martin
> the
> office
>>> right now...
>>> Greetings,
>>> Björn
>>>> Hi Martin,
> generated
> the
>>>> model code?
>>>> Greetings,
>>>> Björn
>>>>> Hi Björn,
> to
>>>> the runtime layer.
>>> file
>>> code?
>>>>> gr. Martin
>>>>> Björn Sundin wrote:
>>>>>> Hi Martin,
> Oddly
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>> testing
>>>> suggestions
>>> Version
>>>> though,
>>>>>> hibernate.hbm.xml:
>>>>>> <meta
>>>>>> /meta>
>>>>>> </id>
>>>>>> </version>
> update="true"
>>>>>> </property>
>>>>>> </class>
>>>>>> automatic mapping:
>>>>>> <meta
>>>>>> /meta>
>>>>>> </id>
> update="true"
>>>>>> </property>
>>>> update="true"
>>>>>> </property>
>>>>>> </class>
>>> currently
>>>> had to
>>>>>> Greetings,
>>>>>> Björn
>>>>>>> Hi Björn,
>>>> source
> manually
>>>> and
> mapping).
>>> I
>>>> changes
>>>>>>> current db schema).
>>>>>>> gr. Martin
>>>>>>> Björn Sundin wrote:
>>>>>>>> Hi Martin,
>>> and
>>>> so
>>>>>> I
>>>>>>>> </eAnnotations>
>>>>>>>> </eClassifiers>
>>>>>>>> </eAnnotations>
>>>>>>>> </eClassifiers>
> name="name"
>>>>>>>> lowerBound="1"
>>>>>>>> lowerBound="1"
>>>>>>>> iD="true"/>
>>>> name="version"
>>>>>>>> lowerBound="1"
>>>>>>>> </eClassifiers>
>>> generator,
>>>> with
>>>>>> (with
>>> and
>>>>>>>> EditorPlugin.
>>>>>>>> <meta
>>>>>>>> /meta>
>>>>>>>> </id>
>>>>>>>> ler">
>>>>>>>> </version>
>>> update="true"
>>>>>>>> </property>
>>>>>>>> </class>
>>>> mapping
>>>>>> I
>>>>>>>> <meta
>>>>>>>> /meta>
>>>>>>>> </id>
>>> update="true"
>>>>>>>> </property>
>>>>>> update="true"
>>> name="`version`"/>
>>>>>>>> </property>
>>>>>>>> </class>
> way,
>>>> so
>>>>>> I
>>>>>>>> cheers,
>>>>>>>> Björn
>>>>>>>>> Hi Björn,
>>>>>> model
>>>>>>>>> separate xml.
>>>>>> annotations
>>> then
>>>>>> you
>>>>>>>>> See also here:
>>>>>>>>> gr. Martin
>>>>>>>>> Björn Sundin wrote:
>>>>>>>>>> Hi,
>>>> columns
>>>>>> in
>>>>>>>> my
>>> my
>>>>>>>> model
>>> not
>>>>>>>> visible.
>>> with
>>>>>>>> little
>>>>>>>>>> success:
>>>>>>>>>> FOR THE ID COLUMN:
>>>>>>>>>> * @generated
>>>>>>>>>> int getId();
>>>>>>>>>> * @generated
>>> this
>>>>>>>> class
>>>> auto_increment
>>>>>>>> in
>>>>>>>>>> MySql)
>>>>>>>>>> * @generated
>>>>>>>>>> @Version
>>>>>>>>>> int getVersion();
>>>>>>>>>> * @generated
> mapping
>>>> of
>>>>>>>>>> version found
>>>>>>>> modifying
>>> What
>>>> I
>>>>>> EMF -
>>> that
>>>> I
>>>>>>>> have
>>>>>>>>>> added
>>>>>> generated
>>>>>>>>>> GENERATED:
>>>>>>>>>> </id>
>>>>>>>>>> MODIFIED:
>>>>>>>>>> </id>
>>>>>>>>>> GENERATED:
>>>>>>>>>> ler">
>>>>>>>>>> </version>
>>>>>>>>>> MODIFIED:
>>>>>>>>>> ler"/>
>>> no
>>>>>>>> problems
>>> and
>>>>>>>> version
>>>>>>>>>> is incremented.
>>>>>> generated
>>>>>>>> in
>>>>>>>>>> Thanks,
>>>>>>>>>> Björn
>>>>>>>>>> - Eclipse IDE 3.2.1
>>>>>>>>>> - EMF 2.2.2
>>>>>>>>>> - Hibernate 3.2
>>>>>>>> "id");
>>>>>>>>>> "version");
>>>>>>>>> The Netherlands
>>>>>>> The Netherlands
>>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #602973 is a reply to message #72941] |
Hi Björn,
separate xml.
See also here:
gr. Martin
Björn Sundin wrote:
> success:
> FOR THE ID COLUMN:
> * @generated
> int getId();
> * @generated
> MySql)
> * @generated
> @Version
> int getVersion();
> * @generated
> version found
> GENERATED:
> </id>
> MODIFIED:
> </id>
> GENERATED:
> ler">
> </version>
> MODIFIED:
> ler"/>
> is incremented.
> Björn
> - Eclipse IDE 3.2.1
> - EMF 2.2.2
> - Hibernate 3.2
> "version");
The Netherlands
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #602977 is a reply to message #72985] |
Wed, 28 February 2007 08:50  |
Hi Martin,
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eClassifiers>
lowerBound="1"
lowerBound="1"
iD="true"/>
lowerBound="1"
</eClassifiers>
EditorPlugin.
<meta
/meta>
</id>
ler">
</version>
</property>
</class>
<meta
/meta>
</id>
</property>
</property>
</class>
cheers,
Bj
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #602979 is a reply to message #72995] |
Hi Björn,
current db schema).
gr. Martin
Björn Sundin wrote:
> Hi Martin,
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> lowerBound="1"
> lowerBound="1"
> iD="true"/>
> lowerBound="1"
> </eClassifiers>
> EditorPlugin.
> <meta
> /meta>
> </id>
> ler">
> </version>
> </property>
> </class>
> <meta
> /meta>
> </id>
> </property>
> </property>
> </class>
> cheers,
> Björn
>> Hi Björn,
>> separate xml.
>> See also here:
>> gr. Martin
>> Björn Sundin wrote:
>>> Hi,
> my
> model
> visible.
> little
>>> success:
>>> FOR THE ID COLUMN:
>>> * @generated
>>> int getId();
>>> * @generated
> class
> in
>>> MySql)
>>> * @generated
>>> @Version
>>> int getVersion();
>>> * @generated
>>> version found
> modifying
> have
>>> added
>>> GENERATED:
>>> </id>
>>> MODIFIED:
>>> </id>
>>> GENERATED:
>>> ler">
>>> </version>
>>> MODIFIED:
>>> ler"/>
> problems
> version
>>> is incremented.
> in
>>> Thanks,
>>> Björn
>>> - Eclipse IDE 3.2.1
>>> - EMF 2.2.2
>>> - Hibernate 3.2
> "id");
>>> "version");
>> The Netherlands
The Netherlands
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #602983 is a reply to message #73013] |
Wed, 28 February 2007 10:51  |
Hi Martin,
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eClassifiers>
hibernate.hbm.xml:
<meta
/meta>
</id>
</version>
</property>
</class>
automatic mapping:
<meta
/meta>
</id>
</property>
</property>
</class>
Greetings,
Bj
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #602987 is a reply to message #73035] |
Hi Björn,
gr. Martin
Björn Sundin wrote:
> Hi Martin,
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eClassifiers>
> hibernate.hbm.xml:
> <meta
> /meta>
> </id>
> </version>
> </property>
> </class>
> automatic mapping:
> <meta
> /meta>
> </id>
> </property>
> </property>
> </class>
> Greetings,
> Björn
>> Hi Björn,
>> current db schema).
>> gr. Martin
>> Björn Sundin wrote:
>>> Hi Martin,
> I
>>> </eAnnotations>
>>> </eClassifiers>
>>> </eAnnotations>
>>> </eClassifiers>
>>> lowerBound="1"
>>> lowerBound="1"
>>> iD="true"/>
>>> lowerBound="1"
>>> </eClassifiers>
> (with
>>> EditorPlugin.
>>> <meta
>>> /meta>
>>> </id>
>>> ler">
>>> </version>
>>> </property>
>>> </class>
> I
>>> <meta
>>> /meta>
>>> </id>
>>> </property>
> update="true"
>>> </property>
>>> </class>
> I
>>> cheers,
>>> Björn
>>>> Hi Björn,
> model
>>>> separate xml.
> annotations
> you
>>>> See also here:
>>>> gr. Martin
>>>> Björn Sundin wrote:
>>>>> Hi,
> in
>>> my
>>> model
>>> visible.
>>> little
>>>>> success:
>>>>> FOR THE ID COLUMN:
>>>>> * @generated
>>>>> int getId();
>>>>> * @generated
>>> class
>>> in
>>>>> MySql)
>>>>> * @generated
>>>>> @Version
>>>>> int getVersion();
>>>>> * @generated
>>>>> version found
>>> modifying
> EMF -
>>> have
>>>>> added
> generated
>>>>> GENERATED:
>>>>> </id>
>>>>> MODIFIED:
>>>>> </id>
>>>>> GENERATED:
>>>>> ler">
>>>>> </version>
>>>>> MODIFIED:
>>>>> ler"/>
>>> problems
>>> version
>>>>> is incremented.
> generated
>>> in
>>>>> Thanks,
>>>>> Björn
>>>>> - Eclipse IDE 3.2.1
>>>>> - EMF 2.2.2
>>>>> - Hibernate 3.2
>>> "id");
>>>>> "version");
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #602990 is a reply to message #73053] |
Wed, 28 February 2007 11:16  |
Hi Martin,
model code?
Greetings,
Bj
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #602996 is a reply to message #73096] |
gr. Martin
> right now...
> Greetings,
> Björn
>> Hi Martin,
>> model code?
>> Greetings,
>> Björn
>>> Hi Björn,
>> the runtime layer.
> file
> code?
>>> gr. Martin
>>> Björn Sundin wrote:
>>>> Hi Martin,
>>>> </eAnnotations>
>>>> </eClassifiers>
>>>> </eAnnotations>
>>>> </eClassifiers>
>> testing
>> suggestions
> Version
>> though,
>>>> hibernate.hbm.xml:
>>>> <meta
>>>> /meta>
>>>> </id>
>>>> </version>
>>>> </property>
>>>> </class>
>>>> automatic mapping:
>>>> <meta
>>>> /meta>
>>>> </id>
>>>> </property>
>> update="true"
>>>> </property>
>>>> </class>
> currently
>> had to
>>>> Greetings,
>>>> Björn
>>>>> Hi Björn,
>> source
>> and
> I
>> changes
>>>>> current db schema).
>>>>> gr. Martin
>>>>> Björn Sundin wrote:
>>>>>> Hi Martin,
> and
>> so
>>>> I
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> lowerBound="1"
>>>>>> lowerBound="1"
>>>>>> iD="true"/>
>> name="version"
>>>>>> lowerBound="1"
>>>>>> </eClassifiers>
> generator,
>> with
>>>> (with
> and
>>>>>> EditorPlugin.
>>>>>> <meta
>>>>>> /meta>
>>>>>> </id>
>>>>>> ler">
>>>>>> </version>
> update="true"
>>>>>> </property>
>>>>>> </class>
>> mapping
>>>> I
>>>>>> <meta
>>>>>> /meta>
>>>>>> </id>
> update="true"
>>>>>> </property>
>>>> update="true"
> name="`version`"/>
>>>>>> </property>
>>>>>> </class>
>> so
>>>> I
>>>>>> cheers,
>>>>>> Björn
>>>>>>> Hi Björn,
>>>> model
>>>>>>> separate xml.
>>>> annotations
> then
>>>> you
>>>>>>> See also here:
>>>>>>> gr. Martin
>>>>>>> Björn Sundin wrote:
>>>>>>>> Hi,
>> columns
>>>> in
>>>>>> my
> my
>>>>>> model
> not
>>>>>> visible.
> with
>>>>>> little
>>>>>>>> success:
>>>>>>>> FOR THE ID COLUMN:
>>>>>>>> * @generated
>>>>>>>> int getId();
>>>>>>>> * @generated
> this
>>>>>> class
>> auto_increment
>>>>>> in
>>>>>>>> MySql)
>>>>>>>> * @generated
>>>>>>>> @Version
>>>>>>>> int getVersion();
>>>>>>>> * @generated
>> of
>>>>>>>> version found
>>>>>> modifying
> What
>> I
>>>> EMF -
> that
>> I
>>>>>> have
>>>>>>>> added
>>>> generated
>>>>>>>> GENERATED:
>>>>>>>> </id>
>>>>>>>> MODIFIED:
>>>>>>>> </id>
>>>>>>>> GENERATED:
>>>>>>>> ler">
>>>>>>>> </version>
>>>>>>>> MODIFIED:
>>>>>>>> ler"/>
> no
>>>>>> problems
> and
>>>>>> version
>>>>>>>> is incremented.
>>>> generated
>>>>>> in
>>>>>>>> Thanks,
>>>>>>>> Björn
>>>>>>>> - Eclipse IDE 3.2.1
>>>>>>>> - EMF 2.2.2
>>>>>>>> - Hibernate 3.2
>>>>>> "id");
>>>>>>>> "version");
>>>>>>> The Netherlands
>>>>> The Netherlands
>>> The Netherlands
The Netherlands
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #603009 is a reply to message #73116] |
Wed, 28 February 2007 12:21  |
Greetings,
Bj
Re: [Teneo] Possible to Override Generation of hibernate.hbm.xml? [message #603020 is a reply to message #73169] |
know?
gr. Martin
> Greetings,
> Björn
> epackages?
>> gr. Martin
> the
> office
>>> right now...
>>> Greetings,
>>> Björn
>>>> Hi Martin,
> generated
> the
>>>> model code?
>>>> Greetings,
>>>> Björn
>>>>> Hi Björn,
> to
>>>> the runtime layer.
>>> file
>>> code?
>>>>> gr. Martin
>>>>> Björn Sundin wrote:
>>>>>> Hi Martin,
> Oddly
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>>>> </eAnnotations>
>>>>>> </eClassifiers>
>>>> testing
>>>> suggestions
>>> Version
>>>> though,
>>>>>> hibernate.hbm.xml:
>>>>>> <meta
>>>>>> /meta>
>>>>>> </id>
>>>>>> </version>
> update="true"
>>>>>> </property>
>>>>>> </class>
>>>>>> automatic mapping:
>>>>>> <meta
>>>>>> /meta>
>>>>>> </id>
> update="true"
>>>>>> </property>
>>>> update="true"
>>>>>> </property>
>>>>>> </class>
>>> currently
>>>> had to
>>>>>> Greetings,
>>>>>> Björn
>>>>>>> Hi Björn,
>>>> source
> manually
>>>> and
> mapping).
>>> I
>>>> changes
>>>>>>> current db schema).
>>>>>>> gr. Martin
>>>>>>> Björn Sundin wrote:
>>>>>>>> Hi Martin,
>>> and
>>>> so
>>>>>> I
>>>>>>>> </eAnnotations>
>>>>>>>> </eClassifiers>
>>>>>>>> </eAnnotations>
>>>>>>>> </eClassifiers>
> name="name"
>>>>>>>> lowerBound="1"
>>>>>>>> lowerBound="1"
>>>>>>>> iD="true"/>
>>>> name="version"
>>>>>>>> lowerBound="1"
>>>>>>>> </eClassifiers>
>>> generator,
>>>> with
>>>>>> (with
>>> and
>>>>>>>> EditorPlugin.
>>>>>>>> <meta
>>>>>>>> /meta>
>>>>>>>> </id>
>>>>>>>> ler">
>>>>>>>> </version>
>>> update="true"
>>>>>>>> </property>
>>>>>>>> </class>
>>>> mapping
>>>>>> I
>>>>>>>> <meta
>>>>>>>> /meta>
>>>>>>>> </id>
>>> update="true"
>>>>>>>> </property>
>>>>>> update="true"
>>> name="`version`"/>
>>>>>>>> </property>
>>>>>>>> </class>
> way,
>>>> so
>>>>>> I
>>>>>>>> cheers,
>>>>>>>> Björn
>>>>>>>>> Hi Björn,
>>>>>> model
>>>>>>>>> separate xml.
>>>>>> annotations
>>> then
>>>>>> you
>>>>>>>>> See also here:
>>>>>>>>> gr. Martin
>>>>>>>>> Björn Sundin wrote:
>>>>>>>>>> Hi,
>>>> columns
>>>>>> in
>>>>>>>> my
>>> my
>>>>>>>> model
>>> not
>>>>>>>> visible.
>>> with
>>>>>>>> little
>>>>>>>>>> success:
>>>>>>>>>> FOR THE ID COLUMN:
>>>>>>>>>> * @generated
>>>>>>>>>> int getId();
>>>>>>>>>> * @generated
>>> this
>>>>>>>> class
>>>> auto_increment
>>>>>>>> in
>>>>>>>>>> MySql)
>>>>>>>>>> * @generated
>>>>>>>>>> @Version
>>>>>>>>>> int getVersion();
>>>>>>>>>> * @generated
> mapping
>>>> of
>>>>>>>>>> version found
>>>>>>>> modifying
>>> What
>>>> I
>>>>>> EMF -
>>> that
>>>> I
>>>>>>>> have
>>>>>>>>>> added
>>>>>> generated
>>>>>>>>>> GENERATED:
>>>>>>>>>> </id>
>>>>>>>>>> MODIFIED:
>>>>>>>>>> </id>
>>>>>>>>>> GENERATED:
>>>>>>>>>> ler">
>>>>>>>>>> </version>
>>>>>>>>>> MODIFIED:
>>>>>>>>>> ler"/>
>>> no
>>>>>>>> problems
>>> and
>>>>>>>> version
>>>>>>>>>> is incremented.
>>>>>> generated
>>>>>>>> in
>>>>>>>>>> Thanks,
>>>>>>>>>> Björn
>>>>>>>>>> - Eclipse IDE 3.2.1
>>>>>>>>>> - EMF 2.2.2
>>>>>>>>>> - Hibernate 3.2
>>>>>>>> "id");
>>>>>>>>>> "version");
>>>>>>>>> The Netherlands
>>>>>>> The Netherlands
>>>>> The Netherlands
>> The Netherlands
The Netherlands
Current Time: Sat Jul 19 11:35:32 EDT 2025
Powered by FUDForum. Page generated in 0.07846 seconds
