PDE Director throws ClassNotFoundException [message #602827] |
Fri, 23 October 2009 10:15  |
does anybody have any idea whats going wrong here?
While the PDE Director application tries to install my product - it throws exceptions that it can't find the SWTException class. See the ant log below:
Thanks in advance for your answer,
Alain.
[java] main:
[java]
[java] assemble.org.eclipse.pde.build.container.feature.win32.win32 .x86:
[java]
[java] main:
[java]
[java] runDirector:
[java]
[java] runDirector:
[java] [echo] This application is deprecated. Please use the org.eclipse.equinox.p2.director application.
[java] [echo] Installing ch.ivyteam.ivy.designerproduct 1.0.0.30741-M2.
[java] [echo] !SESSION 2009-10-23 16:05:49.545 -----------------------------------------------
[java] [echo] eclipse.buildId=M20090917-0800
[java] [echo] java.version=1.6.0_16
[java] [echo] java.vendor=Sun Microsystems Inc.
[java] [echo] BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_CH
[java] [echo] Framework arguments: -application org.eclipse.equinox.p2.director.app.application --launcher.suppressErrors -flavor ${p2.flavor} -installIU ch.ivyteam.ivy.designerproduct -version 1.0.0.30741-M2 -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming -profile profile -profileProperties org.eclipse.update.install.features=true -metadataRepository file:C:\hudsonbuilds\XpertIvyDesigner\4.2_PDE_build\source\p lugins\Xpert.ivy Designer/../../../buildresults/buildRepo -artifactRepository file:C:\hudsonbuilds\XpertIvyDesigner\4.2_PDE_build\source\p lugins\Xpert.ivy Designer/../../../buildresults/buildRepo -destination C:\hudsonbuilds\XpertIvyDesigner\4.2_PDE_build\source\plugin s\Xpert.ivy Designer/../../../buildresults/tmp/XpertIvyDesigner42 -bundlepool C:\hudsonbuilds\XpertIvyDesigner\4.2_PDE_build\source\plugin s\Xpert.ivy Designer/../../../buildresults/tmp/XpertIvyDesigner42
[java] [echo] Command-line arguments: -application org.eclipse.equinox.p2.director.app.application --launcher.suppressErrors -consoleLog -flavor ${p2.flavor} -installIU ch.ivyteam.ivy.designerproduct -version 1.0.0.30741-M2 -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming -profile profile -profileProperties org.eclipse.update.install.features=true -metadataRepository file:C:\hudsonbuilds\XpertIvyDesigner\4.2_PDE_build\source\p lugins\Xpert.ivy Designer/../../../buildresults/buildRepo -artifactRepository file:C:\hudsonbuilds\XpertIvyDesigner\4.2_PDE_build\source\p lugins\Xpert.ivy Designer/../../../buildresults/buildRepo -destination C:\hudsonbuilds\XpertIvyDesigner\4.2_PDE_build\source\plugin s\Xpert.ivy Designer/../../../buildresults/tmp/XpertIvyDesigner42 -bundlepool C:\hudsonbuilds\XpertIvyDesigner\4.2_PDE_build\source\plugin s\Xpert.ivy Designer/../../../buildresults/tmp/XpertIvyDesigner42
[java] [echo]
[java] [echo] !ENTRY org.eclipse.osgi 4 0 2009-10-23 16:05:53.045
[java] [echo] !MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (254).
[java] [echo] !STACK 0
[java] [echo] org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
[java] [echo] at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
[java] [echo] at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:751)
[java] [echo] at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
[java] [echo] at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
[java] [echo] at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
[java] [echo] at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
[java] [echo] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
[java] [echo] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
[java] [echo] at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:381)
[java] [echo] at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
[java] [echo] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:454)
[java] [echo] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
[java] [echo] at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
[java] [echo] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
[java] [echo] at java.lang.ClassLoader.loadClass(Unknown Source)
[java] [echo] at java.lang.ClassLoader.loadClassInternal(Unknown Source)
[java] [echo] at java.lang.ClassLoader.defineClass1(Native Method)
[java] [echo] at java.lang.ClassLoader.defineClass(Unknown Source)
[java] [echo] at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:183)
[java] [echo] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:576)
[java] [echo] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:546)
[java] [echo] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:477)
[java] [echo] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:465)
[java] [echo] at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:445)
[java] [echo] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:457)
[java] [echo] at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:326)
[java] [echo] at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
[java] [echo] at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:150)
[java] [echo] at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
[java] [echo] at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
[java] [echo] at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
[java] [echo] at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
[java] [echo] at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
[java] [echo] at org.eclipse.core.internal.net.ProxyManager.getPluggedInAuthe nticator(ProxyManager.java:400)
[java] [echo] at org.eclipse.core.internal.net.ProxyManager.registerAuthentic ator(ProxyManager.java:382)
[java] [echo] at org.eclipse.core.internal.net.ProxyManager.initialize(ProxyM anager.java:283)
[java] [echo] at org.eclipse.core.internal.net.Activator.start(Activator.java :179)
[java] [echo] at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
[java] [echo] at java.security.AccessController.doPrivileged(Native Method)
[java] [echo] at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
[java] [echo] at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
[java] [echo] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:445)
[java] [echo] at java.lang.Class.forName0(Native Method)
[java] [echo] at java.lang.Class.forName(Unknown Source)
[java] [echo] at org.eclipse.ecf.internal.provider.filetransfer.Activator.get ProxyService(Activator.java:198)
[java] [echo] at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.setupProxies(AbstractRetrieveFileTransfer.ja va:875)
[java] [echo] at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTran sfer.java:807)
[java] [echo] at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTran sfer.java:506)
[java] [echo] at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocol RetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAda pter.java:98)
[java] [echo] at org.eclipse.equinox.internal.p2.repository.FileReader.sendRe trieveRequest(FileReader.java:317)
[java] [echo] at org.eclipse.equinox.internal.p2.repository.FileReader.readIn to(FileReader.java:263)
[java] [echo] at org.eclipse.equinox.internal.p2.repository.RepositoryTranspo rt.download(RepositoryTransport.java:71)
[java] [echo] at org.eclipse.equinox.internal.p2.repository.RepositoryTranspo rt.download(RepositoryTransport.java:127)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:468)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:451)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:518)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.getArtifact(MirrorRequest.java:200)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transferSingle(MirrorRequest.java:175)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:159)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:95)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:507)
[java] [echo] at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifacts(SimpleArtifactRepositor y.java:563)
[java] [echo] at org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch (DownloadManager.java:109)
[java] [echo] at org.eclipse.equinox.internal.p2.engine.DownloadManager.start (DownloadManager.java:97)
[java] [echo] at org.eclipse.equinox.internal.provisional.p2.engine.phases.Co llect.completePhase(Collect.java:73)
[java] [echo] at org.eclipse.equinox.internal.provisional.p2.engine.Phase.pos tPerform(Phase.java:195)
[java] [echo] at org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:78)
[java] [echo] at org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet. perform(PhaseSet.java:44)
[java] [echo] at org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe rform(Engine.java:54)
[java] [echo] at org.eclipse.equinox.internal.provisional.p2.director.PlanExe cutionHelper.executePlan(PlanExecutionHelper.java:41)
[java] [echo] at org.eclipse.equinox.internal.provisional.p2.director.PlanExe cutionHelper.executePlan(PlanExecutionHelper.java:23)
[java] [echo] at org.eclipse.equinox.internal.p2.director.app.Application.pla nAndExecute(Application.java:265)
[java] [echo] at org.eclipse.equinox.internal.p2.director.app.Application.run (Application.java:434)
[java] [echo] at org.eclipse.equinox.internal.p2.director.app.Application.sta rt(Application.java:536)
[java] [echo] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
[java] [echo] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
[java] [echo] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
[java] [echo] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
[java] [echo] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
[java] [echo] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] [echo] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
[java] [echo] at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
[java] [echo] at java.lang.reflect.Method.invoke(Unknown Source)
[java] [echo] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
[java] [echo] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
[java] [echo] at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
[java] [echo] at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
[java] [echo] Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
[java] [echo] at java.lang.Class.getDeclaredConstructors0(Native Method)
[java] [echo] at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
[java] [echo] at java.lang.Class.getConstructor0(Unknown Source)
[java] [echo] at java.lang.Class.newInstance0(Unknown Source)
[java] [echo] at java.lang.Class.newInstance(Unknown Source)
[java] [echo] at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:152)
[java] [echo] ... 120 more
[java] [echo] Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
[java] [echo] at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
[java] [echo] ... 126 more
[java] [echo] Root exception:
[java] [echo] java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
FUDForum. Page generated in 0.08939 seconds
