Plugin classpath problems [message #602666] |
Tue, 20 October 2009 11:16  |
I am trying to desrialize an object of type A. Although my plugin has the proper dependency on plugin C which has type A and can also create and instantiate an object of type A, when I try to desiralize an object of type A, it fails.
The reason I believe is that the java.io.* classes which are actually doing the deserialization cannot see type A.
What do I have to put in the manifest of plugin C so that the system classes can see type A?
Here is a stack trace I am getting-
java.lang.ClassNotFoundException: com.chronon.sb.debug.model.TimeAndEventData
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at java.io.ObjectInputStream.resolveClass(Unknown Source)
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
at com.chronon.sb.recorder.commons.CompressorUtil.decompressObj ect(CompressorUtil.java:53)
at com.chronon.sb.recorder.commons.CompressorUtil.decompressObj (CompressorUtil.java:36)
at com.chronon.sb.debug.core.dbManagers.Events.createBlock(Even ts.java:134)
at com.chronon.sb.debug.core.dbManagers.Events.getThreadForTime (Events.java:108)
at com.chronon.sb.debug.core.helpers.MethodCallHelper.<init>(MethodCallHelper.java:62)
at com.chronon.sb.debug.core.helpers.MiscHelper.getVeryFirstMet hod(MiscHelper.java:22)
at com.placid.sb.browser.ui.startbrowse.StartBrowseJob$1.run(St artBrowseJob.java:86)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
FUDForum. Page generated in 0.36708 seconds
