Home » Eclipse Projects » Plugin Development Environment (PDE) » Plug-in Fragment cannot resolve classes from host
Plug-in Fragment cannot resolve classes from host [message #488656] Tue, 29 September 2009 11:48 Go to next message
Originally posted by: cold.phusion.gmail.com
I am new to extending plugins with fragments, so I guess this should be
straight-forward. Imagine the following set-up:
Host: org.eclipse.swt
Fragment: xyz.abc.product
The Fragment's manifest:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Extension Fragment
Bundle-SymbolicName: xyz.abc.product
Bundle-Version: 1.5.0
Bundle-Vendor: ABC
Fragment-Host: org.eclipse.swt
All imports from the host plugin are not resolved in the any of the fragment
classes as if the host plugin was not on the classpath...
Is there anything I've forgotten in the manifest / fragment configuration?
Alex
Re: Plug-in Fragment cannot resolve classes from host [message #490611 is a reply to message #488656] Fri, 09 October 2009 08:12 Go to previous messageGo to next message
He Alex,
I have the same problem, do you found a solution ?
Please let me know.
André
[Updated on: Fri, 09 October 2009 08:28] by Moderator
Re: Plug-in Fragment cannot resolve classes from host [message #490714 is a reply to message #488656] Fri, 09 October 2009 15:04 Go to previous messageGo to next message
Alex Shterev wrote:
> Bundle-Vendor: ABC
Are you patching SWT or something else? PDE has two headers to deal with
these type of things:
The Eclipse-ExtensibleAPI is used to specify whether a host bundle
allows fragment bundles to add addtional API to the host. This header
should be used if a host bundle wants to allow fragments to add
additional packages to the API of the host. If this header is not
specified then a default value of 'false' is used. The
Eclipse-ExtensibleAPI header must use the following syntax:
Eclipse-ExtensibleAPI ::= ( 'true' | 'false' )
The following is an example of the Eclipse-ExtensibleAPI header:
Eclipse-ExtensibleAPI: true
Eclipse-PatchFragment ::= ( 'true' | 'false' )
https://bugs.eclipse.org/bugs/show_bug.cgi?id=126687
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Plug-in Fragment cannot resolve classes from host [message #490826 is a reply to message #488656] Sun, 11 October 2009 11:54 Go to previous messageGo to next message
@Chris - thank you for replying. Yes, I'm trying to extend the SWT library
(org.eclipse.swt) and yes - its manifest includes "Eclipse-ExtensibleAPI: true".
I'm wondering if this is not actually the correct behavior? That is - if you are
extending a plugin with a fragment, are you allowed to use its classes or not?
@André - no, unfortunately I haven't. I'll post another thread on the equinox
newsgroup, because I need a solution rather urgently. I'll keep you posted.
Alex
Alex Shterev <cold.phusion@gmail.com> wrote:
> Bundle-Vendor: ABC
> Alex
Re: Plug-in Fragment cannot resolve classes from host [message #496306 is a reply to message #490826] Mon, 09 November 2009 11:46 Go to previous messageGo to next message
I found me mistake. The host- plugin was not in the feature. After I include the plugin in the same feature.xml as the fragment everythink works fine.
André
Re: Plug-in Fragment cannot resolve classes from host [message #496476 is a reply to message #496306] Tue, 10 November 2009 04:10 Go to previous message
Andre Kullmann a écrit :
> works fine.
> Cheers,
> André
Thanks a lot Andre. I met a similar issue with automated tests because of org.eclipse.ant.optionla.junit fragmant and stggled for days until I saw you message. Now it's ok thanks to your tip.
IMHO, this should be considered as a bug or a feature request against Equinox, since Equinox users (ie plugin developers) do not expect nor understand such a constraint. Should we file a bug for it?
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: Plug-in Fragment cannot resolve classes from host [message #602369 is a reply to message #488656] Fri, 09 October 2009 08:12 Go to previous message
He Alex,
Please let me know.
André
Re: Plug-in Fragment cannot resolve classes from host [message #602376 is a reply to message #488656] Fri, 09 October 2009 15:04 Go to previous message
Alex Shterev wrote:
> Bundle-Vendor: ABC
Re: Plug-in Fragment cannot resolve classes from host [message #602401 is a reply to message #488656] Sun, 11 October 2009 11:54 Go to previous message
Alex
> Bundle-Vendor: ABC
> Alex
Re: Plug-in Fragment cannot resolve classes from host [message #603122 is a reply to message #490826] Mon, 09 November 2009 11:46 Go to previous message
André
Re: Plug-in Fragment cannot resolve classes from host [message #603130 is a reply to message #603122] Tue, 10 November 2009 04:10 Go to previous message
> works fine.
> Cheers,
> André
Previous Topic:Does doc.zip no longer work in 3.5?
Next Topic:Adding annotation model to default text editor
Current Time: Sat Jul 19 21:54:10 EDT 2025
Powered by FUDForum. Page generated in 0.07515 seconds
