Home » Eclipse Projects » Mylyn » Grayed out entries in package explorer
Grayed out entries in package explorer [message #42009] Mon, 28 January 2008 17:16 Go to next message
Originally posted by: fake.phony_email_address.com
Newbie here. I installed Mylyn with the Bugzilla plugin, and it works.
But now most of the entries in the package explorer are grayed out (but
still clickable). It appears that recently-used entries are black. How
do I reset everything to black?
I activated then deactivated an issue, thinking that would help, but it
did not.
Re: Grayed out entries in package explorer [message #42164 is a reply to message #42009] Thu, 31 January 2008 11:22 Go to previous messageGo to next message
> did not.
The graying out signifies decaying interest. The files that you don't
use are deemed less and less relevant for the current task. This is an
important part of the Mylyn productivity gain: hide what you don't need/use.
You can switch this of entirely in the package explorer by clicking the
3 circle button in the top or deselecting Focus on Active Task in the
view menu. This Focus on Active Task button can also be found in other
views: outline, java editor, problems, tasks, etc.
Maarten
Re: Grayed out entries in package explorer [message #553525 is a reply to message #42164] Tue, 17 August 2010 15:38 Go to previous messageGo to next message
I have recently had sight issues and I am trying to setup a dark background and light foreground color scheme in Eclipse, but I am seeing greyed out package names which start as black and are almost immediately redrawn in this faint grey which I cannot see. I just want the system default foreground color to be used always.
Disabling the "Focus on Active Task" has no effect on the package name greying. It seems I have found how to affect every other color but this one and the permanent grey of the menu backgrounds. Any help would be appreciated.
Re: Grayed out entries in package explorer [message #553779 is a reply to message #553525] Wed, 18 August 2010 16:03 Go to previous messageGo to next message
that sounds like something we need to look into and very similar to this
request:
321336: Change the highlight color black in the inactive task-focused view
mode
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321336
It would be much appreciate if you added your requirements to the bug above.
Thanks.
Steffen
> appreciated.
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Grayed out entries in package explorer [message #587335 is a reply to message #42009] Thu, 31 January 2008 11:22 Go to previous messageGo to next message
> did not.
Maarten
Re: Grayed out entries in package explorer [message #601855 is a reply to message #42164] Tue, 17 August 2010 15:38 Go to previous messageGo to next message
Re: Grayed out entries in package explorer [message #601883 is a reply to message #601855] Wed, 18 August 2010 16:03 Go to previous messageGo to next message
request:
mode
Thanks.
Steffen
> appreciated.
Steffen Pingel
Re: Grayed out entries in package explorer [message #1415749 is a reply to message #601883] Wed, 03 September 2014 10:07 Go to previous message
I know this topic is quite old. Anyway, I am using the Luna version of eclipse, and looks like this is not solved.
A solution I found was disabling the Interest decorator:
Preferences->General->Appearance->Label Decorators->disable "Task Context Decorator"
Previous Topic:Eclipse Bugzilla users announcement
Next Topic:Why nothing listed in the task list (using XPlanner 0.7b connector)?
Current Time: Sat Jul 19 06:01:09 EDT 2025
Powered by FUDForum. Page generated in 0.04460 seconds
