Enumerating EObject instances in a model [message #68107] |
Mon, 15 January 2007 10:26  |
Originally posted by: kalin.nakov.gmail.com
I have an EMF model loaded (in the case it's in a GMF diagram). The
metamodel consists of class MyClassA and class MyClassB which has a
reference MyClassB.myReferenceToA which points to an instance of A. I
have an EObject (instance of class MyClassA called myInstanceA). How can
I find the instance of class MyClassB in the model which has the
reference myReferenceToA which equals myInstanceA?
Thanks in advance,
Kalin
Re: Enumerating EObject instances in a model [message #68135 is a reply to message #68107] |
Mon, 15 January 2007 18:05  |
Hi, Kalin,
This question is more appropriate for the EMF newsgroup, being a core EMF
problem.
Luckily, I can answer it! Use the getNonNavigableInverseReferences(EObject)
method of an ECrossReferenceAdapter (which you have previously attached to
your object tree, resource, or resource set.
HTH,
Christian
Kalin Nakov wrote:
> Thanks in advance,
> Kalin
Re: Enumerating EObject instances in a model [message #601244 is a reply to message #68107] |
Hi, Kalin,
problem.
HTH,
Christian
Kalin Nakov wrote:
> Thanks in advance,
> Kalin
FUDForum. Page generated in 0.05662 seconds
