Home » Eclipse Projects » Mylyn » Mylyn Wiki Help
Mylyn Wiki Help [message #489208] |
Thu, 01 October 2009 16:17  |
Hi guys,
I really like the approach you've taken with auto-updating
( http://greensopinion.blogspot.com/2008/11/mylyn-converts-wik i-based-user-guide-to.html)
from community maintainable wiki. I want to adopt it for AMP
I note that you have the User Guide all on one page. This works great
for User Guide as the .toc geenration allows users to look at just one
sub-section. But I'm wondering if on Wiki side for AMP it wouldn't be
better to have this organized by section as well -- if the user guide
get's really long it could present loading issues and make it harder
for users to reference and find relevant sections. Do you think it
would be difficult to set up the ant cripts so that they built from a
hierachy instead?
Anything you would have done differently if you were starting over?
Re: Mylyn Wiki Help [message #489433 is a reply to message #489430] |
Fri, 02 October 2009 19:23   |
Following up on my own post, an even simpler approach would be to
specify one "official" UserGuide/Contents page. Then the ant script
could very easily parse that and generate any document format from it.
Plus it would be a nice resource for Wiki readers.
On 2009-10-02 16:16:01 -0700, Miles Parker <milesparker@gmail.com> said:
> Thanks for all the links -- extremely helpful.
> On 2009-10-02 15:27:16 -0700, David Green <dgreen99@gmail.com> said:
>> You'll find that Eclipse help has some really neat facilities with
>> anchors and links: you can compose almost any structure in the Eclipse
>> help table of contents with multiple documents. This means that you
>> should be able to break your user guide into multiple documents with
>> some tweaking of help toc.xml files.
> Yeah, makes sense. It would be nice to not have to maintain the toc
> though. The really great thing about the current Mylyn approch is that
> you don't have to do *anything* whereas if you are using document
> hierarchy you've got to maintain that linkage manually. Which means
> that if a user adds a new page, that's not going to show up. But it
> seems that it wouldn't be too hard to setup a script to say grab every
> document under wiki.eclipse.org/myproject/UserGuide, convert it, and
> then generate a toc for it. You could avoid all of the doc book
> assembly by simply organizing the documentation hierachrchiaclly, e.g.
> UserGuide/Overview/..
> UserGuide/Getting_Started/..
> With the assumption that everything at a given level is within same
> document (sub)section. Then you would simply have say one Contents Page
> at each level that would define the ordering within that section. but
> it seems that it would at least handle the cannonical case. I'm
> thinking that anything that can be done to give Wiki users full control
> over the end state of the documentation is to the good. Perhaps someone
> has already thought of all that..
>> As far as I know XText is using WikiText to produce their documentation
>> from wiki format, using DocBook as an intermediary form.
> I was thinking that must be the case.
> BTW, have you thought about any possiblity of providing editing for
> online content from WikiText? I didn't see anything on this anywhere
> and I don't know if it is even a reasonable thing to do WRT to the Wiki
> side of things.
Re: Mylyn Wiki Help [message #502868 is a reply to message #491852] |
Thu, 10 December 2009 00:38   |
Peter Friese wrote on Fri, 16 October 2009 04:18 |
That's right, the Xtext team uses WikiText do write their documentation and we're *very* satisfied with it. If you're intersted, here is the link to our build script: ...
Although it would be great to use the Eclipse wiki to crowdsource the documentaiton, we decided against that. Mainly due to the somehow cumbersome syntax of MediWiki. Or, to express it in a more positive way: we like Textile syntax
Cool, thanks a lot for the links Peter, very helpful. Just a quick question for this thread. So you're actually doing something like:
textile -> wiki
textile -> Eclipse docs
as opposed to
wiki -> Eclipse Docs
And as a genral addendum, I've got doc sections seperated now, but I'm thinking of re-integrating them as even on Wiki it's surprisingly difficult to navigate between sections and I'm finding I'm having to spend a fair amount of time maintaining the references between TOC, overview and sections. Sure seems like it might be sipler to have one big page for each of the major components as Mylyn and XText seem to be doing.
Re: Mylyn Wiki Help [message #502870 is a reply to message #502868] |
Thu, 10 December 2009 01:50   |
Miles Parker wrote on Thu, 10 December 2009 00:38 | Peter Friese wrote on Fri, 16 October 2009 04:18 |
textile -> wiki
as opposed to
Not quite. We do
textile (files stored on workspace, resp. CVS) -> docbook -> PDF
textile (files stored on workspace, resp. CVS) -> docbook -> Eclipse Help
textile (files stored on workspace, resp. CVS) -> docbook -> HTML
We were considering writing our documentation on the Eclipse wiki and the transform (wiki -> docbook -> [PDF|HTML|Eclipse Help], but decided against this approach for the following reasons:
- Textile syntax is much more concise than any other Wiki markup, including the dialect being used on the Eclipse wiki
- We needed to introduce special syntax for linking to files in Eclipse CVS, this was easier with WikiText / Textile.
Quote: |
And as a genral addendum, I've got doc sections seperated now, but I'm thinking of re-integrating them as even on Wiki it's surprisingly difficult to navigate between sections and I'm finding I'm having to spend a fair amount of time maintaining the references between TOC, overview and sections. Sure seems like it might be sipler to have one big page for each of the major components as Mylyn and Xtext seem to be doing.
We use a text file to configure the structure of the entire document. This works very well.
Re: Mylyn Wiki Help [message #599381 is a reply to message #489430] |
> side of things.
Re: Mylyn Wiki Help [message #600163 is a reply to message #599718] |
> Although it would be great to use the Eclipse wiki to crowdsource the documentaiton, we decided against that. Mainly due to the somehow cumbersome syntax of MediWiki. Or, to express it in a more positive way: we like Textile syntax :)
textile -> wiki
as opposed to
Re: Mylyn Wiki Help [message #600168 is a reply to message #600163] |
> textile -> wiki
> as opposed to
Not quite. We do
Current Time: Sat Jul 19 05:40:52 EDT 2025
Powered by FUDForum. Page generated in 0.67858 seconds
