Home » Archived » EPF » Using EPF RichText Feature in Ubuntu
Using EPF RichText Feature in Ubuntu [message #599300] Fri, 26 March 2010 17:16
I'm trying to use the separate RichText Feature (1.5.04) in Ubuntu 9.04. And I'm facing the problem that both Tabs - RichText and Html are not automatically synchronized. In partucular the changes that I make to a document in the RichText tab are not transfered to the Html. So when I switch to Html and afterwards back to RichText all the changes that I've made disappear.
I'm trying to synchronize them using a ModifyListener, which correctly identifies changes when I type in the RichText tab, but still both RichTextEditor.getText() and RichText.getText() return an empty String.
I am usind the Feature in a RCP Application and under Windows the synchronization works as expected. The problem appears, when I use it under Linux. So I assume it is some dependency of the underlying native browser.
Did someone face such problem and find a solution for it?
Previous Topic:Using EPF RichText Feature in Ubuntu
Next Topic:EPF model transformation problem with Multi file xmi resources
Current Time: Sat Jul 19 19:05:08 EDT 2025
Powered by FUDForum. Page generated in 0.23124 seconds
