Problems encountered in file "pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml" [message #598296] |
Wed, 07 March 2007 04:48 |
I open a .uml file with the uml plugin version UML2 2.1.0.v200702012039
And I always geht the errors:
Thanx in advice.
Chris
MalformedURLException: unknown protocol: pathmap
java.net.MalformedURLException: unknown protocol: pathmap
at java.net.URL.<init>(Unknown Source)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createU RLInputStream(URIConverterImpl.java:557)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:442)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:962)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObje ct(ResourceSetImpl.java:217)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java: 197)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java: 257)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(Ba sicEObjectImpl.java:1460)
at
org.eclipse.uml2.uml.internal.impl.PackageImportImpl.getImpo rtedPackage(PackageImportImpl.java:208)
at
org.eclipse.uml2.uml.edit.providers.PackageImportItemProvide r.getText(PackageImportItemProvider.java:161)
at
org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider .getColumnText(AdapterFactoryLabelProvider.java:276)
at
org.eclipse.jface.viewers.TableColumnViewerLabelProvider.upd ate(TableColumnViewerLabelProvider.java:74)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:137)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:149)
at
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:98)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:850)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:45)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:15 3)
at
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:894)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:465)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1983)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:798)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:776)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:750)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:622)
at
org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1302)
at
org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:877)
at
org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1313)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:181)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:6638)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4263)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:14 80)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:3916)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3424 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4134 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:209 0)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1371)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:5473)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3405 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5052)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4147 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:21 76)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3077)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1945)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1909)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:425)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hod(EclipseAppContainer.java:522)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:147)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:104)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:170)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:339 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:283)
at org.eclipse.core.launcher.Main.run(Main.java:984)
at org.eclipse.core.launcher.Main.main(Main.java:959)
FUDForum. Page generated in 0.03991 seconds
