Is it possible to change the product (Bugzilla) [message #67221] |
Tue, 24 March 2009 15:23  |
Hi all,
for my project it is a common usecase to change the product a bug is
assigned to. Unfortunately it does not seem possible to do so in our setup.
When I visited http://tasktop.com/products/eclipse/ I saw that the
product was editable in the upper screenshot.
My question is now: What are the prerequisites for the the product to be
editable in a bugzilla environment?
We use eclipse Ganymede SR2, mylyn 3.2 and bugzilla 3.0.4.
Thanks in advance
Markus Plail
Re: Is it possible to change the product (Bugzilla) [message #67315 is a reply to message #67295] |
Fri, 27 March 2009 15:09  |
> ^^^^ should have been 3.1
>> you need Mylyn 3.1 to have this. Version 3.2 is not released. What Mylyn
>> Version did you use?
>> The actual weekly build is 3.2.0.I20090325-0500-e3x. If you did have this it
>> should work.
> I upgraded to 3.2 weekly build, but still couldn't change the product.
> Then I deleted my repository and added it again and - surprise, surprise
> - I can change the product. Seems my metadata was too old or there went
> something wrong upgrading it.
> So it works now and I am happy not having to use the web frontend to do
> it. Thank you for your help.
> regards
> Markus
OK now I know what was the source of the problem.
The Product Attribute was readonly. Sync the Task should have worked to.
regards
Frank
Re: Is it possible to change the product (Bugzilla) [message #597056 is a reply to message #67221] |
Thu, 26 March 2009 12:00  |
Really no one with an explanation or am I just missing something obvious?
regards
Markus
Re: Is it possible to change the product (Bugzilla) [message #597083 is a reply to message #67221] |
Thu, 26 March 2009 17:43  |
> Hi all,
Hi Markus,
should work.
Frank
> Thanks in advance
> Markus Plail
Re: Is it possible to change the product (Bugzilla) [message #597110 is a reply to message #67259] |
Fri, 27 March 2009 11:38  |
> should work.
regards
Markus
Re: Is it possible to change the product (Bugzilla) [message #597130 is a reply to message #67295] |
>> should work.
> regards
> Markus
regards
Frank
FUDForum. Page generated in 0.07668 seconds
