Home » Archived » XML Schema Definition (XSD) » attribute reference unresolved - must be basic answer
attribute reference unresolved - must be basic answer [message #594759] Wed, 20 April 2005 10:54
during installation of the eclipse subversion plugin, I 'inherited' the
XSD plugin too. Now my eclipse 'problems' list is showing errors in
schemas in my project.
I have googled and searched this mailing list without finding a
solution. Perhaps someone can recognise what basic mistake I'm making -
and I'm sure it must be basic :(
XSD: Attribute reference 'http://www.w3.org/XML/1998/namespace#lang' is
unresolved
comes from this line of schema:
<xs:attribute ref="xml:lang" default="en"/>
which imports the schema mentioned in the error msg like so:
<xs:import namespace="http://www.w3.org/XML/1998/namespace"
schemaLocation="http://www.w3.org/2001/xml.xsd"/>
I have actually downloaded the xml.xsd schema and placed it in the same
directory, and I have this directory loaded as a class folder resource
in the .classpath for my project like so:
<classpathentry kind="lib" path="docs/Design/schemas"/>
Adam
Previous Topic:How to test if a type is a base type ?
Next Topic:How to check if a simple type is a restriction of a base type ?
Current Time: Sat Jul 19 18:18:38 EDT 2025
Powered by FUDForum. Page generated in 0.02597 seconds
