Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem getting all files/folders when unpack="true"
Problem getting all files/folders when unpack="true" [message #592886] Thu, 05 March 2009 20:20
I have a plugin (JUnit Max, to be precise) that needs to unpack when it is
installed. (It contains a jar file and you can't have a jar in a jar.) I
set the "Unpack plugin archive after the installation" checkbox in the
feature.xml GUI (I also tried manually setting unpack="true" feature.xml).
In either case, the plugins directory contains a directory for my plugin,
but the icons directory inside my plugin does not appear in the resulting
directory. The icons directory and its contents are there in the plugin
jar file.
This happens in 3.4 and 3.5M4.
Any suggestions for what I should do differently? Is this pilot error or
an Eclipse defect? I tried tracing the code that is invoked when a plugin
is installed, but after a day I'm done.
Kent Beck
Three Rivers Consulting, Inc.
www.junitmax.com/junitmax
Previous Topic:Contributed Ant task, headless behaviour changed 3.3.2 -> 3.5M5
Next Topic:Export Wizard fails
Current Time: Sat Jul 19 08:38:21 EDT 2025
Powered by FUDForum. Page generated in 0.07883 seconds
