call transformation from Java API [message #589761] |
Fri, 05 March 2010 08:19  |
When running the TestAPI.java , there is NullPointer exception and the problem is located in the following lines.
protected int parse (String transformation) {
File f = new File (transformation);
MOFScriptSpecification spec = parserUtil.parse(f, true);
The debugging shows that f is null , and parserUtil is null too. And specification of the parserUtil used in this program couldn't be found. We run out of any possible solutions. What's the problem and any way to solve this problem. Thanks for reply!
M
FUDForum. Page generated in 0.25175 seconds
