Ping Failed Derby Connection [message #589363] |
Sat, 15 December 2007 14:53 |
Dear all,
I have a problem with getting the Apache Derby example up and running.
I installed Apache Derby, I am not sure what I should do with the
classpath. I created the DERBY_INSTALL environment variable.
I followed these steps:
- created the driver definition: it is a bit strange but the driver for
the latest version of derby is not available, selected the available one.
I used the embedded JDBC driver
- I assigned the location where the derby.jar of my apache derby
installation is located and the location where I am going to store my
databases
- Then I created a connection profile. When I press the button test
connection I get a message Ping failed
Here are the details:
java.sql.SQLException: Failed to create database
'C:\DataFiles\DerbyDatabases', see the next exception for details.
at
org.apache.derby.impl.jdbc.SQLExceptionFactory40.getSQLExcep tion(Unknown
Source)
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.Util.seeNextException(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Un known
Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection30.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.EmbeddedDriver.connect(Unknown Source)
at
org.eclipse.datatools.connectivity.db.generic.JDBCConnection .createConnection(JDBCConnection.java:87)
at
org.eclipse.datatools.connectivity.db.derby.DerbyEmbeddedJDB CConnection.createConnection(DerbyEmbeddedJDBCConnection.jav a:136)
at
org.eclipse.datatools.connectivity.DriverConnectionBase.inte rnalCreateConnection(DriverConnectionBase.java:104)
at
org.eclipse.datatools.connectivity.DriverConnectionBase.open (DriverConnectionBase.java:53)
at
org.eclipse.datatools.connectivity.db.derby.DerbyJDBCConnect ionFactory.createConnection(DerbyJDBCConnectionFactory.java: 32)
at
org.eclipse.datatools.connectivity.internal.ConnectionFactor yProvider.createConnection(ConnectionFactoryProvider.java:77 )
at
org.eclipse.datatools.connectivity.internal.ConnectionProfil e.createConnection(ConnectionProfile.java:354)
at org.eclipse.datatools.connectivity.ui.PingJob.run(PingJob.ja va:57)
Caused by: java.sql.SQLException: Failed to create database
at org.apache.derby.impl.jdbc.SQLExceptionFactory.getSQLExcepti on(Unknown
Source)
at
org.apache.derby.impl.jdbc.SQLExceptionFactory40.wrapArgsFor TransportAcrossDRDA(Unknown
Source)
... 19 more
Caused by: java.sql.SQLException: Directory C:\DataFiles\DerbyDatabases
already exists.
Source)
at
Source)
at
Source)
at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unkno wn Source)
at
org.apache.derby.impl.jdbc.TransactionResourceImpl.wrapInSQL Exception(Unknown
Source)
at
org.apache.derby.impl.jdbc.TransactionResourceImpl.handleExc eption(Unknown
Source)
at org.apache.derby.impl.jdbc.EmbedConnection.handleException(U nknown
Source)
... 16 more
Caused by: ERROR XBM0J: Directory C:\DataFiles\DerbyDatabases already
exists.
at org.apache.derby.iapi.error.StandardException.newException(U nknown
Source)
at
org.apache.derby.impl.services.monitor.StorageFactoryService $9.run(Unknown
Source)
at
org.apache.derby.impl.services.monitor.StorageFactoryService .createServiceRoot(Unknown
Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootServi ce(Unknown
Source)
at
org.apache.derby.impl.services.monitor.BaseMonitor.createPer sistentService(Unknown
Source)
at
org.apache.derby.iapi.services.monitor.Monitor.createPersist entService(Unknown
Source)
... 16 more
Can somebody explain me what is wrong ?
kind regards,
Danny
FUDForum. Page generated in 0.03020 seconds
