SQL Editor Syntax Error [message #35361] |
Thu, 23 August 2007 07:07  |
we work on Derby Network with DTP 1.5.1 (and previous).
With ij we create the database from DDL we use.
But when i want to use SQL Editor (with cinnection info) to Execute the
DDL we have this error Syntax error: Encountered ";".
Can someone help me?
PS I have tried enablind and disabling sysntax checking but i had the same
results
Massimo Montecchi
BS Company Srl
Re: SQL Editor Syntax Error [message #37230 is a reply to message #36141] |
Sun, 14 October 2007 13:50  |
Originally posted by: bmf1972.fastmail.fm
Seems to be the same problem with MySQL.
Adrian.
Hui Cao wrote:
> Hi Massimo,
> I think your request does make sense. Can you open a bugzilla to track
> this problem for Derby enablement? I'll find a time to look into it. Thanks!
Re: SQL Editor Syntax Error [message #587600 is a reply to message #35361] |
Fri, 24 August 2007 00:26  |
Can you try to terminate each SQL statement with a ";" in a new line
instead of just by appending ";" at the end of the statement? ( I suppose
this can be done by a batch replace: ";(\r\n)"->"$1;$1" in SQL editor )
Semicolon is not part of the Derby grammar and won't be accepted by the
server, and by default SQL editor only filters out statement
terminators(";") in a standalone line.
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
"Massimo Montecchi" <massimo.montecchi@bs-company.com> wrote in message
news:62045b3fe7d206664d23260b44371062$1@www.eclipse.org...
> results
> Thanks
> Massimo Montecchi
> BS Company Srl
Re: SQL Editor Syntax Error [message #587822 is a reply to message #35429] |
Tue, 04 September 2007 11:04  |
Hi Max (Hui),
the hint you give to me it works!!!
But I think it's not so useful that SQL Editor check the end statement
only in a new line.
Think about using DTP for all the development fase: i mean, that we
develop the db DDL from the DTP plugin and when you estract the DDL from
DTP the file.sql you have is with ; at the end of every sql line!!!
Massimo Montecchi
BS Company Srl
Re: SQL Editor Syntax Error [message #587832 is a reply to message #36108] |
Fri, 07 September 2007 00:43  |
Hi Massimo,
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
news:5149a6a22050ffa751ccacdf468f360f$1@www.eclipse.org...
> Hi Max (Hui),
> only in a new line.
> Thanks
> Massimo Montecchi
> BS Company Srl
Re: SQL Editor Syntax Error [message #588180 is a reply to message #36141] |
Adrian.
Hui Cao wrote:
> Hi Massimo,
FUDForum. Page generated in 0.05398 seconds
