Home » Eclipse Projects » DTP » Getting connection profile content
Getting connection profile content [message #36374] Mon, 17 September 2007 10:28 Go to next message
I am now able to successfully get a handle on a particular
IConnectionProfile via the ProfileManager object.
How can I get the meta data content from that connection profile and use it
in another plugin (rather than just viewing it as a user)?
Obviously, I must connect first.
Chuck
Re: Getting connection profile content [message #36401 is a reply to message #36374] Mon, 17 September 2007 13:34 Go to previous messageGo to next message
Let me be more specific:
How can I get a handle on a
(org.eclipse.datatools.modelbase.sql.schema.)Database object
given a connection profile?
Chuck
"Chuck Doucette" <cdoucette@vaultus.com> wrote in message
news:fcm30k$8al$1@build.eclipse.org...
> it in another plugin (rather than just viewing it as a user)?
> Chuck
Re: Getting connection profile content [message #36421 is a reply to message #36401] Tue, 18 September 2007 02:36 Go to previous messageGo to next message
Originally posted by: hui.cao.sybase.ocm
In SQL Dev Tools, we have a utility method ProfileUtil.getDatabase, which
does exactly what you want, although this is not API and we can not
guarantee its stability. In fact, you can see that the parameter
DatabaseIdentifier asks more than what this method needs: a profile name is
sufficient. So we'll overload this method with a profileName as the
parameter later.
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
news:fcmdsc$3sv$1@build.eclipse.org...
> Chuck
>> Thanks,
>> Chuck
Re: Getting connection profile content [message #36438 is a reply to message #36421] Tue, 18 September 2007 11:53 Go to previous message
I believe this method or a similar one should be part of the public API -
don't you?
If you want people to leverage the work that you've done, then you should be
able to programmatically access the contents of the connection profile (not
just as a user).
I'm just trying to figure out the best way to do that.
Thank you very much for your help.
Chuck
"Hui Cao" <hui.cao@sybase.ocm> wrote in message
news:fcnrl2$knd$1@build.eclipse.org...
> is sufficient. So we'll overload this method with a profileName as the
> parameter later.
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>> Thanks,
>> Chuck
>>> Thanks,
>>> Chuck
Re: Getting connection profile content [message #587912 is a reply to message #36374] Mon, 17 September 2007 13:34 Go to previous message
Chuck
> Chuck
Re: Getting connection profile content [message #587923 is a reply to message #36401] Tue, 18 September 2007 02:36 Go to previous message
parameter later.
Best Regards!
Max (Hui) Cao
Sybase Shanghai RD
> Chuck
>> Thanks,
>> Chuck
Re: Getting connection profile content [message #587931 is a reply to message #36421] Tue, 18 September 2007 11:53 Go to previous message
don't you?
just as a user).
Chuck
> parameter later.
> Best Regards!
> Max (Hui) Cao
> Sybase Shanghai RD
>> Thanks,
>> Chuck
>>> Thanks,
>>> Chuck
Previous Topic:Getting connection profile content
Next Topic:Connect just hangs
Current Time: Sun Jul 20 04:31:32 EDT 2025
Powered by FUDForum. Page generated in 0.05872 seconds
