Home » Modeling » Epsilon » [Eugenia] @gmf.diagram Annotations ignored
[Eugenia] @gmf.diagram Annotations ignored [message #518505] Thu, 04 March 2010 05:29 Go to next message
Moin, moin,
I'm using Eclipse Modelling Package 20090920-1017 with Eugenia 0.8.8.200910281243 and Emfatic 0.3.0.200810132307
The GMF generation works fine but the gmf.diagram annotations are ignored (while others like @gmf.node or @gmf.link are working):
@gmf.diagram(onefile="true", diagram.extension="sgraph", units="Pixels")
class SGraph {
  val Node[*] nodes;
  val Edge[*] edges;
The annotations are transfered correctly by Emfatic to the sgraph.ecore model.
Does anybody have a clue what's wrong ?
Re: [Eugenia] @gmf.diagram Annotations ignored [message #518522 is a reply to message #518505] Thu, 04 March 2010 06:33 Go to previous messageGo to next message
--------------000701020409000106060600
I haven't actually worked with Eugenia yet, so this could be wrong. But
could it be that
should really be
@gmf.diagram(onefile="true", extension="sgraph", units="Pixels")
Steffen
Content-Type: text/html; charset=UTF-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Hi,<br>
<br>
could it be that <br>
<br>
<blockquote cite="mid:hmo21k$98v$1@build.eclipse.org" type="cite">@gmf.diagram(onefile="true",
<br>
</blockquote>
should really be<br>
<blockquote>
<pre>@gmf.diagram(onefile="true", extension="sgraph", units="Pixels")
</pre>
</blockquote>
?<br>
<br>
Steffen<br>
</body>
</html>
--------------000701020409000106060600--
Re: [Eugenia] @gmf.diagram Annotations ignored [message #518533 is a reply to message #518522] Thu, 04 March 2010 07:06 Go to previous messageGo to next message
Hi Ralf,
What do you mean when you say that they are ignored i.e. what are the
symptoms you're observing?
Dimitris
Steffen Zschaler wrote:
> could it be that
> should really be
> Steffen
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: [Eugenia] @gmf.diagram Annotations ignored [message #518578 is a reply to message #518533] Thu, 04 March 2010 09:40 Go to previous messageGo to next message
Dimitrios Kolovos wrote on Thu, 04 March 2010 07:06
Hi Ralf,
Dimitris
Well, the generated editor uses "two files", the extensions are "sgraph" and "sgraph_diagram" and the default units are "Inches".
Re: [Eugenia] @gmf.diagram Annotations ignored [message #518579 is a reply to message #518522] Thu, 04 March 2010 09:43 Go to previous messageGo to next message
Steffen Zschaler wrote on Thu, 04 March 2010 06:33
could it be that
should really be
I'm referring to http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-gmf- tutorial/ and there it says:
gmf.diagram
Denotes the root object of the metamodel. Only one (non-abstract) EClass must be annotated as gmf.diagram. Accepts the following details
    * onefile (optional) : a value of true specifies that the domain model and the diagram should be stored in the same file
    * model.extension (optional) : the file extension for the domain model
    * diagram.extension (optional) : the file extension for the diagram file
    * units (optional) : the units for the diagram (e.g. Pixels)
Re: [Eugenia] @gmf.diagram Annotations ignored [message #518602 is a reply to message #518579] Thu, 04 March 2010 05:42 Go to previous messageGo to next message
Hi Ralf,
Could it be the case that you're not performing the following step?
"Right click the generated .gmfgen model and select Eugenia->Synchronize
GMF gen model"
If this is not the case, could you please send me your .emf metamodel
(dskolovos _ gmail _ com) so that I can have a closer look?
Dimitris
>> Hi,
>> But could it be that
>> units="Pixels")
>> should really be
> I'm referring to
> and there it says:
> gmf.diagram
Re: [Eugenia] @gmf.diagram Annotations ignored [message #518725 is a reply to message #518602] Thu, 04 March 2010 15:07 Go to previous messageGo to next message
Dimitrios Kolovos wrote on Thu, 04 March 2010 05:42
Hi Ralf,
GMF gen model"
Hi Dimitrios,
Oh, sh** ...
I remember having done this Synchronize step on the first day following the tutorial and forgot the step feeling familiar with the building process the next days. It's my fault, I'm sorry! Thanx for the help.
Cu - Ralf.
Re: [Eugenia] @gmf.diagram Annotations ignored [message #586977 is a reply to message #518505] Thu, 04 March 2010 06:33 Go to previous messageGo to next message
could it be that
should really be
Steffen
<html>
<head>
</head>
Hi,<br>
<br>
<br>
<br>
</blockquote>
<blockquote>
</pre>
</blockquote>
?<br>
<br>
Steffen<br>
</body>
</html>
Re: [Eugenia] @gmf.diagram Annotations ignored [message #586990 is a reply to message #518522] Thu, 04 March 2010 07:06 Go to previous messageGo to next message
Hi Ralf,
Dimitris
> could it be that
> should really be
> Steffen
Re: [Eugenia] @gmf.diagram Annotations ignored [message #587012 is a reply to message #518533] Thu, 04 March 2010 09:40 Go to previous messageGo to next message
> Hi Ralf,
> Cheers,
> Dimitris
Re: [Eugenia] @gmf.diagram Annotations ignored [message #587024 is a reply to message #518522] Thu, 04 March 2010 09:43 Go to previous messageGo to next message
> could it be that
> should really be
gmf.diagram
Re: [Eugenia] @gmf.diagram Annotations ignored [message #587033 is a reply to message #518579] Thu, 04 March 2010 10:33 Go to previous messageGo to next message
Hi Ralf,
GMF gen model"
Dimitris
>> Hi,
>> units="Pixels")
>> should really be
> I'm referring to
> and there it says:
> gmf.diagram
Re: [Eugenia] @gmf.diagram Annotations ignored [message #587057 is a reply to message #587033] Thu, 04 March 2010 15:07 Go to previous message
> Hi Ralf,
> GMF gen model"
Hi Dimitrios,
Oh, sh** ...
Cu - Ralf.
Previous Topic:How to list all the wizards registered in Epsilon?
Next Topic:EVL is not working.
Current Time: Sat Jul 19 15:45:31 EDT 2025
Powered by FUDForum. Page generated in 0.49946 seconds
