Re: 3.5M3 crashes Invalid memory access of location [message #585942] |
Thu, 27 November 2008 01:14 |
Originally posted by: ekkehard.gentz-software.de
I made some more tests
seems that the IDE and the workspace - projects itself are are all well
so 3.5M3 at IDE - level works
....think there's something wrong in my target platform,
which I also tried to build new from 3.5M3
now a question:
is there a way to startup a workspace without using last Target Platform
? something like -cleantargetplatform
ekke
ekke schrieb:
> dont know if this is the right newsgroup
> I'm just trying to make my projects run under 3.5M3
> MacOSX 10.5.5, JDK 1.5, carbon
> just thaught I was ready, but after restarting my workspace
> (was a fresh workspace and all projects new copied into the workspace)
> eclipse crashes
> I can open a new workspace, but switching to the problematic workspace
> it crashes again
> its a workspace with a target platform and many project
> if no one has an idea I'll try tomorrow again to build the workspace
> perhaps someone has an idea ?
> THX
> ekke
> 26.11.08 22:33:10 [0x0-0x46046].org.eclipse.eclipse[367]
> org.eclipse.core.runtime.AssertionFailedException: assertion failed:
> 26.11.08 22:33:10 [0x0-0x46046].org.eclipse.eclipse[367] at
> org.eclipse.core.runtime.Assert.isTrue(Assert.java:111)
> org.eclipse.core.runtime.Assert.isTrue(Assert.java:97)
> org.eclipse.jface.text.source.AnnotationModel.getRegionAnnot ationIterator(AnnotationModel.java:741)
> org.eclipse.jface.text.source.AnnotationModel.getAnnotationI terator(AnnotationModel.java:699)
> org.eclipse.jface.text.source.AnnotationRulerColumn.doPaint1 (AnnotationRulerColumn.java:699)
> org.eclipse.jface.text.source.AnnotationRulerColumn.doubleBu fferPaint(AnnotationRulerColumn.java:513)
> org.eclipse.jface.text.source.AnnotationRulerColumn.access$3 (AnnotationRulerColumn.java:489)
> org.eclipse.jface.text.source.AnnotationRulerColumn$1.paintC ontrol(AnnotationRulerColumn.java:280)
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:217)
> org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1566)
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1590)
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1575)
> org.eclipse.swt.widgets.Control.drawWidget(Control.java:850)
> org.eclipse.swt.widgets.Canvas.drawWidget(Canvas.java:114)
> org.eclipse.swt.widgets.Widget.kEventControlDraw(Widget.java :1069)
> org.eclipse.swt.widgets.Canvas.kEventControlDraw(Canvas.java :191)
> org.eclipse.swt.widgets.Widget.controlProc(Widget.java:370)
> org.eclipse.swt.widgets.Display.controlProc(Display.java:862 )
> org.eclipse.swt.internal.carbon.OS.ShowWindow(Native Method)
> org.eclipse.swt.widgets.Shell.setWindowVisible(Shell.java:17 92)
> org.eclipse.swt.widgets.Shell.setVisible(Shell.java:1764)
> org.eclipse.swt.widgets.Shell.open(Shell.java:1298)
> org.eclipse.jface.window.Window.open(Window.java:797)
> org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow .java:778)
> org.eclipse.ui.internal.Workbench$61.runWithException(Workbe nch.java:3394)
> org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
> org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
> org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3342)
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3071)
> org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
> org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
> org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:333)
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:370)
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> java.lang.reflect.Method.invoke(Method.java:585)
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> 26.11.08 22:33:10 [0x0-0x46046].org.eclipse.eclipse[367] Invalid memory
> access of location 00000009 eip=910e9d14
FUDForum. Page generated in 0.03720 seconds
