Home » Modeling » Epsilon » Incorrect access to model in ubuntu
Incorrect access to model in ubuntu [message #507126] Mon, 11 January 2010 23:27 Go to next message
Hi, I am trying to validate a model using evl in Ubuntu 9.04 and Eclipse Galileo. When validating I get a message that says
Resource 'xxx' does not exist. (xxx is a file path)
The file exists and debugging the execution I found that in the class EmfModel the instruction this.modelFileUri = EmfUtil.createURI(modelFile); returns the URI with "platform:/resource" before the valid path.
Inside the method createURI() I see that these lines are commented:
// Handle paths that start with / under Unix e.g. /local/foo.txt
//else if (OperatingSystem.isUnix() && s.startsWith("/")) {
// return URI.createFileURI(s);
Could be my problem because that?
Raul
Re: Incorrect access to model in ubuntu [message #507139 is a reply to message #507126] Mon, 11 January 2010 23:52 Go to previous messageGo to next message
Hi Raul,
Are you launching the validation through the UI or through Java code?
Dimitris
> before the valid path. Inside the method createURI() I see that these
> Best regards,
> Raul
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Incorrect access to model in ubuntu [message #507150 is a reply to message #507139] Tue, 12 January 2010 05:31 Go to previous messageGo to next message
Hi Dimitrios,
I am working with Raul in the same project. The validation is launched through java code.
Hector
Re: Incorrect access to model in ubuntu [message #507161 is a reply to message #507150] Tue, 12 January 2010 05:35 Go to previous messageGo to next message
Hi Hector,
To be on the safe side when loading EMF models from Java, you should use
the complete URI (e.g. file:/foo/bar.model,
platform:/resource/foo/bar.model)
Dimitris
H wrote:
> Hi Dimitrios,
> through java code.
> Best regards,
> Hector
Re: Incorrect access to model in ubuntu [message #507186 is a reply to message #507161] Tue, 12 January 2010 07:25 Go to previous messageGo to next message
What do you mean with "safe side"?
Let's specify a little more the problem.
I call the evl validation through java using a plugin, and in order to do that I launch a second Eclipse instance where the models are. In Windows I have never had this issues (still haven't) but when running the tests from Linux I get this error. In Windows createURI does not add the prefix "platform:/resource", does it mean it has no need of keeping in the safe side?
/foo/bar.model is an absolute path, doesn't it? Or should I give workspace relative paths in Linux?
Many thanks,
Hector
Re: Incorrect access to model in ubuntu [message #507229 is a reply to message #507186] Tue, 12 January 2010 10:00 Go to previous messageGo to next message
I reply to myself:
I have made it work changing the given path from an absolute path to a workspace relative path. Now, using the epsilon OperativeSystem utilities I change the path of the model depending on the S.O. of the computer.
Is this the correct way or would it be fixed?
Hector
Re: Incorrect access to model in ubuntu [message #507238 is a reply to message #507229] Tue, 12 January 2010 10:12 Go to previous message
That sounds right.
Dimitris
Hector wrote:
> I reply to myself:
> computer.
> Best regards,
> Hector
Re: Incorrect access to model in ubuntu [message #584681 is a reply to message #507161] Tue, 12 January 2010 07:25 Go to previous message
Many thanks,
Hector
Re: Incorrect access to model in ubuntu [message #584695 is a reply to message #507186] Tue, 12 January 2010 10:00 Go to previous message
I reply to myself:
Hector
Re: Incorrect access to model in ubuntu [message #584711 is a reply to message #584695] Tue, 12 January 2010 10:12 Go to previous message
That sounds right.
Dimitris
Hector wrote:
> I reply to myself:
> computer.
> Best regards,
> Hector
Previous Topic:Incorrect access to model in ubuntu
Next Topic:problems with ETL
Current Time: Sat Jul 19 10:28:21 EDT 2025
Powered by FUDForum. Page generated in 0.05769 seconds
