Home » Eclipse Projects » DSDP - Target Management » Eclipse hang up. Suspecting RSE...
Eclipse hang up. Suspecting RSE... [message #583600] Thu, 22 July 2010 04:29 Go to next message
I had encountered the situation when eclipse hangs up when starting.
I was playing with creating projects using RSE.
I had tried to create couple projects and since this creation took a long time (to syncronize, i suppose) I had aborted the process. Nevertheless I have 1 remote project currently.
Below is the stack trace.
Could someone guess what is the root cause of the issue or how can I further discover it?
Dmitry
6636 eclipse.exe ( Eclipse SDK ) session:0 threads:25 parent:6248
2010-07-22 11:36:19
Full thread dump Java HotSpot(TM) Client VM (16.3-b01 mixed mode):
"StackTrace Remote Thread" prio=6 tid=0x04328c00 nid=0x1c68 waiting on condition [0x00000000]
java.lang.Thread.State: RUNNABLE
"[ThreadPool Manager] - Idle Thread" daemon prio=6 tid=0x03a5b800 nid=0x18f0 in Object.wait() [0x067ff000]
java.lang.Thread.State: WAITING (on object monitor)
at java.lang.Object.wait(Native Method)
- waiting on <0x096587b0> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or)
at java.lang.Object.wait(Object.java:485)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or.run(Executor.java:106)
- locked <0x096587b0> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or)
"Bundle File Closer" daemon prio=6 tid=0x05708400 nid=0x5d8 in Object.wait() [0x066ff000]
- waiting on <0x0891b268> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextEvent(EventManager.java:397)
- locked <0x0891b268> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:333)
"Java indexing" daemon prio=4 tid=0x0571f400 nid=0x181c in Object.wait() [0x065ff000]
- waiting on <0x080cf8b0> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
at org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:381)
- locked <0x080cf8b0> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
"Thread-4" prio=6 tid=0x0457dc00 nid=0x1108 waiting for monitor entry [0x0561f000]
java.lang.Thread.State: BLOCKED (on object monitor)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:183)
- waiting to lock <0x179b3df0> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4584)
at org.eclipse.ui.internal.StartupThreading.runWithThrowable(St artupThreading.java:85)
at org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:937)
at org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:3174)
at org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:2219)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:3612)
at org.eclipse.ui.internal.Workbench.access$29(Workbench.java:3 554)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2261 )
at org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1975)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:2259)
at org.eclipse.ui.internal.Workbench.access$27(Workbench.java:2 230)
at org.eclipse.ui.internal.Workbench$50.run(Workbench.java:2093 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:2037)
at org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
at org.eclipse.ui.application.WorkbenchAdvisor$1.run(WorkbenchA dvisor.java:781)
"Worker-2" prio=6 tid=0x04447c00 nid=0x1bc8 in Object.wait() [0x052cf000]
java.lang.Thread.State: TIMED_WAITING (on object monitor)
- waiting on <0x12e4b788> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:185)
- locked <0x12e4b788> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:217)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:50)
"Thread-1" prio=6 tid=0x04361c00 nid=0x1190 in Object.wait() [0x051cf000]
- waiting on <0x17656250> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:186)
- locked <0x17656250> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:94)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1561)
at org.eclipse.ui.internal.Workbench.access$33(Workbench.java:1 471)
at org.eclipse.ui.internal.Workbench$61.run(Workbench.java:2525 )
"Worker-1" prio=6 tid=0x04350000 nid=0x18ec in Object.wait() [0x050cf000]
"Worker-0" prio=6 tid=0x04360400 nid=0x1120 in Object.wait() [0x04fcf000]
- waiting on <0x1705e258> (a org.eclipse.ui.internal.UISynchronizer)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:140)
- locked <0x1705e258> (a org.eclipse.ui.internal.UISynchronizer)
at org.eclipse.rse.core.subsystems.SubSystem.connect(SubSystem. java:2514)
at org.eclipse.rse.internal.efs.RSEFileStoreImpl.getConnectedFi leSubSystem(RSEFileStoreImpl.java:293)
at org.eclipse.rse.internal.efs.RSEFileStoreImpl.getRemoteFileO bject(RSEFileStoreImpl.java:363)
at org.eclipse.rse.internal.efs.RSEFileStoreImpl.fetchInfo(RSEF ileStoreImpl.java:550)
at org.eclipse.rse.internal.efs.RSEFileStore.fetchInfo(RSEFileS tore.java:305)
at org.eclipse.rse.internal.efs.RSEFileStore.fetchInfo(RSEFileS tore.java:287)
at org.eclipse.core.internal.localstore.UnifiedTree.createChild ForLinkedResource(UnifiedTree.java:272)
at org.eclipse.core.internal.localstore.UnifiedTree.addChildren (UnifiedTree.java:165)
at org.eclipse.core.internal.localstore.UnifiedTree.addNodeChil drenToQueue(UnifiedTree.java:243)
at org.eclipse.core.internal.localstore.UnifiedTree.accept(Unif iedTree.java:109)
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.refreshResource(FileSystemResourceManager.java:824)
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.refresh(FileSystemResourceManager.java:808)
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.refreshRoot(FileSystemResourceManager.java:855)
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.refresh(FileSystemResourceManager.java:801)
at org.eclipse.core.internal.resources.Resource.refreshLocal(Re source.java:1661)
at org.eclipse.core.internal.refresh.RefreshJob.runInWorkspace( RefreshJob.java:166)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
"Worker-JM" prio=6 tid=0x03ab6800 nid=0xa2c in Object.wait() [0x0421f000]
- waiting on <0x12c671e0> (a java.util.ArrayList)
at org.eclipse.core.internal.jobs.InternalWorker.run(InternalWo rker.java:58)
- locked <0x12c671e0> (a java.util.ArrayList)
"[Timer] - Main Queue Handler" daemon prio=6 tid=0x039fe800 nid=0x474 in Object.wait() [0x0411f000]
- waiting on <0x12c67260> (a java.lang.Object)
at org.eclipse.equinox.internal.util.impl.tpt.timer.TimerImpl.r un(TimerImpl.java:141)
- locked <0x12c67260> (a java.lang.Object)
"Framework Event Dispatcher" daemon prio=6 tid=0x03983400 nid=0x1004 in Object.wait() [0x03f1f000]
- waiting on <0x12c67310> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x12c67310> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
"Start Level Event Dispatcher" daemon prio=6 tid=0x0397e400 nid=0x1a50 in Object.wait() [0x03d7f000]
- waiting on <0x12c67388> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x12c67388> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
"State Data Manager" daemon prio=6 tid=0x03992400 nid=0xcd4 waiting on condition [0x03c7f000]
java.lang.Thread.State: TIMED_WAITING (sleeping)
at java.lang.Thread.sleep(Native Method)
at org.eclipse.osgi.internal.baseadaptor.StateManager.run(State Manager.java:319)
"Low Memory Detector" daemon prio=6 tid=0x0305fc00 nid=0x6e8 runnable [0x00000000]
"CompilerThread0" daemon prio=10 tid=0x03059800 nid=0x1324 waiting on condition [0x00000000]
"Attach Listener" daemon prio=10 tid=0x03058000 nid=0xbb8 runnable [0x00000000]
"Signal Dispatcher" daemon prio=10 tid=0x03056c00 nid=0x720 runnable [0x00000000]
"Finalizer" daemon prio=8 tid=0x03047800 nid=0x1cc0 in Object.wait() [0x033cf000]
- waiting on <0x12ab02b0> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
- locked <0x12ab02b0> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
"Reference Handler" daemon prio=10 tid=0x03042c00 nid=0x1be4 in Object.wait() [0x032cf000]
- waiting on <0x12ab0338> (a java.lang.ref.Reference$Lock)
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <0x12ab0338> (a java.lang.ref.Reference$Lock)
"main" prio=6 tid=0x00b46c00 nid=0x1bd8 in Object.wait() [0x0013e000]
- waiting on <0x17631878> (a org.eclipse.rse.core.subsystems.SubSystem$ConnectorServicePo ol)
at org.eclipse.rse.core.subsystems.SubSystem$ConnectorServicePo ol.waitUntilNotContained(SubSystem.java:2467)
- locked <0x17631878> (a org.eclipse.rse.core.subsystems.SubSystem$ConnectorServicePo ol)
at org.eclipse.rse.core.subsystems.SubSystem.connect(SubSystem. java:2508)
at org.eclipse.rse.internal.efs.RSEFileStoreImpl.getRemoteFileO bject(RSEFileStoreImpl.java:348)
at org.eclipse.rse.internal.efs.RSEFileStoreImpl.openInputStrea m(RSEFileStoreImpl.java:667)
at org.eclipse.rse.internal.efs.RSEFileStore.openInputStream(RS EFileStore.java:323)
at org.eclipse.core.internal.resources.ContentDescriptionManage r$LazyFileInputStream.ensureOpened(ContentDescriptionManager .java:156)
at org.eclipse.core.internal.resources.ContentDescriptionManage r$LazyFileInputStream.read(ContentDescriptionManager.java:16 8)
at java.io.InputStream.read(Unknown Source)
at org.eclipse.core.internal.content.LazyInputStream.loadBlock( LazyInputStream.java:99)
at org.eclipse.core.internal.content.LazyInputStream.ensureAvai lable(LazyInputStream.java:64)
at org.eclipse.core.internal.content.LazyInputStream.read(LazyI nputStream.java:119)
at org.eclipse.core.internal.content.Util.getByteOrderMark(Util .java:119)
at org.eclipse.core.internal.content.TextContentDescriber.descr ibe(TextContentDescriber.java:49)
at org.eclipse.core.internal.content.ContentType.describe(Conte ntType.java:161)
at org.eclipse.core.internal.content.ContentType.internalGetDes criptionFor(ContentType.java:458)
at org.eclipse.core.internal.content.ContentTypeCatalog.getDesc riptionFor(ContentTypeCatalog.java:356)
at org.eclipse.core.internal.content.ContentTypeCatalog.getDesc riptionFor(ContentTypeCatalog.java:360)
at org.eclipse.core.internal.content.ContentTypeMatcher.getDesc riptionFor(ContentTypeMatcher.java:86)
at org.eclipse.core.internal.resources.ContentDescriptionManage r.readDescription(ContentDescriptionManager.java:436)
at org.eclipse.core.internal.resources.ContentDescriptionManage r.getDescriptionFor(ContentDescriptionManager.java:346)
at org.eclipse.core.internal.resources.File.internalGetCharset( File.java:255)
at org.eclipse.core.internal.resources.File.getCharset(File.jav a:216)
at org.eclipse.core.internal.resources.File.getCharset(File.jav a:203)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer .cacheEncodingState(ResourceTextFileBuffer.java:479)
at org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer .initializeFileBufferContent(ResourceTextFileBuffer.java:281 )
at org.eclipse.core.internal.filebuffers.ResourceFileBuffer.cre ate(ResourceFileBuffer.java:245)
at org.eclipse.core.internal.filebuffers.TextFileBufferManager. connect(TextFileBufferManager.java:112)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.createF ileInfo(TextFileDocumentProvider.java:559)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider.createFileInfo(CompilationUnitDocumentProvider.ja va:969)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect (TextFileDocumentProvider.java:478)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitDocume ntProvider.connect(CompilationUnitDocumentProvider.java:1229 )
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:4050)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:217)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1444)
at org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.internalDo SetInput(JavaEditor.java:2578)
at org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.doSetInput (JavaEditor.java:2551)
at org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .doSetInput(CompilationUnitEditor.java:1371)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3037)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2600)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3055)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3082)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1429)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
- locked <0x179b3df0> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbe nch.java:1566)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2537)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
"VM Thread" prio=10 tid=0x03040000 nid=0xe94 runnable
"VM Periodic Task Thread" prio=10 tid=0x03062400 nid=0xee8 waiting on condition
System Properties
osgi.bundles.defaultStartLevel=4
org.osgi.supports.framework.extension=true
sun.management.compiler=HotSpot Client Compiler
https.proxyHost=proxy.telma.nn
eclipse.p2.profile=SDKProfile
https.proxySet=true
os.name=Windows XP
sun.boot.class.path=C:\Program Files\Java\jre6\lib\resources.jar;C:\Program Files\Java\jre6\lib\rt.jar;C:\Program Files\Java\jre6\lib\sunrsasign.jar;C:\Program Files\Java\jre6\lib\jsse.jar;C:\Program Files\Java\jre6\lib\jce.jar;C:\Program Files\Java\jre6\lib\charsets.jar;C:\Program Files\Java\jre6\classes
osgi.ws=win32
sun.desktop=windows
java.vm.specification.vendor=Sun Microsystems Inc.
java.runtime.version=1.6.0_20-b02
osgi.instance.area=file:/D:/Dvs/Project/EclipseWorkspaces/3. 6/MDM6600/
http.proxyPort=3128
user.name=dsmirnov
osgi.framework.extensions=
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
eclipse.launcher=D:\eclipse-3.6M6\eclipse.exe
eclipse.launcher.name=Eclipse
org.osgi.framework.language=ru
equinox.use.ds=true
org.eclipse.equinox.launcher.splash.handle=6621156
user.language=ru
org.osgi.framework.processor=x86
osgi.syspath=d:\eclipse-3.6M6\plugins
sun.boot.library.path=C:\Program Files\Java\jre6\bin
osgi.manifest.cache=D:\eclipse-3.6M6\configuration\org.eclip se.osgi\manifests
java.version=1.6.0_20
org.osgi.framework.os.name=WindowsXP
user.timezone=Europe/Moscow
sun.arch.data.model=32
osgi.bundles=reference:file:mailto: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @1:start
http.nonProxyHosts=*.telma.nn|10.13.8.*|<local>
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
osgi.tracefile=D:\Dvs\Project\EclipseWorkspaces\3.6\MDM6600\ .metadata\trace.log
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.jnu.encoding=Cp1251
eclipse.application=org.eclipse.ui.ide.workbench
file.encoding.pkg=sun.io
org.osgi.framework.vendor=Eclipse
file.separator=\
java.specification.name=Java Platform API Specification
java.class.version=50.0
user.country=RU
org.eclipse.equinox.launcher.splash.location=D:\eclipse-3.6M 6\\plugins\org.eclipse.platform_3.6.0.v201006080911\splash.b mp
java.home=C:\Program Files\Java\jre6
osgi.os=win32
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
D:\eclipse-3.6M6\\plugins\org.eclipse.platform_3.6.0.v201006 080911\splash.bmp
-launcher
-name
Eclipse
--launcher.library
D:\eclipse-3.6M6\plugins/org.eclipse.equinox.launcher.win32. win32.x86_1.1.0.v20100503\eclipse_1307.dll
-startup
D:\eclipse-3.6M6\plugins/org.eclipse.equinox.launcher_1.1.0. v20100507.jar
-data
-launcher
-vm
C:\Program Files\Java\jre6\bin\client\jvm.dll
java.vm.info=mixed mode
osgi.splashLocation=D:\eclipse-3.6M6\\plugins\org.eclipse.pl atform_3.6.0.v201006080911\splash.bmp
os.version=5.1
https.proxyPort=3128
osgi.arch=x86
https.nonProxyHosts=*.telma.nn|10.13.8.*|<local>
path.separator=;
java.vm.version=16.3-b01
org.osgi.supports.framework.fragment=true
user.variant=
osgi.framework.shape=jar
http.proxySet=true
osgi.instance.area.default=file:/C:/Documents and Settings/dsmirnov/workspace/
java.awt.printerjob=sun.awt.windows.WPrinterJob
sun.io.unicode.encoding=UnicodeLittle
org.osgi.framework.version=1.5.0
awt.toolkit=sun.awt.windows.WToolkit
osgi.install.area=file:/D:/eclipse-3.6M6/
osgi.framework=file:/d:/eclipse-3.6M6/plugins/org.eclipse.os gi_3.6.0.v20100517.jar
user.home=C:\Documents and Settings\dsmirnov
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
osgi.bundlestore=D:\eclipse-3.6M6\configuration\org.eclipse. osgi\bundles
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.nl=ru_RU
java.specification.vendor=Sun Microsystems Inc.
java.library.path=D:\eclipse-3.6M6;.;C:\WINDOWS\Sun\Java\bin ;C:\WINDOWS\system32;C:\WINDOWS;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:/Program Files/Java/jre6/lib/i386;C:\Python26\Scripts;C:\Python26\;C: \P4\Buildtools\bin;C:\Utils\Cygwin\Bin;C:\Perl\bin\;C:\WINDO WS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Perforce;C:\Utils\SourceryEABI\bin;c:\apps\utf\lib;c:\ apps\utf\bin;C:\Program Files\CollabNet Subversion Server;C:\PROGRA~1\Qualcomm\BREWMP~1.7\tools\DEPREC~1\BTIL\H ost\bin;C:\Program Files\MySQL\MySQL Server 5.0\bin\;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Microsoft Driver Test Manager\Controller\;C:\Program Files\PC Connectivity Solution\;%APPDATA%\Python\Scripts;c:\p4\buildtools\bin;
java.vendor.url=http://java.sun.com/
org.osgi.framework.os.version=5.1.0
eclipse.startTime=1279783430046
eclipse.p2.data.area=@config.dir/../p2/
java.vm.vendor=Sun Microsystems Inc.
java.runtime.name=Java(TM) SE Runtime Environment
java.class.path=D:\eclipse-3.6M6\plugins/org.eclipse.equinox .launcher_1.1.0.v20100507.jar
org.eclipse.update.reconcile=false
eclipse.vm=C:\Program Files\Java\jre6\bin\client\jvm.dll
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.version=1.0
sun.cpu.endian=little
sun.os.patch.level=Service Pack 3
java.io.tmpdir=C:\Temp\
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
http.proxyHost=proxy.telma.nn
eclipse.product=org.eclipse.sdk.ide
eclipse.home.location=file:/D:/eclipse-3.6M6/
os.arch=x86
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
user.dir=D:\eclipse-3.6M6
org.osgi.supports.framework.requirebundle=true
line.separator=
java.vm.name=Java HotSpot(TM) Client VM
file.encoding=Cp1251
osgi.framework.version=3.6.0.v20100517
eclipse.buildId=I20100608-0911
eclipse.vmargs=-Xms40m
-Xmx512m
-XX:MaxPermSize=512m
-Djava.class.path=D:\eclipse-3.6M6\plugins/org.eclipse.equin ox.launcher_1.1.0.v20100507.jar
java.specification.version=1.6
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
osgi.logfile=D:\Dvs\Project\EclipseWorkspaces\3.6\MDM6600\.m etadata\.log
osgi.configuration.area=file:/D:/eclipse-3.6M6/configuration /
Command line
D:\eclipse-3.6M6\eclipse.exe -data D:\Dvs\Project\EclipseWorkspaces\3.6\MDM6600 -os win32 -ws win32 -arch x86 -showsplash D:\eclipse-3.6M6\\plugins\org.eclipse.platform_3.6.0.v201006 080911\splash.bmp -launcher D:\eclipse-3.6M6\eclipse.exe -name Eclipse --launcher.library D:\eclipse-3.6M6\plugins/org.eclipse.equinox.launcher.win32. win32.x86_1.1.0.v20100503\eclipse_1307.dll -startup D:\eclipse-3.6M6\plugins/org.eclipse.equinox.launcher_1.1.0. v20100507.jar -vm "C:\Program Files\Java\jre6\bin\client\jvm.dll" -vmargs -Xms40m -Xmx512m -XX:MaxPermSize=512m
Memory
Used: 109363432 (~104MB)
Free: 93175576 (~89MB)
Total: 202539008 (~193MB)
Max: 518979584 (~495MB)
Available Processors: 2
4048 eclipse.exe ( GDI+ Window ) session:0 threads:26 parent:7712
2010-07-22 11:43:47
"StackTrace Remote Thread" prio=6 tid=0x043cb400 nid=0x1c34 runnable [0x00000000]
"[ThreadPool Manager] - Idle Thread" daemon prio=6 tid=0x0399e000 nid=0x1d50 in Object.wait() [0x0677f000]
- waiting on <0x09655288> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or)
- locked <0x09655288> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or)
"Bundle File Closer" daemon prio=6 tid=0x03a0c800 nid=0x107c in Object.wait() [0x0667f000]
- waiting on <0x0891bee0> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x0891bee0> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
"Java indexing" daemon prio=4 tid=0x03a2b400 nid=0x1184 in Object.wait() [0x0657f000]
- waiting on <0x080cfc40> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
- locked <0x080cfc40> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
"Thread-4" prio=6 tid=0x04420c00 nid=0x1540 in Object.wait() [0x0559f000]
- waiting on <0x179c4790> (a org.eclipse.swt.widgets.RunnableLock)
- locked <0x179c4790> (a org.eclipse.swt.widgets.RunnableLock)
"Worker-2" prio=6 tid=0x043a4c00 nid=0x1bfc in Object.wait() [0x0522f000]
- waiting on <0x12e4b790> (a org.eclipse.core.internal.jobs.WorkerPool)
- locked <0x12e4b790> (a org.eclipse.core.internal.jobs.WorkerPool)
"Thread-1" prio=6 tid=0x03a92400 nid=0x1ea4 in Object.wait() [0x0512f000]
- waiting on <0x17558c78> (a org.eclipse.swt.widgets.RunnableLock)
- locked <0x17558c78> (a org.eclipse.swt.widgets.RunnableLock)
"Worker-1" prio=6 tid=0x042a0c00 nid=0x1944 in Object.wait() [0x0502f000]
"Worker-0" prio=6 tid=0x0429f400 nid=0x10ec in Object.wait() [0x04f2f000]
- waiting on <0x17086f78> (a org.eclipse.ui.internal.UISynchronizer)
- locked <0x17086f78> (a org.eclipse.ui.internal.UISynchronizer)
"Worker-JM" prio=6 tid=0x03a9a800 nid=0x16bc in Object.wait() [0x0416f000]
"[Timer] - Main Queue Handler" daemon prio=6 tid=0x039f1400 nid=0x8ac in Object.wait() [0x0406f000]
"Framework Event Dispatcher" daemon prio=6 tid=0x03999400 nid=0x12b0 in Object.wait() [0x03e6f000]
"Start Level Event Dispatcher" daemon prio=6 tid=0x03988000 nid=0x1060 in Object.wait() [0x03d6f000]
"State Data Manager" daemon prio=6 tid=0x03977800 nid=0x1d6c waiting on condition [0x03c6f000]
"Low Memory Detector" daemon prio=6 tid=0x0305f800 nid=0x8d4 runnable [0x00000000]
"CompilerThread0" daemon prio=10 tid=0x03059800 nid=0x1c98 waiting on condition [0x00000000]
"Attach Listener" daemon prio=10 tid=0x03058000 nid=0xa68 runnable [0x00000000]
"Signal Dispatcher" daemon prio=10 tid=0x03056c00 nid=0x122c runnable [0x00000000]
"Finalizer" daemon prio=8 tid=0x03047800 nid=0x244 in Object.wait() [0x033cf000]
- waiting on <0x12ab06c0> (a java.lang.ref.ReferenceQueue$Lock)
- locked <0x12ab06c0> (a java.lang.ref.ReferenceQueue$Lock)
"Reference Handler" daemon prio=10 tid=0x03042c00 nid=0x1da8 in Object.wait() [0x032cf000]
- waiting on <0x12ab0748> (a java.lang.ref.Reference$Lock)
- locked <0x12ab0748> (a java.lang.ref.Reference$Lock)
"main" prio=6 tid=0x00b46c00 nid=0x1834 in Object.wait() [0x0013e000]
- waiting on <0x1767aed0> (a org.eclipse.rse.core.subsystems.SubSystem$ConnectorServicePo ol)
- locked <0x1767aed0> (a org.eclipse.rse.core.subsystems.SubSystem$ConnectorServicePo ol)
"VM Thread" prio=10 tid=0x03040000 nid=0x1b48 runnable
"VM Periodic Task Thread" prio=10 tid=0x03062400 nid=0x1a0c waiting on condition
System Properties
https.proxySet=true
os.name=Windows XP
osgi.ws=win32
sun.desktop=windows
http.proxyPort=3128
user.name=dsmirnov
equinox.use.ds=true
org.eclipse.equinox.launcher.splash.handle=6752228
user.language=ru
file.separator=\
user.country=RU
osgi.os=win32
win32
-ws
win32
-arch
x86
-showsplash
-launcher
-name
Eclipse
--launcher.library
-startup
Re: Eclipse hang up. Suspecting RSE... [message #639508 is a reply to message #583600] Tue, 16 November 2010 13:45 Go to previous message
remote projects don't work well, see also the Known Issues:
http://wiki.eclipse.org/DSDP/TM/3.2_Known_Issues_and_Workaro unds
Bugzilla's exist for the issue but unfortunately it's a problem that's
not resolved easily, so you'll have to look at the Workarounds for now.
HTH,
Martin
Previous Topic:RSE installation failed
Next Topic:RSE connection
Current Time: Sat Jul 19 06:03:24 EDT 2025
Powered by FUDForum. Page generated in 0.04037 seconds
