Home » Archived » Riena » Problem with annotated injection
Problem with annotated injection [message #468033] Mon, 03 August 2009 13:28 Go to next message
in Riena I like to inject services with @InjectService.
Everything is easy in a SubModuleController class.
But in pojo's I have the problem, that bind won't be called.
The following code runs well from Activator.start
for pojo CurrentUser without annotation:
currentUser = new CurrentUser();
Inject.service(ISubjectHolderService.class.getName())
.into(currentUser)
.bind("bindSubjectHolderService")
.unbind("unbindSubjectHolderService")
.andStart(context);
Inject.service(IUserService.class.getName())
.into(currentUser)
.bind("bindUserService")
.unbind("unbindUserService")
.andStart(context);
If in Activator.start or any other place only
is called and CurrentUser is annotated like this the services are null.
public class CurrentUser {
private ISubjectHolderService subjectHolderService;
private IUserService userService;
@InjectService(service= IUserService.class ,unbind = "unbindUserService")
public void bindUserService(IUserService srv) {
this.userService = srv;
@InjectService(service=ISubjectHolderService.class,unbind="unbindSubjectHolderService ")
public void bindSubjectHolderService(ISubjectHolderService srv)
this.subjectHolderService = srv;
If tried to change @InjectService or use @WireWith but I can't get it run.
What goes wrong.
Rüdiger
Re: Problem with annotated injection [message #468089 is a reply to message #468033] Tue, 04 August 2009 01:03 Go to previous messageGo to next message
Hi Rüdiger,
When using annotations for injection something has to interpret those
annotations and perform the necessary actions.
In the case where classes are defined within extension points like your
SubModuleController the ExtensionInjector takes care of the wiring.
I you create a pojo yourself you have the choice of using either:
-Inject.Service().into( pojo ). ..
or
- use annotations and do a Wire.instance( pojo ).andStart()
HTH
Stefan
Rüdiger Rensinghoff-Kranen wrote:
> Hello,
> .into(currentUser)
> .andStart(context);
> .into(currentUser)
> .andStart(context);
> public void bindSubjectHolderService(ISubjectHolderService srv) {
> What goes wrong.
> Rüdiger
Re: Problem with annotated injection [message #468130 is a reply to message #468089] Tue, 04 August 2009 06:16 Go to previous messageGo to next message
Stefan Liebig schrieb:
> Hi Rüdiger,
> or
> HTH
> Stefan
>> Hello,
>> .into(currentUser)
>> .andStart(context);
>> .into(currentUser)
>> .andStart(context);
>> run.
>> What goes wrong.
>> Rüdiger
Hello Stefan,
thanks for your rapide response. I tried Wire.instance and it works well
and is more convenient to me.
Rüdiger
Re: Problem with annotated injection [message #468144 is a reply to message #468130] Tue, 04 August 2009 06:52 Go to previous messageGo to next message
>> Hi Rüdiger,
>> your SubModuleController the ExtensionInjector takes care of the wiring.
>> or
>> HTH
>> Stefan
>>> Hello,
>>> .into(currentUser)
>>> .andStart(context);
>>> .into(currentUser)
>>> .andStart(context);
>>> srv) {
>>> run.
>>> What goes wrong.
>>> Rüdiger
> Hello Stefan,
> Rüdiger
Hello Rüdiger,
You can even simplify your pojo annotations:
@InjectService()
@InjectService()
The service class is now taken from the parameter type of the annotated
bind method and the unbind method name is generated by prefixing the
annotated bind method with with "un".
Tschüß,
Stefan
Re: Problem with annotated injection [message #468154 is a reply to message #468144] Tue, 04 August 2009 08:07 Go to previous messageGo to next message
>>> Hi Rüdiger,
>>> or
>>> HTH
>>> Stefan
>>>> Hello,
>>>> .into(currentUser)
>>>> .andStart(context);
>>>> .into(currentUser)
>>>> .andStart(context);
>>>> srv) {
>>>> it run.
>>>> What goes wrong.
>>>> Rüdiger
>> Hello Stefan,
>> well and is more convenient to me.
>> Rüdiger
> Hello Rüdiger,
> @InjectService()
> @InjectService()
> Tschüß,
> Stefan
Hello Stefan,
thanks very much for your helpfull usage hint. It would be great to find
such information in a description for Riena. Now I have to learn it
the hard way. Spend hours, that I not really have, by try and error and
greping in inner classes of the framework. But Riena is worth it. Thanks
to the team.
Rüdiger
Re: Problem with annotated injection [message #468168 is a reply to message #468154] Tue, 04 August 2009 08:52 Go to previous messageGo to next message
>>>> Hi Rüdiger,
>>>> those annotations and perform the necessary actions.
>>>> wiring.
>>>> or
>>>> HTH
>>>> Stefan
>>>>> Hello,
>>>>> .into(currentUser)
>>>>> .andStart(context);
>>>>> .into(currentUser)
>>>>> .andStart(context); If in Activator.start or any other
>>>>> place only
>>>>> null.
>>>>> srv) {
>>>>> it run.
>>>>> What goes wrong.
>>>>> Rüdiger
>>> Hello Stefan,
>>> Rüdiger
>> Hello Rüdiger,
>> @InjectService()
>> @InjectService()
>> annotated bind method and the unbind method name is generated by
>> prefixing the annotated bind method with with "un".
>> Tschüß,
>> Stefan
> Hello Stefan,
> such information in a description for Riena. Now I have to learn it the
> to the team.
> Rüdiger
Hello Rüdiger,
You are right http://wiki.eclipse.org/Riena_Getting_Started_with_Wiring
needs some polishing. Thanks for the hint!
Keep posting your questions and comments! We will try hard.
Tschüß,
Stefan
Re: Problem with annotated injection [message #478778 is a reply to message #468168] Thu, 06 August 2009 15:37 Go to previous message
>>>>> Hi Rüdiger,
>>>>> wiring.
>>>>> or
>>>>> HTH
>>>>> Stefan
>>>>>> Hello,
>>>>>> .into(currentUser)
>>>>>> .andStart(context);
>>>>>> .into(currentUser)
>>>>>> place only
>>>>>> null.
>>>>>> srv) {
>>>>>> it run.
>>>>>> What goes wrong.
>>>>>> Rüdiger
>>>> Hello Stefan,
>>>> Rüdiger
>>> Hello Rüdiger,
>>> @InjectService()
>>> @InjectService()
>>> Tschüß,
>>> Stefan
>> Hello Stefan,
>> find such information in a description for Riena. Now I have to learn
>> it the hard way. Spend hours, that I not really have, by try and error
>> and greping in inner classes of the framework. But Riena is worth it.
>> Thanks to the team.
>> Rüdiger
> Hello Rüdiger,
> Tschüß,
> Stefan
Hi Rüdiger,
I know you said you had no time but still wanted our documentation in Riena to be better. Help us to help us and write a
little paragraph in the wiki page that Stefan mentioned and add the things you were missing. Add a little documentation,
which I guess you can copy in parts from this thread to help others to be faster in understanding the concepts....
thanks
christian
Re: Problem with annotated injection [message #583111 is a reply to message #468033] Tue, 04 August 2009 01:03 Go to previous message
Hi Rüdiger,
or
HTH
Stefan
> Hello,
> .into(currentUser)
> .andStart(context);
> .into(currentUser)
> .andStart(context);
> What goes wrong.
> Rüdiger
Re: Problem with annotated injection [message #583124 is a reply to message #468089] Tue, 04 August 2009 06:16 Go to previous message
> Hi Rüdiger,
> or
> HTH
> Stefan
>> Hello,
>> .into(currentUser)
>> .andStart(context);
>> .into(currentUser)
>> .andStart(context);
>> run.
>> What goes wrong.
>> Rüdiger
Hello Stefan,
Rüdiger
Re: Problem with annotated injection [message #583137 is a reply to message #468130] Tue, 04 August 2009 06:52 Go to previous message
>> Hi Rüdiger,
>> or
>> HTH
>> Stefan
>>> Hello,
>>> .into(currentUser)
>>> .andStart(context);
>>> .into(currentUser)
>>> .andStart(context);
>>> srv) {
>>> run.
>>> What goes wrong.
>>> Rüdiger
> Hello Stefan,
> Rüdiger
Hello Rüdiger,
@InjectService()
@InjectService()
Tschüß,
Stefan
Re: Problem with annotated injection [message #583150 is a reply to message #468144] Tue, 04 August 2009 08:07 Go to previous message
>>> Hi Rüdiger,
>>> or
>>> HTH
>>> Stefan
>>>> Hello,
>>>> .into(currentUser)
>>>> .andStart(context);
>>>> .into(currentUser)
>>>> .andStart(context);
>>>> srv) {
>>>> it run.
>>>> What goes wrong.
>>>> Rüdiger
>> Hello Stefan,
>> Rüdiger
> Hello Rüdiger,
> @InjectService()
> @InjectService()
> Tschüß,
> Stefan
Hello Stefan,
to the team.
Rüdiger
Re: Problem with annotated injection [message #583159 is a reply to message #468154] Tue, 04 August 2009 08:52 Go to previous message
>>>> Hi Rüdiger,
>>>> wiring.
>>>> or
>>>> HTH
>>>> Stefan
>>>>> Hello,
>>>>> .into(currentUser)
>>>>> .andStart(context);
>>>>> .into(currentUser)
>>>>> place only
>>>>> null.
>>>>> srv) {
>>>>> it run.
>>>>> What goes wrong.
>>>>> Rüdiger
>>> Hello Stefan,
>>> Rüdiger
>> Hello Rüdiger,
>> @InjectService()
>> @InjectService()
>> Tschüß,
>> Stefan
> Hello Stefan,
> to the team.
> Rüdiger
Hello Rüdiger,
Tschüß,
Stefan
Re: Problem with annotated injection [message #583174 is a reply to message #468168] Thu, 06 August 2009 15:37 Go to previous message
>>>>> Hi Rüdiger,
>>>>> wiring.
>>>>> or
>>>>> HTH
>>>>> Stefan
>>>>>> Hello,
>>>>>> .into(currentUser)
>>>>>> .andStart(context);
>>>>>> .into(currentUser)
>>>>>> place only
>>>>>> null.
>>>>>> srv) {
>>>>>> it run.
>>>>>> What goes wrong.
>>>>>> Rüdiger
>>>> Hello Stefan,
>>>> Rüdiger
>>> Hello Rüdiger,
>>> @InjectService()
>>> @InjectService()
>>> Tschüß,
>>> Stefan
>> Hello Stefan,
>> Thanks to the team.
>> Rüdiger
> Hello Rüdiger,
> Tschüß,
> Stefan
Hi Rüdiger,
thanks
christian
Previous Topic:Problem with annotated injection
Next Topic:Riena milestone 1.2.0.M1
Current Time: Sat Jul 19 10:19:52 EDT 2025
Powered by FUDForum. Page generated in 0.06897 seconds
