Home » Language IDEs » AspectJ » AJDT 1.1.12 released for Eclipse 3.0
AJDT 1.1.12 released for Eclipse 3.0 [message #40193] Fri, 13 August 2004 11:29 Go to next message
Originally posted by: mchapman.uk.ibm.com
The AJDT team are pleased to announce availability of our 1.1.12
release which, like 1.1.11 before it, runs on Eclipse 3.0 (final).
Please see the 'New and Noteworthy' page for this release, accessible
directly from the AJDT homepage at:
http://eclipse.org/ajdt
Highlights of the release include:
- Per-project properties pages for AspectJ compiler options
- Related location context menu entries for declare errors/warnings, and
also for certain compiler error messages
- New wizard for exporting AspectJ-enabled plugins
- Java code completion behaves the same in .aj files as .java files
- Advice gutter annotations are shown for aspects in JAR files
- A number of bugs have been fixed since 1.1.11
See the 'New and Noteworthy' page for further details.
AJDT 1.1.12 is available from the same update site as the previous
release:
http://download.eclipse.org/technology/ajdt/30/update
or downloadable as a set of plugins for offline installation from:
http://download.eclipse.org/technology/ajdt/30/update/ajdt_1 .1.12_archive.zip
See our homepage and download page for more information.
Matt + the rest of the AJDT team.
AJDT Development
update server always times out [message #40638 is a reply to message #40193] Wed, 22 September 2004 09:46 Go to previous messageGo to next message
I am trying now since two days to update to the new AJDT version using
the http://download.eclipse.org/technology/ajdt/30/update site, but
each and every time the connection is first properly set up and things
start to be downloaded at reasonable speed at first but then the
download gets slower and slooower and slooooweeeerr and finally times
out with the following message:
Unable to complete action for feature "Eclipse AspectJ Development
Tools" due to errors.
Unable to retrieve remote reference
" http://download.eclipse.org/technology/ajdt/30/update/plugin s/org.asp
ectj.ajde_1.2.0.jar". [Connection timed out: connect]
Is there something missing or is the server just overloaded (24 hours
per day?). Am I the only one having this problem?
Michael :-(
"Matt Chapman" <mchapman@uk.ibm.com> wrote in message
news:pan.2004.08.13.15.29.00.654138@uk.ibm.com...
accessible
and
> release:
> AJDT Development
Re: update server always times out [message #40669 is a reply to message #40638] Wed, 22 September 2004 10:32 Go to previous messageGo to next message
Hi Michael,
I'm very sorry to hear you're having difficulties getting hold of AJDT.
Have you tried the zip file version instead to see if that's any
different? Unfortunately the Eclipse projects are not mirrored like the
base Eclipse. It would indeed be very helpful to hear if anyone else has
been having problems, so that we can ask the webmaster about this.
Matt.
On Wed, 22 Sep 2004 15:46:47 +0200, Michael Moser wrote:
> I am trying now since two days to update to the new AJDT version using the
> http://download.eclipse.org/technology/ajdt/30/update site, but each and
> every time the connection is first properly set up and things start to be
> downloaded at reasonable speed at first but then the download gets slower
> and slooower and slooooweeeerr and finally times out with the following
> message:
> Unable to complete action for feature "Eclipse AspectJ Development Tools"
> due to errors.
> Is there something missing or is the server just overloaded (24 hours per
> Michael :-(
Re: update server always times out [message #40732 is a reply to message #40669] Wed, 22 September 2004 10:59 Go to previous messageGo to next message
news:pan.2004.09.22.14.32.47.957245@uk.ibm.com...
> Hi Michael,
AJDT.
> different?
I am in fact trying this since I gave up for the time being on the
automatic update but, alas, I am seeing very similar behaviour (now
already for the second time):
The download starts - at the beginning it gives the optimistic
prognosis: "Estimated time left: 18 minutes...", but then again things
start to slow down and the download right now is e.g. creeping along
at about 1/3 of the file and currently it says: "Estimated time left:
1h 7min ..." and is counting up... :-(
The first attempt at some point then stalled with a timeout. I'm
afraid this second attempt won't yield any better result...
Sigh, maybe I'll have to give it a try at 3:00 am?
Michael
has
> Regards,
> Matt.
using the
each and
start to be
slower
following
> > message:
Tools"
> > due to errors.
hours per
> > Michael :-(
Re: update server always times out [message #40763 is a reply to message #40732] Wed, 22 September 2004 13:23 Go to previous messageGo to next message
> The download starts - at the beginning it gives the optimistic prognosis:
> "Estimated time left: 18 minutes...", but then again things start to slow
> down and the download right now is e.g. creeping along at about 1/3 of the
> file and currently it says: "Estimated time left: 1h 7min ..." and is
> counting up... :-(
> The first attempt at some point then stalled with a timeout. I'm afraid
> Sigh, maybe I'll have to give it a try at 3:00 am? Michael
I assume you're doing this from inside the IBM network? The connectivity
should be good from your location. I just tried it from here, and it did
complete, but it was rather slow, averaging about 12K/s.
I notice some other projects actually have their downloads hosted on the
CVS server. I will ask the webmaster about this. As an experiment, I've
tried putting the 1.1.12 zip file in CVS, so see if that's any better. The
URL is:
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/org. eclipse.ajdt/ajdt_1.1.12_archive.zip
and the file is 13129061 bytes.
Let me know if you still have problems and I can email you the zip file
directly.
Matt.
Re: update server always times out [message #40794 is a reply to message #40669] Wed, 22 September 2004 13:34 Go to previous messageGo to next message
Having the same problems here. Three of our guys are attempting
updates to 3.0.1, GET, EMF,VE. All fail with timeouts
I was able from my home box to do updates yesterday. I assumed it was
a load issues due to all the new updates.
On Wed, 22 Sep 2004 15:32:53 +0100, Matt Chapman <mchapman@uk.ibm.com>
wrote:
>Hi Michael,
>Regards,
>Matt.
>> message:
>> due to errors.
>> Michael :-(
Re: update server always times out [message #40825 is a reply to message #40763] Thu, 23 September 2004 04:53 Go to previous messageGo to next message
In the meantime I tried it from home early this morning (still night
time in the US...) and finally succeeded.
Thanks for your offer and efforts anyway!
Michael
news:pan.2004.09.22.17.22.50.454304@uk.ibm.com...
(now
prognosis:
to slow
1/3 of the
is
> > counting up... :-(
afraid
connectivity
did
Yes, but strange enough it wasn't very good, either. Esp. this strange
slow down or throttling effect (i.e. repeatedly good speed at start
and then ever decreasing speed during the download) puzzles me!
the
I've
better. The
> URL is:
file
> directly.
> Regards,
> Matt.
Outline View: No show of Advice affected classes [message #42151 is a reply to message #40193] Mon, 04 October 2004 14:53 Go to previous message
Originally posted by: geirAoves.online.no
I take the liberty to repost the message "Advice Information for classes in
other projects" by Solomon Obi (dated 27.08.04), since I think it is
**very** important, and I have the same problem myself: Looks like a BUG or
limitaion that I hope will be fixed soon:
"Solomon Obi" <solomono@yahoo.com> wrote in message
news:cgm5gh$u1u$1@eclipse.org...
> It appears that the outline view for an aspect only shows classes that
are
> advised which are in the same Eclipse
> project. Is there a way to show advised projects in other
> projects
> Thanks
> Solomon
update server always times out [message #583083 is a reply to message #40193] Wed, 22 September 2004 09:46 Go to previous message
Michael :-(
accessible
and
> release:
> AJDT Development
Re: update server always times out [message #583103 is a reply to message #40638] Wed, 22 September 2004 10:32 Go to previous message
Hi Michael,
Matt.
> message:
> due to errors.
> Michael :-(
Re: update server always times out [message #583131 is a reply to message #40669] Wed, 22 September 2004 10:59 Go to previous message
> Hi Michael,
AJDT.
> different?
Michael
has
> Regards,
> Matt.
using the
each and
start to be
slower
following
> > message:
Tools"
> > due to errors.
hours per
> > Michael :-(
Re: update server always times out [message #583147 is a reply to message #40732] Wed, 22 September 2004 13:23 Go to previous message
> counting up... :-(
URL is:
directly.
Matt.
Re: update server always times out [message #583158 is a reply to message #40669] Wed, 22 September 2004 13:34 Go to previous message
wrote:
>Hi Michael,
>Regards,
>Matt.
>> message:
>> due to errors.
>> Michael :-(
Re: update server always times out [message #583172 is a reply to message #40763] Thu, 23 September 2004 04:53 Go to previous message
Michael
(now
prognosis:
to slow
1/3 of the
is
> > counting up... :-(
afraid
connectivity
did
the
I've
better. The
> URL is:
file
> directly.
> Regards,
> Matt.
Outline View: No show of Advice affected classes [message #583817 is a reply to message #40193] Mon, 04 October 2004 14:53 Go to previous message
are
> projects
> Thanks
> Solomon
Previous Topic:aspects across eclipse projects?
Next Topic:PDE + AJDT = OMGBBQ
Current Time: Sat Jul 19 19:10:25 EDT 2025
Powered by FUDForum. Page generated in 0.08395 seconds
