GridTreeViewer [message #582870] |
Mon, 04 June 2007 13:08 |
--------------010702030308040407080708
I ran across the need to use the grid viewer as a tree, and discovered
that this wasn't possible with the provided GridViewer. I have
implemented a Tree Viewer based on the grid, which seems to work as
expected.
I've attached the source code so that anyone else who needs this can use
it (or not).
Mike.
name="GridTreeViewer.java"
Content-Disposition: inline;
filename="GridTreeViewer.java"
cGFja2FnZSBvcmcuZWNsaXBzZS5uZWJ1bGEuamZhY2UuZ3JpZHZpZXdlcjsN Cg0KaW1wb3J0
IGphdmEudXRpbC5MaXN0Ow0KDQppbXBvcnQgb3JnLmVjbGlwc2UuamZhY2Uu dmlld2Vycy5B
YnN0cmFjdFRyZWVWaWV3ZXI7DQppbXBvcnQgb3JnLmVjbGlwc2UuamZhY2Uu dmlld2Vycy5W
aWV3ZXJSb3c7DQppbXBvcnQgb3JnLmVjbGlwc2UubmVidWxhLmpmYWNlLmdy aWR2aWV3ZXIu
R3JpZFZpZXdlclJvdzsNCmltcG9ydCBvcmcuZWNsaXBzZS5uZWJ1bGEud2lk Z2V0cy5ncmlk
LkdyaWQ7DQppbXBvcnQgb3JnLmVjbGlwc2UubmVidWxhLndpZGdldHMuZ3Jp ZC5HcmlkSXRl
bTsNCmltcG9ydCBvcmcuZWNsaXBzZS5zd3QuU1dUOw0KaW1wb3J0IG9yZy5l Y2xpcHNlLnN3
dC5ldmVudHMuVHJlZUxpc3RlbmVyOw0KaW1wb3J0IG9yZy5lY2xpcHNlLnN3 dC53aWRnZXRz
LkNvbXBvc2l0ZTsNCmltcG9ydCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5D b250cm9sOw0K
aW1wb3J0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkl0ZW07DQppbXBvcnQg b3JnLmVjbGlw
c2Uuc3d0LndpZGdldHMuV2lkZ2V0Ow0KDQpwdWJsaWMgY2xhc3MgR3JpZFRy ZWVWaWV3ZXIg
ZXh0ZW5kcyBBYnN0cmFjdFRyZWVWaWV3ZXIgew0KCXByaXZhdGUgR3JpZCBn cmlkOw0KCXBy
aXZhdGUgR3JpZFZpZXdlclJvdyBjYWNoZWRSb3c7DQoNCglwdWJsaWMgR3Jp ZFRyZWVWaWV3
ZXIoQ29tcG9zaXRlIHBhcmVudCkgew0KCQlzdXBlcigpOw0KCQlncmlkID0g bmV3IEdyaWQo
cGFyZW50LCBTV1QuTk9STUFMKTsNCgkJaG9va0NvbnRyb2woZ3JpZCk7DQoJ fQ0KDQoJcHVi
bGljIEdyaWQgZ2V0R3JpZCgpIHsNCgkJcmV0dXJuIGdyaWQ7DQoJfQ0KDQoJ QE92ZXJyaWRl
DQoJcHJvdGVjdGVkIHZvaWQgYWRkVHJlZUxpc3RlbmVyKENvbnRyb2wgY29u dHJvbCwgVHJl
ZUxpc3RlbmVyIGxpc3RlbmVyKSB7DQoJCSgoR3JpZCkgY29udHJvbCkuYWRk VHJlZUxpc3Rl
bmVyKGxpc3RlbmVyKTsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90ZWN0ZWQg SXRlbVtdIGdl
dENoaWxkcmVuKFdpZGdldCBvKSB7DQoJCWlmIChvIGluc3RhbmNlb2YgR3Jp ZEl0ZW0pIHsN
CgkJCXJldHVybiAoKEdyaWRJdGVtKSBvKS5nZXRJdGVtcygpOw0KCQl9DQoJ CWlmIChvIGlu
c3RhbmNlb2YgR3JpZCkgew0KCQkJcmV0dXJuICgoR3JpZCkgbykuZ2V0SXRl bXMoKTsNCgkJ
fQ0KCQlyZXR1cm4gbnVsbDsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90ZWN0 ZWQgYm9vbGVh
biBnZXRFeHBhbmRlZChJdGVtIGl0ZW0pIHsNCgkJcmV0dXJuICgoR3JpZEl0 ZW0pIGl0ZW0p
LmlzRXhwYW5kZWQoKTsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90ZWN0ZWQg aW50IGdldEl0
ZW1Db3VudChDb250cm9sIGNvbnRyb2wpIHsNCgkJcmV0dXJuICgoR3JpZCkg Y29udHJvbCku
Z2V0SXRlbUNvdW50KCk7DQoJfQ0KDQoJQE92ZXJyaWRlDQoJcHJvdGVjdGVk IGludCBnZXRJ
dGVtQ291bnQoSXRlbSBpdGVtKSB7DQoJCXJldHVybiAoKEdyaWRJdGVtKSBp dGVtKS5nZXRJ
dGVtQ291bnQoKTsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90ZWN0ZWQgSXRl bVtdIGdldEl0
ZW1zKEl0ZW0gaXRlbSkgew0KCQlyZXR1cm4gKChHcmlkSXRlbSkgaXRlbSku Z2V0SXRlbXMo
KTsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90ZWN0ZWQgSXRlbSBnZXRQYXJl bnRJdGVtKEl0
ZW0gaXRlbSkgew0KCQlyZXR1cm4gKChHcmlkSXRlbSkgaXRlbSkuZ2V0UGFy ZW50SXRlbSgp
Ow0KCX0NCg0KCUBPdmVycmlkZQ0KCXByb3RlY3RlZCBJdGVtW10gZ2V0U2Vs ZWN0aW9uKENv
bnRyb2wgY29udHJvbCkgew0KCQlyZXR1cm4gKChHcmlkKSBjb250cm9sKS5n ZXRTZWxlY3Rp
b24oKTsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90ZWN0ZWQgSXRlbSBuZXdJ dGVtKFdpZGdl
dCBwYXJlbnQsIGludCBzdHlsZSwgaW50IGluZGV4KSB7DQoJCUdyaWRJdGVt IGl0ZW07DQoN
CgkJaWYgKHBhcmVudCBpbnN0YW5jZW9mIEdyaWRJdGVtKSB7DQoJCQlpdGVt ID0gKEdyaWRJ
dGVtKSBjcmVhdGVOZXdSb3dQYXJ0KGdldFZpZXdlclJvd0Zyb21JdGVtKHBh cmVudCksDQoJ
CQkJCXN0eWxlLCBpbmRleCkuZ2V0SXRlbSgpOw0KCQl9IGVsc2Ugew0KCQkJ aXRlbSA9IChH
cmlkSXRlbSkgY3JlYXRlTmV3Um93UGFydChudWxsLCBzdHlsZSwgaW5kZXgp LmdldEl0ZW0o
KTsNCgkJfQ0KDQoJCXJldHVybiBpdGVtOw0KCX0NCgkNCgkvKioNCgkgKiBD cmVhdGUgYSBu
ZXcgVmlld2VyUm93IGF0IHJvd0luZGV4DQoJICogDQoJICogQHBhcmFtIHBh cmVudA0KCSAq
IEBwYXJhbSBzdHlsZQ0KCSAqIEBwYXJhbSByb3dJbmRleA0KCSAqIEByZXR1 cm4gVmlld2Vy
Um93DQoJICovDQoJcHJpdmF0ZSBWaWV3ZXJSb3cgY3JlYXRlTmV3Um93UGFy dChWaWV3ZXJS
b3cgcGFyZW50LCBpbnQgc3R5bGUsIGludCByb3dJbmRleCkgew0KCQlpZiAo cGFyZW50ID09
IG51bGwpIHsNCgkJCWlmIChyb3dJbmRleCA+PSAwKSB7DQoJCQkJcmV0dXJu IGdldFZpZXdl
clJvd0Zyb21JdGVtKG5ldyBHcmlkSXRlbShncmlkLCBzdHlsZSwgcm93SW5k ZXgpKTsNCgkJ
CX0NCgkJCXJldHVybiBnZXRWaWV3ZXJSb3dGcm9tSXRlbShuZXcgR3JpZEl0 ZW0oZ3JpZCwg
c3R5bGUpKTsNCgkJfQ0KDQoJCWlmIChyb3dJbmRleCA+PSAwKSB7DQoJCQly ZXR1cm4gZ2V0
Vmlld2VyUm93RnJvbUl0ZW0obmV3IEdyaWRJdGVtKChHcmlkSXRlbSkgcGFy ZW50LmdldEl0
ZW0oKSwNCgkJCQkJU1dULk5PTkUsIHJvd0luZGV4KSk7DQoJCX0NCg0KCQly ZXR1cm4gZ2V0
ZW0oKSwNCgkJCQlTV1QuTk9ORSkpOw0KCX0NCg0KCUBPdmVycmlkZQ0KCXBy b3RlY3RlZCB2
b2lkIHJlbW92ZUFsbChDb250cm9sIGNvbnRyb2wpIHsNCgkJKChHcmlkKSBj b250cm9sKS5y
ZW1vdmVBbGwoKTsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90ZWN0ZWQgdm9p ZCBzZXRFeHBh
bmRlZChJdGVtIGl0ZW0sIGJvb2xlYW4gZXhwYW5kKSB7DQoJCSgoR3JpZEl0 ZW0paXRlbSku
c2V0RXhwYW5kZWQoZXhwYW5kKTsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90 ZWN0ZWQgdm9p
ZCBzZXRTZWxlY3Rpb24oTGlzdCBpdGVtcykgew0KCQlJdGVtW10gY3VycmVu dCA9IGdldFNl
bGVjdGlvbihnZXRHcmlkKCkpOw0KDQoJCS8vIERvbid0IGJvdGhlciByZXNl dHRpbmcgdGhl
IHNhbWUgc2VsZWN0aW9uDQoJCWlmIChpc1NhbWVTZWxlY3Rpb24oaXRlbXMs IGN1cnJlbnQp
KSB7DQoJCQlyZXR1cm47DQoJCX0NCg0KCQlHcmlkSXRlbVtdIG5ld0l0ZW1z ID0gbmV3IEdy
aWRJdGVtW2l0ZW1zLnNpemUoKV07DQoJCWl0ZW1zLnRvQXJyYXkobmV3SXRl bXMpOw0KCQln
ZXRHcmlkKCkuc2V0U2VsZWN0aW9uKG5ld0l0ZW1zKTsNCgl9DQoNCglAT3Zl cnJpZGUNCglw
cm90ZWN0ZWQgdm9pZCBzaG93SXRlbShJdGVtIGl0ZW0pIHsNCgkJZ2V0R3Jp ZCgpLnNob3dJ
dGVtKChHcmlkSXRlbSkgaXRlbSk7DQoJCQ0KCX0NCg0KCUBPdmVycmlkZQ0K CXB1YmxpYyBD
b250cm9sIGdldENvbnRyb2woKSB7DQoJCXJldHVybiBnZXRHcmlkKCk7DQoJ fQ0KDQoJQE92
ZXJyaWRlDQoJcHJvdGVjdGVkIFZpZXdlclJvdyBnZXRWaWV3ZXJSb3dGcm9t SXRlbShXaWRn
ZXQgaXRlbSkgew0KCQlpZiggY2FjaGVkUm93ID09IG51bGwgKSB7DQoJCQlj YWNoZWRSb3cg
PSBuZXcgR3JpZFZpZXdlclJvdygoR3JpZEl0ZW0pIGl0ZW0pOw0KCQl9IGVs c2Ugew0KCQkJ
Y2FjaGVkUm93LnNldEl0ZW0oKEdyaWRJdGVtKSBpdGVtKTsNCgkJfQ0KCQkN CgkJcmV0dXJu
IGNhY2hlZFJvdzsNCgl9DQoNCglAT3ZlcnJpZGUNCglwcm90ZWN0ZWQgV2lk Z2V0IGdldENv
bHVtblZpZXdlck93bmVyKGludCBjb2x1bW5JbmRleCkgew0KCQlpZiAoY29s dW1uSW5kZXgg
PCAwIHx8ICggY29sdW1uSW5kZXggPiAwICYmIGNvbHVtbkluZGV4ID49IGdl dEdyaWQoKS5n
ZXRDb2x1bW5Db3VudCgpICkgKSB7DQoJCQlyZXR1cm4gbnVsbDsNCgkJfQ0K DQoJCWlmIChn
ZXRHcmlkKCkuZ2V0Q29sdW1uQ291bnQoKSA9PSAwKS8vIEhhbmcgaXQgb2Zm IHRoZSB0YWJs
ZSBpZiBpdA0KCQkJcmV0dXJuIGdldEdyaWQoKTsNCg0KCQlyZXR1cm4gZ2V0 R3JpZCgpLmdl
dENvbHVtbihjb2x1bW5JbmRleCk7DQoJfQ0KDQoJQE92ZXJyaWRlDQoJcHJv dGVjdGVkIGlu
dCBkb0dldENvbHVtbkNvdW50KCkgew0KCQlyZXR1cm4gZ3JpZC5nZXRDb2x1 bW5Db3VudCgp
Ow0KCX0NCg0KfQ==
--------------010702030308040407080708--
FUDForum. Page generated in 0.03620 seconds
