Re: AJDT version 1.1.11 works with AspectJ version 1.2 or 1.1.1 ? [message #39805 is a reply to message #39774] |
Tue, 03 August 2004 10:34  |
Originally posted by: alessandrofm.softplan.com.br
Hi Matt,
Yes.. your answer makes things clearer.... but the plugins folder.. oh my
So I will uninstall AspectJ 1.2 (that was installed before the plugin)..
Thanks a lot
Alessandro
"Matt Chapman" <mchapman@uk.ibm.com> escreveu na mensagem
news:pan.2004.08.03.14.11.43.559099@uk.ibm.com...
> On Tue, 03 Aug 2004 10:44:33 -0300, Alessandro Fragnani de Morais wrote:
> > With wich version AJDT 1.1.1 works?
> > Must I install it manually and configure it to works with AspectJ 1.2?
> If you only want to use AspectJ inside Eclipse, then you only need to
> install AJDT. Each version of AJDT includes the latest version of AspectJ
> at the time of release. Despite its name the version number of the plugin
> you mention refers to AJDT not to AspectJ - bit confusing I admit. I
> suggest not looking too closely at the individual plugins that make up
> AJDT :)
> So with AJDT 1.1.11 you have the latest version of everything. I hope that
> makes things a little clearer.
> Matt.
Re: AJDT version 1.1.11 works with AspectJ version 1.2 or 1.1.1 ? [message #582530 is a reply to message #39743] |
Tue, 03 August 2004 10:11  |
AJDT :)
Matt.
Re: AJDT version 1.1.11 works with AspectJ version 1.2 or 1.1.1 ? [message #582548 is a reply to message #39774] |
Hi Matt,
Thanks a lot
Alessandro
> AJDT :)
> Matt.
FUDForum. Page generated in 0.03997 seconds
