NoClassDefFoundError with Aspectj 1.2 (upd) on Eclipse 2.1.3 [message #582457] |
Mon, 02 August 2004 02:36 |
Hello
I am using Eclipse 2.1.3, have ajdt 1.4 installed and updated for Aspectj
1.2. Because I am new to aspect-oriented Programming, I tried to implement
first a logging aspect as I learned by "AspectJ in action" (see the source
below). I can ompile the whole code without problems, but running the
example I get always an NoClassDefFoundError. This Error occures at the
first place, where i use one of my core classes named Path, that has some
static String constants containing pathnames to the system. Without aspectj
the project runs problemless.
I searched the web, found an entry in the bugzilla tool for eclipse
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=44587) but that points to
ajdt 1.4 without update. Has anybody any idea how I could solve that
problem? Thank you in advance!
Christian
* Created on 21.07.2004
* To change the template for this generated file go to
* Window>Preferences>Java>Code Generation>Code and Comments
package ch.eugster.pos;
import ch.eugster.pos.client.event.ExceptionThrownDelegate;
import ch.eugster.pos.client.event.ExceptionThrownEvent;
import ch.eugster.pos.util.Path;
import java.io.IOException;
import java.lang.SecurityException;
import java.text.DateFormat;
import java.text.SimpleDateFormat;
import java.util.Date;
import java.util.logging.FileHandler;
import java.util.logging.Level;
import java.util.logging.Logger;
import java.util.logging.SimpleFormatter;
import org.aspectj.lang.Signature;
* @author ceugster
* To change the template for this generated type comment go to
public aspect LoggingAspect {
private Logger _logger = Logger.getLogger("logging");
private Level level = Level.SEVERE;
LoggingAspect() {
_logger.setLevel(level);
try {
FileHandler fh = new FileHandler(Path.logDir.concat(Path.FILE_LOG), true);
fh.setFormatter(new SimpleFormatter());
catch (IOException e) {
catch (SecurityException e) {
catch (ExceptionInInitializerError e) {
pointcut traceMethods()
: execution(* *(..)) && !within(LoggingAspect);
before() : traceMethods() {
if (_logger.isLoggable(Level.INFO)) {
Signature sig = thisJoinPointStaticPart.getSignature();
_logger.logp(Level.INFO,
sig.getDeclaringType().getName(),
sig.getName(),
"Entering: " + sig.getDeclaringType().getName() + "." + sig.getName());
after() : traceMethods() {
sig.getName(),
"Leaving: " + sig.getDeclaringType().getName() + "." + sig.getName());
pointcut exceptionLogMethods()
after() throwing(Throwable ex) : exceptionLogMethods() {
if (_logger.isLoggable(Level.WARNING)) {
_logger.logp(Level.WARNING,
sig.getName(),
"Exception thrown: " +
ex.getLocalizedMessage());
DateFormat df = SimpleDateFormat.getDateTimeInstance(SimpleDateFormat.SHORT,
SimpleDateFormat.SHORT);
ExceptionThrownDelegate.fireExceptionThrownEvent(new
ExceptionThrownEvent(df.format(new Date()) + ": Exception thrown - " +
ex.getLocalizedMessage() + "\n"));
FUDForum. Page generated in 0.02780 seconds
