Home » Archived » XML Schema Definition (XSD) » "fixed" and "default" and "groups"
"fixed" and "default" and "groups" [message #34893] Tue, 06 January 2004 09:54 Go to next message
Originally posted by: crscca.bol.net.in
Hi Eddie!
Based on your reply I could figure out where I was going wrong on the
facet question. Thanks.
Two new questions-
1. In a simpleElem ent and a Attribute how do I obtain the values
specified as "fixed" and "default"
2. In the following xsd I have shown maxOccurs in four places. Would all
the four maxOccurs be indicated or is any particular occurence redundant
and left out when I use the api.
Thank you.
Ras
<xs:schema xmlns:xs='http://www.w3.org/2001/XMLSchema'>
<xs:group name="persongroup">
<xs:choice maxOccurs="5">
<xs:element name="firstname" type="xs:string" maxOccurs="4"/>
<xs:element name="lastname" type="xs:string"/>
<xs:element name="birthday" type="xs:date"/>
</xs:choice>
</xs:group>
<xs:element name="person" type="personinfo"/>
<xs:complexType name="personinfo">
<xs:sequence maxOccurs="2">
<xs:group ref="persongroup" maxOccurs="3"/>
<xs:element name="country" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
Re: "fixed" and "default" and "groups" [message #34940 is a reply to message #34893] Tue, 06 January 2004 10:02 Go to previous messageGo to next message
(Afterthought: Also maybe the <xs:choice...> does not m ake m uch sense
make it sequence or whatever.)
Raster wrote:
> Hi Eddie!
> Two new questions-
> Thank you.
> Ras
> </xs:choice>
> </xs:group>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
Re: "fixed" and "default" and "groups" [message #35009 is a reply to message #34893] Tue, 06 January 2004 17:53 Go to previous messageGo to next message
Hi Ras,
Ed's on vacation right now, so let me try to answer your questions...
XSDFeature is a common base class for XSDElementDeclaration and
XSDAttributeDeclaration that provides two applicable attributes:
lexicalValue and value. The getLexicalValue() method will give you the
string literal, and getValue() makes the value available as an object.
Each XSDModelGroup, XSDElementDeclaration and XSDWildcard is contained by an
XSDParticle, which provides the minOccurs and maxOccurs attributes you're
looking for. All but your first maxOccurs are available from the appropriate
XSDParticles. That first maxOccurs is not permitted (whether that model
group is a sequence or a choice).
Let me suggest that you try loading examples like this in the Sample XML
Schema Editor. It will flag any errors, and probably give you some insight
into the model (although, admittedly, it does do things like presenting a
particle and its contents as a single object, in order to match the XML
Schema syntax).
Hope that helps.
Dave
Re: "fixed" and "default" and "groups" [message #35043 is a reply to message #35009] Tue, 06 January 2004 18:58 Go to previous messageGo to next message
Hi Dave,
Lets hope Ed's enjoying his vacation.
1. Yeah it helped. I also figured out that the getConstraint() method
tels one whether its "fixed" or "default".
2. About the maxOccurs I was using the api and not able to get access to
one of the maxOccurs-namely the first so I suspected that one of those
maxOccurs is not available. I was actually getting the last maxOccurs
twice [also in place of the m axOccurs for the choice(first maxOccurs)].
It must be a bug in my code I guess. I have to clean up my code and sort
that out later. I dont suppose we would get the last maxOccurs in place of
the first maxOccurs. Would we?
3. You mentioned the "Sample XML Schema Editor". Is that something
different from the "Extension Point Schema Editor"? If so where do I get
it?
Thank you.
Dave Steinberg wrote:
> Hi Ras,
> Schema syntax).
> Hope that helps.
> Cheers,
> Dave
Re: "fixed" and "default" and "groups" [message #35076 is a reply to message #35043] Wed, 07 January 2004 11:28 Go to previous messageGo to next message
Ras,
I'm not exactly sure what you mean here. The first maxOccurs is invalid
because there's nowhere to put it, so I'm not sure what you mean by getting
it "in place of" the first. If I may, here's the concrete, containment model
for your schema (pardon the ASCII art):
XSDSchema
+- XSDModelGroupDefinition ("persongroup")
| +- XSDModelGroup (sequence)
| +- XSDParticle [1,4]
| | + XSDElementDeclaration ("firstname")
| +- XSDParticle [1,1]
| | + XSDElementDeclaration ("lastname")
| +- XSDElementDeclaration ("birthday")
+- XSDElementDeclaration ("person")
+- XSDComplexType ("personinfo")
+- XSDParticle [1,2]
+- XSDParticle [1,3]
+- XSDElementDeclaration ("country")
Now, because that last XSDModelGroupDefinition is a reference to
"persongroup", its resolvedModelGroupDefinition reference points back to the
first XSDModelGroupDefinition (whose modelGroup is also pointed at directly
by the containing XSDParticle's term reference).
Notice, then, that the maxOccurs values of 4, 2, and 3 are placed in the
particles containing "firstname", the model group in "personinfo", and the
model group reference, respectively. There is no particle for the top-level
model group definition, so there's nowhere to put a maxOccurs value.
> it?
Yes. The Extension Point Schema Editor is part of the Eclipse PDE, and it
only supports the subset of XML Schema allowed in defining extension points.
The Sample XML Schema Editor is built on XSD, and included in the XSD
Runtime package. No one has had the time to make it perfect as an editor
(that's why it's called a sample), but it's the best way to see what's going
on in XSD, and it's excellent at catching errors in your schemas.
In Eclipse, right-click a schema file and select Open With -> Sample XML
Schema Editor. Unfortunately, the Extension Point Schema Editor is the
default for .xsd files in Eclipse, but you can change that via Preferences
-> Workbench -> File Associations.
Dave
Re: "fixed" and "default" and "groups" [message #35350 is a reply to message #35076] Sat, 10 January 2004 09:59 Go to previous messageGo to next message
Hi Dave,
You really took some pains. Its much appreciated.
Me and a friend are working on a project that involves amongst other
things xsd handling. Our project uses eclipse and tries to extend it for
certain specific purposes. We would be through with the core xsd portion
in a few days. That would be only one file a simple Java class for the
core xsd thingy. Would it be okay if we posted the code (the one java
class) for code-review by you or Ed or anyone who can do that from ibm or
eclipse?
I know how hard it is to look at other peoples code. So we wont feel too
disappointed if you dont.
Ras
> Ras,
> XSDSchema
> > it?
> Cheers,
> Dave
Re: "fixed" and "default" and "groups" [message #35384 is a reply to message #35350] Mon, 12 January 2004 07:30 Go to previous messageGo to next message
having spent some time this weekend we are clearer on the api and so we
dont need the code-review.
A few doubts exist which we shall clarify with you any way later.
Thanks.
Raster wrote:
> Hi Dave,
> eclipse?
> Ras
to
of
> > Ras,
getting
model
> > XSDSchema
the
directly
top-level
> > > it?
points.
going
> > Cheers,
> > Dave
Re: "fixed" and "default" and "groups" [message #35418 is a reply to message #35384] Mon, 12 January 2004 09:06 Go to previous message
Hi Ras,
I'm glad to hear that you're starting to grok the model. It's not a simple
or small thing to get your head around.
We're happy to help with whatever doubts still exist. Ask away! :)
Dave
Re: "fixed" and "default" and "groups" [message #582217 is a reply to message #34893] Tue, 06 January 2004 10:02 Go to previous message
Raster wrote:
> Hi Eddie!
> Two new questions-
> Thank you.
> Ras
> </xs:choice>
> </xs:group>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
Re: "fixed" and "default" and "groups" [message #582257 is a reply to message #34893] Tue, 06 January 2004 17:53 Go to previous message
Hi Ras,
Schema syntax).
Hope that helps.
Dave
Re: "fixed" and "default" and "groups" [message #582273 is a reply to message #35009] Tue, 06 January 2004 18:58 Go to previous message
Hi Dave,
it?
Thank you.
> Hi Ras,
> Schema syntax).
> Hope that helps.
> Cheers,
> Dave
Re: "fixed" and "default" and "groups" [message #582284 is a reply to message #35043] Wed, 07 January 2004 11:28 Go to previous message
Ras,
XSDSchema
> it?
Dave
Re: "fixed" and "default" and "groups" [message #582426 is a reply to message #35076] Sat, 10 January 2004 09:59 Go to previous message
Hi Dave,
eclipse?
Ras
> Ras,
> XSDSchema
> > it?
> Cheers,
> Dave
Re: "fixed" and "default" and "groups" [message #582459 is a reply to message #35350] Mon, 12 January 2004 07:30 Go to previous message
Thanks.
Raster wrote:
> Hi Dave,
> eclipse?
> Ras
to
of
> > Ras,
getting
model
> > XSDSchema
the
directly
top-level
> > > it?
points.
going
> > Cheers,
> > Dave
Re: "fixed" and "default" and "groups" [message #582471 is a reply to message #35384] Mon, 12 January 2004 09:06 Go to previous message
Hi Ras,
Dave
Previous Topic:problem with headless xml schema -> genmodel
Next Topic:use="required"/use="optional"
Current Time: Sat Jul 19 09:54:38 EDT 2025
Powered by FUDForum. Page generated in 0.08649 seconds
