Home » Modeling » Modeling (top-level project) » Beginners trouble with modeling.
Beginners trouble with modeling. [message #582156] Mon, 25 September 2006 11:42
Hey,
I'm having trouble with building a model for gmf in a xsd file.
I want to start off with a very simple model that contains only one type
of element that can then be associated with other elements (a directed
association) of the same type. The element will have some attributes (or
should these be elements?) as well but it's doing the association I don't
understand.
What I want to model is a simple dialogue that is divided into segments.
Each node to be a segment in a graph structure.
So something like:
<xsd:schema
targetNamespace="http://www.example.org/dialoguegraph"
xmlns:dialoguegraph="http://www.example.org/dialoguegraph"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<xsd:complexType name="DialogueSegment">
<xsd:attribute name="intro_text" type="xsd:string"/> //set to max of one
<xsd:attribute name="transcript" type="xsd:string"/> //set to max of one
<xsd:attribute name="outro_text" type="xsd:string"/> //0..*
</xsd:complexType>
//set the relatonship between nodes?????
</xsd:schema>
Previous Topic:Ignoring Notifications That Occur During Proxy Resolution
Next Topic:Beginners trouble with modeling.
Current Time: Sun Jul 20 03:18:13 EDT 2025
Powered by FUDForum. Page generated in 0.03467 seconds
